Argh! Blade changing woes on z425... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-01-2013, 11:29 PM   post #1 of 21
littletractorguy
The Mod from... Nowhere!
littletractorguy's Avatar
MTF Member # 36339
Images: 6
Garage
Default Argh! Blade changing woes on z425...
So today Kidlet #2 and I went out to give my dad a hand with his EZTrak Z425... Last season, one of his workers skimmed a cindercrete block with the center mower blade, and for some strange reason it hasn't mowed right since then... Leaves a strip of poor cut around the centre of the deck... MIGHT have something to do with THIS:
(I DID check the center spindle last season for any damage/out-of-alignment, it was fine... They were LUCKY!)
So our job today was to change out the three blades (might as well do all three, since they're only $18 a piece). Nothing says father-daughter togetherness like a JD zero-turn!
So got out there, FINALLY located my dad's 1/2 drive sockets, popped the 3/4" on the impact wrench... geez, it doesn't fit.. Too loose... So it must be 11/16, right? Nooooooo.... So I went through his entire bin-o-random sockets (metric and imperial) and tried every one I could find... The only size I COULDN'T find was 18mm... Couldn't find a socket, nor could I find an 18mm box end.
Guess what size the interweb tells me those bolts are!
If you said 18mm, you win a PRIZE!
So... is 18mm some oddball size that it doesn't get included in any of the socket sets I've got access to? I've even checked online, and all the sets I've seen skip from 17mm to 19mm! ARRGH!
(I finally broke down and used the 3/4", but now I figure I'll need to buy replacement bolts AND an 18mm impact socket... Cuz all three have nice rounded edges now).
littletractorguy is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2013, 11:36 PM   post #2 of 21
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
Default Re: Argh! Blade changing woes on z425...
LTG...you have Princess Auto up there right? (Regina and Saskatoon)
http://www.princessauto.com/pal/en/I...cket/3410944.p
Harryc is offline   Reply With Quote Quick reply to this message
Old 06-01-2013, 11:48 PM   post #3 of 21
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Cheap enough price and the deck maybe Canadian!LOL
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 06-01-2013, 11:53 PM   post #4 of 21
littletractorguy
MTF Member # 36339
Images: 6
Garage
Of course, the woes didn't stop there... We got the deck all back on and hooked up, but I was in a rush to get mowing and didn't TASTE the gas in the gas can before pouring it in... Filled the tank right up, then it occurred to me, I'd never checked with my dad WHICH of his 7 different RED gas cans I should use... Smelled the tank... Hmmmmmmmmmmm... NOT that nice tangy gas-like smell I'm used to...
Some of you may remember my experiences LAST summer when I grabbed a random red gas can and wound up hiking all the way back to civilization to get a siphon and the can when the z425 decided it didn't like diesel so much...
I thought he said he was gonna start putting his diesel in those YELLOW cans he's got! At least I or Kidlet didn't get out into the middle of nowhere and find this out. So, JUST to be sure, we hiked to the gas station, filled an empty can, and LABELLED it...
Off we went to mow... ONCE we got it started (the battery froze over the winter apparently, so my dad left his booster for us to use)... Checked Kidlet #2 out on zero-turning (it isn't really that hard!) and took her out to the starter-pasture for some supervised mowing... She mowed a swath up and back, then, as I watched, she shut down the PTO and-
SWISH-off came the mower belt!
CRUD! By the time I got over there I could see the shreds of belt hanging off the mower... In too much of a rush to get the mower back on, I never checked our belt routing. I was loosening the idler pulley while Kidlet #2 was putting the belt around the PTO. Neither of us noticed the belt was routed UNDER a crossframe piece instead of OVER it...
Guess I pick up a new belt on Monday when I go get the 18mm socket and replacement bolts... Anybody know what the serial number range of the Briggs and Stratton-powered Z425 is? I notice that they have two belts listed, one for pre 100,000, one for post-100,000... I'm thinking post-100,000.
Old 06-01-2013, 11:58 PM   post #5 of 21
littletractorguy
MTF Member # 36339
Images: 6
Garage
Is on my list to get to tomorrow... I just don't understand why 18 wouldn't just be IN any set you buy... Like all the sets I've bought or my dad has...
Quote:
Apparently, its "international" phooey! None of OUR lumberjacks use 18mm ANYTHING!
Old 06-02-2013, 08:02 AM   post #6 of 21
Displaced Hokie
Senior MTF Member
MTF Member # 84156
Lots of socket sets skip 18mm to keep the set cost down.
Sent from the MTF Free App
Displaced Hokie is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 10:32 PM   post #7 of 21
KhellendrosXS
Tinkerer
KhellendrosXS's Avatar
MTF Member # 78929
I had to buy an 18 MM socket to work on my car since the socket sets I got for Christmas eons ago did not come with one. I share in your frustration!
__________________
1994 320
KhellendrosXS is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 11:49 PM   post #8 of 21
John Deere 240
Mowing Green MTF Member
John Deere 240's Avatar
MTF Member # 64018
Garage
Good to know about the 18MM socket! If my set doesn't have one i'll have to buy it. The Z425 is a great mower! Hopefully I get many years out of it. Thanks littletractorguy!
