John Deere 345 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-12-2013, 02:52 PM   post #1 of 11
JohnDeere345
MTF Member
MTF Member # 86777
Images: 3
Default John Deere 345
Hello, I've had my 2000 JD 345 for a little over a year now and its been the best one I have. I use it commercially for my lawn care business. Every time I use it before I shut it down I idle it for about 1 min. Sometimes I might have to get off and open my garage door or something and when I start it back up it surges for about 20 seconds. I was wondering if I should worry about it or if it's just a regular thing for the 345's.
JohnDeere345 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-12-2013, 03:09 PM   post #2 of 11
ajcan
Senior MTF Member
ajcan's Avatar
MTF Member # 39156
Default Re: John Deere 345
I don't know what is normal but I will say my GX345 does not like idling once it gets warmed up.
If I use it and bring it down to idle it spits and sputters.Does not stall but does not idle well at all.
Once I throttle it back up it does fine and will mow till the cows come home,but once idled back down the same thing happens.
Normal?Not sure but mine does too.
AJ
ajcan is online now   Reply With Quote Quick reply to this message
Old 06-12-2013, 03:45 PM   post #3 of 11
jim335
Senior MTF Member
MTF Member # 45576
Images: 1
Your not supposed to let those idle very long, maybe a few seconds before you shut it off, but that's it.
__________________
2004 GX335, 48C mower, powerflow 7 bu. bagger, 42 snowthrower, 30 mech. tiller, 48 blade, 80 dump cart.
jim335 is online now   Reply With Quote Quick reply to this message
Old 06-12-2013, 04:11 PM   post #4 of 11
JohnDeere345
MTF Member
MTF Member # 86777
Images: 3
AJ
Exact same for me also.
Old 06-12-2013, 04:53 PM   post #5 of 11
PEIDeerefan
Proud Member of the 1K Club
PEIDeerefan's Avatar
MTF Member # 18351
Images: 2
My 02 GX345 idles fine but when I bought it 2 years ago it did not like going up to full throttle quickly so, had to push lever up very slow. I saw some threads about adding Seafoam so I have used it with much success.
__________________
2011 John Deere X530 with 48 inch deck
44 inch snowblower, chains, 4 suitcase weights
OTC Cab and winter grill cover
2002 John Deere GX345 with 48 inch deck
48 inch John Deere snow blade, 4 suitcase weights and rear tire chains
Power flow bagger
John Deere #80 cart
40 inch Brinly plug aerator
48 inch Brinly lawn roller
PEIDeerefan is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 06:16 PM   post #6 of 11
mitch 1952
MTF Junior Poster
MTF Member # 48725
I have a 2000 345(48c deck) also great mower, 602 hrs. haven't noticed any surgeing at idle, I run non etho gas and add seafoam every often so, 345 likes it and i feel better. had to replace two valve cover gaskets' the old ones crack and engine oil drips down onto the muffler headers, smokey situation replaced them with better updated ones good to go. other issues throws 3 inches of grass up on the front of deck around the belt pullys doesn't seem bother, just annoying, i blow it off after every mow. just got done mowing got to go blow the deck off put johnny away.
mitch 1952 is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 06:27 PM   post #7 of 11
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
I have a 345 and an X500 with Kawasaki engines, and I had an X485 with a Kawasaki before that. They all seem to fumfer around at idle when hot. None of them are what I'd call steady idlers when hot, but if I let them sit for a few moments they seem to steady out. So I am calling it normal. I run Seafoam in all of my machines.
Harryc is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 06:42 PM   post #8 of 11
mikestoy
2000 Posts and climbing!!!
mikestoy's Avatar
MTF Member # 38920
See........both these shouldn't have happen and it's complete BS on a expensive tractor like this.
Come on JD, get your act together.
__________________
Mike
My 2011 X720 Tractor: "The spirit of a race horse....but the body and pulling power of Clydesdale."
2011 X720 54c" mower deck/ 47" snow thrower / 2 bag vacuum System....SWEET
Other Toys:
2003 Candy Red Honda Goldwing Touring Cycle ......SWEET
2009 18' Lund w/200 hp Boat
2012 Black Lexus RX 350
Married for 47 years.
1 adopted son, married and lives in Charlotte N.C.
mikestoy is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 08:30 PM   post #9 of 11
JohnDeere345
MTF Member
MTF Member # 86777
Images: 3
Haha I also put seafoam in it also but last can of gas I put some injector cleaner and it runs better. Mitch, I have the same mower and same problem with the oil thing also, I haven't had to change anything YET lets make it stay that way.
Old 06-12-2013, 08:52 PM   post #10 of 11
FD611V
MTF Member # 12772
From reading your comments, it appears you have a governor issue when you reduce the throttle down to idle speed and it sputters. Idling don't hurt any type of combustion engine. Pay no attention to those that say otherwise. Small combustion engines such as chain saws, outboards, lawn mowers, and lawn tractors runs very well at idle, and for many (hours) without any problems.
FD611V is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-12-2013, 09:08 PM   post #11 of 11
mikestoy
mikestoy's Avatar
MTF Member # 38920
Quote:
I thought so to until I had a X540.
You couldn't idle that engine to save your soul when moving the throttle down to fast.
After putting up with that for a year, in came a X720 with fuel injection into my life..............
I remember the salesmen telling me on that X540, our great uncle sam doesn't what us to idle those engines.
BTW.......I power troll when fishing with my boat, so a engine that doesn't idle is no option...........
__________________
Mike
Other Toys:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
