More Info Needed!!Cubzilla!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 02-13-2007, 08:03 AM   post #1 of 48
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Question More Info Needed!!Cubzilla!!
Saw this while surfing the MTF Gallery..
I will PM Coop to see if he can give us more info!!
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-13-2007, 10:50 AM   post #2 of 48
raytasch
Old Guy With Old Toys
raytasch's Avatar
MTF Member # 4585
Images: 2
Default Re: More Info Needed!!Cubzilla!!
Awsome machine. Would like to see more of it.
__________________
ray
Ford Jubilee-- restored, pulls a finish mower once in a while
Ford 850 -- the workhorse--does it all
IH CC 122--semi retired-awaiting restoration
JD 4300HST FWDA W/Loader--- another workhorse
Sears DGS6500
raytasch is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 11:05 AM   post #3 of 48
REW
Senior MTF Member
REW's Avatar
MTF Member # 3817
Somebody has some fab skills to make something like that.
__________________
Richard
John Deere Green
REW is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 11:11 AM   post #4 of 48
Edward
My kid @ W.H. gift shop:
Edward's Avatar
MTF Member # 4340
Images: 9
Seems like the weight up front would lift the back end up? I don't see weights: or do I not understand why the rear wheels aren't off the ground? /n00b
Edward is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 11:40 AM   post #5 of 48
jodyand
Retired Super Moderator
jodyand's Avatar
MTF Member # 6
Images: 23
Im sure there is more weight in the back then in the front or the back would be off the ground.
__________________
Jody
Dodge
you drive the Rest I drive the Best.
2006 Dodge 1500 Mega Cab
2004 Flagstaff 8524RK 5th Wheel
jodyand is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 01:46 PM   post #6 of 48
Mith_J
Eccentric Englishman
MTF Member # 801
Ken, there was alot of info on it over at weekendfreedommachines.org, but I cant find the posts any more.
Here is a link to his profile
__________________
Jim
Mith_J is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 01:51 PM   post #7 of 48
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Coop has registered on MTF, uploaded his photo in the MTF Gallery, but has never posted..
__________________
Old 02-13-2007, 03:47 PM   post #8 of 48
Jim_WV
Jim_WV's Avatar
MTF Member # 241
Images: 13
Garage
Defintley a unique looking machine for sure
Jim_WV is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 05:06 PM   post #9 of 48
john_deere_kid
2 Yr Member of WFM
john_deere_kid's Avatar
MTF Member # 4830
Images: 6
Mith, what happened was that it was in the Corner Store there in the off topic tractor thread. What happened was the thread was deleted and they dont archive the cornerstore over there. Go to http://www.ihregistry.com and go to their forum. There should be a custom corner forum. Try there. You might have to look throgh the archived threads to find it, but you will find it there.
__________________
1993 F150 Used to be Flareside
135000 Miles
4x4
5.8l 351w V8 thats burning oil and leaking a quart a day
E4OD automatic
Primer Gray (Soon to be Foxfire Metallic)
Short bed
Standard Cab
Rebuilt after being rolled over on 11-18-08
1993 Crown Victoria
115000 Miles
4.6l 281 V8 that runs like a top
Green
Black Steel Wheels 15"
Home made "Cherry Bomb" exhaust
Daily Driver
john_deere_kid is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 05:12 PM   post #10 of 48
Mith_J
MTF Member # 801
JDK, yea I know, it sucks. I'm glad places like this dont just dump the old threads.
Thanks for the link to that site. Following that link and searching for cubzilla all the goodies came up.
__________________
Jim
Old 02-13-2007, 08:28 PM   post #11 of 48
Coop
Senior MTF Member
Coop's Avatar
MTF Member # 4464
Images: 5
Hi Guys...Sorry to post a pic of Cubzilla without any info. I'm new to this site, actually have never posted here other than the pic in my gallery.
Cubzilla is an articulated, 4 wheel drive, 4 cylinder tractor. It started out as (2) 126 Cub cadets, the front one had a factory installed rear PTO, I used this to get power back to the rear transaxle in order to have 4 wheel drive. As long as I am in the same gear in both transxles, I have 4 wheel drive. For normal driving around, I just disengage the PTO, and I can shift normally using just the front transaxle. The rear tranaxle has been modified by removing the reduction gears and housing so the PTO shaft drives the rear transaxle directly and at the same speed as the front.
The weight hanging out the front was a problem I fought with for awhile at first. I moved the front axle forward in the frame 7 inches to get as much weight forward as I could. This helped, but not enough. On the back I added 250# of Kubota suitcase weights, this solved the front heavy problem. At this point in the build I had the stock Kohler 12 hp engine in it, and they are heavy, to the tune of 175#. I pretty much worked out the rest of the bugs in the machine with this engine, but I wanted something more unique as far as the engine went, so I decided to use the US Army surplus engine that is in it now, 4 cylinder gas, air cooled, and the bonus is it only weighs 105#, so I shaved 70 # off the front just by using this engine. I no longer need the weights on the back now, and I will be removing them over the winter because I am adding a Cat 0 3 pt hitch to the rear where the weights are now. If it turns out I want weight on the rear, I can either hang the weights off the rear, or load the tires.
The steering is hydraulic, has 2 rams in a push-pull set-up, the pump is mounted on the front of the engine and coupled to the engine with a Love Joy coupling. Steering is controlled by a Char-Lyn steering valve. The pivot points for the steering consist of a cat 0 top link at the top, and a trailer ball pivot at the bottom. This arrangement not only allows the tractor to pivot, but because the top link is able to pivot at both ends, the tractor oscillates as well when going over un-even ground. I have the pivot points located exactly center of the front and rear axle centerlines, this means that when making a turn, the rear wheels follow in the same track as the fronts. I'd post detailed pics of all this, but I haven't fiquired out how to put a pic in a post, I'll try to add them to my gallery.
The build took me 11 months to complete, alot of time was spent just sitting and pondering how to make it all work, and then re-doing something when it didn't work. There are build pics over at ihregistry.com , you will find them in the Custom Corner Archives, starting about a year ago.
C]oop
Coop is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 10:19 PM   post #12 of 48
Edward
Edward's Avatar
MTF Member # 4340
Images: 9
Cool! Looks like you had fun building it
Old 02-13-2007, 10:31 PM   post #13 of 48
Jim_WV
Jim_WV's Avatar
MTF Member # 241
Images: 13
Garage
Hey Coop , well welcome and thanks for the info on this machine, that was interesting and quite a fine job
Hope to see ya around more often and thanks again for sharing with us
Old 02-14-2007, 01:18 AM   post #14 of 48
mbkerk
I'd rather be threshing!
mbkerk's Avatar
MTF Member # 59
Images: 10
Quote:
Obvious a lot of thought went into your project, and it shows!
Thanks so much for sharing the details, and keep visiting!
__________________
Mark
Fargo, ND
Where are you from? VOTE HERE! To represent your state!
2004 Craftsman GT 5000 1962 Cub Cadet 1944 John Deere B 1954 John Deere R Diesel
1945 VAI Case 1998 Dodge Ram 2500 4X4 / Cummins 24V
mbkerk is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-14-2007, 06:21 AM   post #15 of 48
pigsitter
the "AWOL member"
pigsitter's Avatar
MTF Member # 1020
Images: 1
Great machine coop!!!Please don't take so long to post again!
__________________
My favorite song
proud to be a member since 2005 and aggravating Ken in NJ since sometime shortly thereafter
Uh Oh! someone left the gate open, pig's gone walkabout again!!
Where is everybody?
pigsitter is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
