D140 w/ 1.6 hours - Smoke on Startup??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-24-2013, 06:40 PM   post #1 of 9
troymi
MTF Junior Poster
troymi's Avatar
MTF Member # 101378
Default D140 w/ 1.6 hours - Smoke on Startup???
Ok, I didn't find anything "just" like this so I'll ask the question. Is it normal for a new (almost) D140 to smoke like this when started?
Anything I should be doing when seeing this? Thanks for advice and experience. Otherwise, everything is working great.
Ok, I'm not as good as I thought. I took a video of the smoke at startup because it did it last time also. But, the file is too huge to upload. So I took a screen shot of it paused.
__________________
2013 John Deere D140 (Vince)
troymi is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-24-2013, 06:58 PM   post #2 of 9
jd2007
Senior MTF Member
jd2007's Avatar
MTF Member # 76293
Garage
Default Re: D140 w/ 1.6 hours - Smoke on Startup???
An little smoke at start-up is normal when the choke is used.
__________________
John Deere 345, L130, LT133, & JX75
MTF Tech Exchange Articles
jd2007 is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 07:07 PM   post #3 of 9
JohnDeere318Guy
Proud Member of the 1K Club
JohnDeere318Guy's Avatar
MTF Member # 68096
Images: 21
Garage
The rings probably haven't fully seated yet, it will diminish as it gets more hours on it.
__________________
-1999 John Deere F1145 -28HP Yanmar Diesel, 72'' Deck, 4x4, Roll-Guard, Carlisle Tires
-1989 John Deere 318 -18HP Onan P218G, Carlisle Tires
-1987 John Deere 318 -18HP Onan P218G, 46 Deck, 54 Blade, Wheel Weights, Chains, Goodyear Tires
-1988 John Deere 322 -18HP Yanmar Liquid Cooled Gas, Deestone Tires
-2009 John Deere LA115
JohnDeere318Guy is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 07:27 PM   post #4 of 9
Basstracker34
LA125
MTF Member # 76669
While it's doubtful it'd be the same problem I had, it's an easy fix if it is.
My '08 LA125 with 98HRS was smoking while mowing and at startup. It turned out being a blown head gasket. I got it fixed easily in one night. Think it was about $12 at the dealer for both gaskets needed. Just looked online for how to videos posted on youtube and did it all myself.
Basstracker34 is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 07:27 PM   post #5 of 9
Mach-1
Proud JD Owner
Mach-1's Avatar
MTF Member # 51303
You have warranty. Let the engine break in some and it should get better. Some smoke upon startup is normal. When my Poulan has been sitting for a few days, it will smoke for the first few minutes of running. No biggie.
__________________
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
2003 Poulan 1742 (not ultimate)
Mach-1 is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 10:02 PM   post #6 of 9
forum009
Senior MTF Member
MTF Member # 82054
On my X320, I found startup continues to get easier and cleaner. After 3 yrs and 138 hours, startup is smokeless I agree you probably just need the engine to break in and the rings to seat.
Sent from the MTF Free App
forum009 is offline   Reply With Quote Quick reply to this message
Old 06-26-2013, 06:49 PM   post #7 of 9
ryanpf
L120/G110 Hybridizer
ryanpf's Avatar
MTF Member # 31574
Congrats on your new D-140. That's an excellent machine for its intended purpose.
I'll offer you my experiences with my Intek twin, similar to yours, and now almost 10 years old. It has 425+ hours on it. Sometimes it smokes on startup but most times not. A hot start will NEVER blow smoke. When a cold start does smoke, it is just a brief event. Never noticed any drop in oil level, and the engine doesn't use oil between changes (~ yearly and 50 hours). The commonly accepted explanation is that the vertical shaft engines will draw a drop or two of oil into the cylinder on shutdown, depending on where the piston stops in the bore. I can buy that and it seems to fit with my experiences.
The other possibility is overfilling the crankcase oil. Then it will smoke on every startup and MAY smoke while running until it burns it down to a useable level. Since it's new, the dealer may have slightly overfilled during prep. For reference, there's about 8 oz between FULL and ADD, so it can get pretty low before you need to worry. There's 64 oz in a full oil change.
I'd give it a few more hours to break-in then revisit the issue. Check the oil level regularly to make sure there isn't a major problem lurking under the hood.
HTH,
Paul
__________________
L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline   Reply With Quote Quick reply to this message
Old 06-30-2013, 10:19 AM   post #8 of 9
CitizenCS
JD 112, 37A snowblower
CitizenCS's Avatar
MTF Member # 19642
Images: 2
I have a new one with a few hours on it. It did start some smoke at start up but I am not too concerned.
One bonus on buying a new one... My wife has mowed the last two weeks!
__________________
past JD rides: 4020,3020,4430,8640
CitizenCS is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-01-2013, 02:01 AM   post #9 of 9
forum009
Senior MTF Member
MTF Member # 82054
Forgot to mention. When my X320 was new, it was hard to start, and it smokes in cold start. I was a little concerned but didn't do anything about it. Now, it starts cold and hot smokeless, hot start is instantaneous, cold start takes about 1-2 sec. I know we have different engines, but I think breaking-in is the key.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
