SS12 Spring 4301H - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-02-2013, 09:38 AM   post #1 of 36
arswans
MTF Novice
MTF Member # 76546
Default SS12 Spring 4301H
I just replaced the upper spring (6486H) for the clutch/brake/Idler system on my SS12, but found that the lower spring (4301H) broke as well. Does anyone know a substitute for this spring, since SearsDirect no longer carries it?
Thanks for any advice!
arswans is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-03-2013, 12:21 AM   post #2 of 36
Plowthesidewalk
7000 posts and climbing!
Plowthesidewalk's Avatar
MTF Member # 36313
Default Re: SS12 Spring 4301H
I am not sure if I have the correct spring but here is what I have found. Keep in mind no precision measuring tools were used.
Part Number 4301H
Spring Type = Extension
Ends = Across Center (possibly extended)
Hooks = Almost at 90 degrees
Length Inside Hooks = About 6 inches
Length of Coil = Not sure
Outside Diameter = About 5/8 inches
Wire Diameter = Less than 1/8 inch but more than 1/16 inch
Have you tried Century Spring? Usually hardware stores have them in stock and you simply try to match a stock spring up. If you cannot find a matching spring I would suggest trying to contact a spring company and have them make a spring to match.
Another MTF member went to Home Depot and used a larger spring and some eye hooks. They just installed their own version their way.
__________________
Hand Tool Collector
Plowthesidewalk is offline   Reply With Quote Quick reply to this message
Old 07-03-2013, 12:23 AM   post #3 of 36
Plowthesidewalk
MTF Member # 36313
Oh yeah, I just realized you are a new member here at MTF. Welcome aboard!!!!!!
:MTF_ wel:
__________________
Hand Tool Collector
Old 07-03-2013, 01:19 AM   post #4 of 36
stripmine
Member: Special K Club
stripmine's Avatar
MTF Member # 26454
Images: 5
Garage
Hi Arswans, Welcome to MTF.
According to RCPW's website listing for that spring ( HERE ), that part number has been superseded by part number 9503H.
The replacement part number IS AVAILABLE HERE AT MOWPART.COM for just $6.74.
Hope this helps.
Dave
stripmine is offline   Reply With Quote Quick reply to this message
Old 07-03-2013, 08:50 AM   post #5 of 36
arswans
MTF Novice
MTF Member # 76546
Smile Re: SS12 Spring 4301H
Thank you VERY MUCH for your replies Plowthesidewalk and stripmine.
Those measurements match.
I had not heard of RCPW - looks like a great resource.
I appreciate your time!
Old 07-03-2013, 12:25 PM   post #6 of 36
Plowthesidewalk
MTF Member # 36313
I used a precision tool to take a couple of measurements just in case the part is no longer available.
Length Inside Hooks = 6 Inches
Length of Coil = 4-5/8 Inches
Width of Coil = .637 Inches
Thickness of Wire = .110 Inches
Number of Coils = 42
Hook Opening = 1/4 Inch
Hook Extension = 3/4 Inches (to outside of hook from end of coil)
Name:	Lower Clutch Spring.jpg
ID:	359737   Click image for larger version
Name:	4301H Lower Clutch Spring.jpg
ID:	359745   Click image for larger version
ID:	359753   Click image for larger version
Name:	4301H Hook End.jpg
Name:	4301H End of Hook.jpg
__________________
Hand Tool Collector
Old 07-03-2013, 03:39 PM   post #7 of 36
arswans
MTF Novice
MTF Member # 76546
Thank you for the photos Plowthesidewalk...
However, it appears what you have in the photos is the spring I did just successfully replace (part #6486H). Maybe I had them in the wrong places, but I put that spring as the upper placement of the idler assembly. The spring I had in place on the lower portion of the assembly was a bit smaller (shorter), and had quite a bit more "give", or extendibility.
Andrew
Old 07-03-2013, 07:22 PM   post #8 of 36
Plowthesidewalk
MTF Member # 36313
Hmmmmm.......I had a brand new spring in a parts bag to go on a ST16 and the spring in the photo was sitting on a battery shelf with a clutch. The other new spring had a different part number and was shorter so I assumed I had the correct part. Oh well, who knows?
Can you snap some pics of the spring you have?
__________________
Hand Tool Collector
Old 07-03-2013, 10:49 PM   post #9 of 36
AngieK
Lady Tinkerer
AngieK's Avatar
MTF Member # 122209
arswans,
I have the same issue with the same deck. If you find a source please let me know? I promise to do the same if I find one first.
AngieK is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 03:51 PM   post #10 of 36
arswans
MTF Novice
MTF Member # 76546
Thank you AngieK.
Here is a photo of the spring in question.
I tried to order the replacement from Mowpart.com recommended by stripmine (Mowpart indicated that they had the superseding replacement part 9503H in stock)...BUT, I just got another email from them saying that they no longer have it available.
Old 07-04-2013, 06:34 PM   post #11 of 36
AngieK
Lady Tinkerer
AngieK's Avatar
MTF Member # 122209
arswans,
I'm going up to Fleet Farm and Grainger on Friday or Saturday to match mine up. If I find the right springs I'll get you one
I see your image, it's the same one I need. Mine broke off 11 coils in from the end, so I have the whole thing to match if I find any.
Old 07-04-2013, 07:38 PM   post #12 of 36
Plowthesidewalk
MTF Member # 36313
Okay, I just realized the 9503H spring is the same spring they used inside the Sears 42 and 48 inch mower decks to tension the flat idler pulley. You might even find the same spring where the mule drive is.
__________________
Hand Tool Collector
Old 07-04-2013, 07:42 PM   post #13 of 36
AngieK
Lady Tinkerer
AngieK's Avatar
MTF Member # 122209
Yes, I will need to buy 2 for myself because there is none on the mule drive either. Dad wasn't very organized it seems, after all. I had to hunt for most of the parts in his old shed until I located all but a few. But you're correct the parts breakdown shows the same spring on the mule.
Old 07-04-2013, 08:10 PM   post #14 of 36
Plowthesidewalk
MTF Member # 36313
I went to an Ace Hardware store and purchased a spring off the shelf with a matching hook on one end and it had a long straight piece of wire on the other end. I simply cut the straight end and looped it like the original and it has worked okay ever since.
__________________
Hand Tool Collector
Sponsored Links
Advertisement
Old 07-04-2013, 08:51 PM   post #15 of 36
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
looks like all you need is to bend a new hook on the end...
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
