Kohler Command V Twin 20 Hp - stalling - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 02-12-2007, 12:40 PM   post #1 of 9
PatapscoPete
Simpicity Legacy
PatapscoPete's Avatar
MTF Member # 254
Default Kohler Command V Twin 20 Hp - stalling
Right after the cold weather hit around here I developed a problem with my Simplicity Legacy. My tractor is stalling out every 30 seconds or so. The Kohler Command V Twin 20 Hp starts right up with the choke engaged, but stalls out after running for a short while. The situation begins right after the engine gets up to operating temperature and the choke is disengaged. Applying the choke at that point doesn't help - I didn't think it would. Strangely though, applying any pressure to the brake immediately cancells the stall, and I'm able to go another 30 seconds before the stall begins.
I have the feeling there is a switch or something related to the brake that's causing the problem. Any hints?
Stumped
PatapscoPete is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-12-2007, 02:55 PM   post #2 of 9
sixchows
2000 Posts and climbing!!!
sixchows's Avatar
MTF Member # 3
Images: 6
Default Re: Kohler Command V Twin 20 Hp - stalling
Try setting the parking brake and see if it stays running. If it does than you're probably right about the brake safety switch and/or wiring to it.
sixchows is offline   Reply With Quote Quick reply to this message
Old 02-12-2007, 06:55 PM   post #3 of 9
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Kinda sounds like water in the gas....
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 02-12-2007, 09:28 PM   post #4 of 9
cleatusj
Proud Member of the 1K Club
cleatusj's Avatar
MTF Member # 400
Images: 2
Sounds like the electric fuel shutoff valve. Try running a jumper from battery to valve and if that doesn't work, disconnect all wires to valve in bottom of float bowl then pull pin and spring from valve and re install DO NOT HOOK UP WIRE. Now test to see if it acts the same.
__________________
I'm the guy purist/restorers don't like.
Keith .
cleatusj is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 11:21 AM   post #5 of 9
Reep1077
Senior MTF Member
MTF Member # 3747
I agree sounds like water in the gas or possibly a dirty carburator...pull of theturn the gas off and drain the float bowl and see if that helps
Reep1077 is offline   Reply With Quote Quick reply to this message
Old 02-19-2007, 10:28 AM   post #6 of 9
PatapscoPete
Simpicity Legacy
MTF Member # 254
Default Re: Simplicity Legacy - Kohler Command V Twin 20 Hp - stalling
If the temperature ever gets over 30 degrees around here I'll craw under the machine to see what gives. The stalling problem disappears when the brake pedal is depressed; an inch of pedal deflection is all that it takes. I know there is a starter interlock on the brake pedal; e.g. the engine will stall if you get off the tractor while the brake is not engaged. I have a strong feeling the interlock is to blame. There is a seat switch that may also be contributing to the problem.
I doubt the carb is at issue, as the problem is eliminated with any application of the brake. Is it possible to jump the switches to comfirm my suspicions? The tractor is a 2003 Simplicity Legacy (pre- XL makeover).
Old 02-19-2007, 12:36 PM   post #7 of 9
sixchows
sixchows's Avatar
MTF Member # 3
Images: 6
There should be a little plunger on the switch that the arm of the brake pedal makes contact with. Reach around for it and make sure it moves in and out. I had this problem on my craftsman a few years ago. I could get it to run by playing with the plunger for awhile but then wound up replacing it.
Old 02-19-2007, 01:23 PM   post #8 of 9
PatapscoPete
Simpicity Legacy
MTF Member # 254
Wink Re: Kohler Command V Twin 20 Hp - stalling
It was a safety switch alright, but not the interlock on the brake. The seat switch was not working properly. When it gets really cold, the seat switch opens up intermittently even though I'm in the seat. This forces the brake interlock into thinking the operator is no longer in control, and shuts down the ignition. If I depressed the brake, the interlock is no longer in play. That's why the stall stops immediately if I apply pressure to the brake pedal. It's designed to keep running, as long as the brake is depressed, regardless of the presence of an operator in the seat.
Thanks for the advice. It pointed me in the right direction. Now all I have to do is get a replacement seat switch, and I'm good to go.
Sponsored Links
Advertisement
Old 02-19-2007, 10:01 PM   post #9 of 9
cleatusj
cleatusj's Avatar
MTF Member # 400
Images: 2
Sorry guys I forget about all those anti law suite switchs as I have not a thing with any.
__________________
Keith .
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