__________________
John Deere 240
Carlisle All Trail Tires
Freshly repainted and welded 46" Deck
48" Snow Blade
Kawasaki FC420V 14 horse engine
2012 John Deere Z425
23 horse Briggs & Stratton Engine
48" Edge Deck with EZ Track grass groomer striping kit
1940's Briggs and Stratton BR 6
Stihl FS 90 R Weedwacker
Stihl BR 600 Magnum Leafblower
Stihl BG55 Leafblower
Echo GT200r Weedwacker
Poulan Pro PP330 Weedwacker
Metal Garden Trailer
John Deere 240 is offline   Reply With Quote Quick reply to this message
Old 06-04-2013, 12:30 AM   post #9 of 21
littletractorguy
MTF Member # 36339
Images: 6
Garage
Well, funny story about that, you two... Well, actually, its kind of a sucky story... So I went out yesterday on a quest for an 18mm 1/2" drive impact socket... Stopped at Peavy Mart hardware... Nada. So, I went to Princess Auto. Well their impact sockets weren't WITH their regular sockets so I wandered over to air tools... And the helpful guy said
"Sure, they're right over here! Did you want a set or a single?" I said
" I want an 18mm 1/2" drive single socket.". HE said... " Ohhh... I don't think we SELL those in singles, you'll have to buy a set".
I said, "Your website says you sell singles, I don't want to pay big dollars to buy all those other sizes I don't want, and I didn't FIND the 18mm in any of the sets on your website".
"Oh, well, we don't HAVE any single 18mm sockets."
"You got a web browser on that computer over there?"
"Sure..."
And there it was, large as life, on their web site, for $2.99...
"Oh.." he says, "let me check our inventory".
click, click click...
"Ya, that socket was discontinued in February. We don't have any. They have some in Lethbridge, did you want me to get them to ship you one?"
"WHAT?!? WHY is it still on your website then, saying its in stock?"
"Well, funny thing with our website, until the inventory is gone across country, stuff stays up there. When did you need it by?"
"Yesterday, at 1:00. Never mind, I'll go find one somewhere else."
So, after an abortive trip to Costco, we stopped at Canadian Tire, and I found their LAST 1/2" drive 18mm socket.... 9 bux and change.
Old 06-04-2013, 12:48 AM   post #10 of 21
littletractorguy
MTF Member # 36339
Images: 6
Garage
So TODAY, I went back out to replace the belt on the z425...
$93 later, I have a spiffy new belt to stick on... Its the one on the right.
I have to say, I REALLY like the little "speed clips" on the mount points..
AND how the front draft bar works... That's very slick.
So, here's the newly routed belt...
Took me a bit longer to get things adjusted right (after I replaced the battery so that I could start it up and test). First thing I learned is that they aren't kidding in the manual about making sure that the belt guide "C" (that gold thingy in upper right of the deck) is properly lined up... Mowed one stripe, smelled burning belt, found a bunch of belt bits piled up on that guide. It must vibrate some, because at first glance it looked like it was passing through... Back out to mow some more, STILL smell burning belt... Hmmm Back to the gate, check the guide, it seems clean... Check/adjust the other belt guide to make sure its sitting in the indented hole.. Yup (after 20 minutes of futzing)... One more run, STILL belt burning smell... NOT good... I can see $93 going up in smoke, so back to the gate, REALLY carefully look things over... Hmm... belt seems AWFULLY close to the idler tensioner spring... In fact, there's a shiny spot on it... AND a burnt stripe on the underside of the belt! DOH! SOMETHING must be out of alignment... Pull the belt off the PTO, practice wedging my socket extension in between the idler arm and the center spindle pulley (as per the advice in the manual) to relieve the belt tension so I can take it off and put it on the pto... Pull off both belt guards, again... flip the spring the other way around... Can't see ANYTHING out of alignment... But its still too close to the spring. Well WTH... Its like the deck is coming up too high or something... So, I go and look at the deck height adjust lever to see if something is wonky-WAITAMINIT... Its not resting on the big deck height pin (which we always leave at 4", because we're mowing pastures), its above it... I'd left it in the transport position!... Drop it down to the 4" pin, take it for a spin, it mows like a dream!
Oh, and I used my new 18mm socket and my clicky torque wrench to make sure my spiffy new blades were torqued to 50 foot-pounds... It may be a metric socket, but I can't think in newtons per centimeter...
Old 06-04-2013, 01:02 AM   post #11 of 21
moondawg
Senior MTF Member
MTF Member # 44543
While we're on the subject, go look in your Allen wrench collection for that 7mm hex that you need to change the rear brakes on my old VW. Go ahead, I'll wait.
Nope, not included in all but the largest sets!
moondawg is offline   Reply With Quote Quick reply to this message
Old 06-04-2013, 01:07 AM   post #12 of 21
mrbeef
5000 Strong & Climbing
mrbeef's Avatar
MTF Member # 75839
Garage
Don't you love how those small tasks turn into huge jobs and how what you think are simple tools dont exisit!
Glad you got it going again
__________________
A Wonderful Wife that puts up with me, two cats and the dog, and a BAD case of round fenderitis
Tractors:
07' JD X748
88' JD 318 "The Golden Child"
83' JD 214
The Round Fenders: 67' JD 112H, 67' JD 110H "The Frog", 66' JD 110, 65' JD 110, 64' JD 110
In Parts: 65' JD 110, 66' 110H
Former Machines:
60's Power King, 65' JD 110, 66' JD 60, 69' JD 112, 69' JD 140H3, 72' 140 H1, 77' JD 212, 80' JD 317, 80' JD 317, 80' JD 317, 83' JD 318, 84' 420, 86' JD 318, 86' JD 420, 87' JD 430, 87' JD 318, 88' JD 318, 88' JD 318, 88' JD 855, 89' JD 318, 91' JD 430, uk Cab Cadet 2140, 92' JD 320, 93' JD 320, and 01' LX277
mrbeef is offline   Reply With Quote Quick reply to this message
Old 06-04-2013, 01:10 AM   post #13 of 21
QAFarm
3K Poster!!!!
QAFarm's Avatar
MTF Member # 83194
Da** you. You know I had to get off my a** go out to the shop and look and yep your right.
__________________
1981 john deere 317. 1986 John Deere 318
1964 International B414. 69 John Deere 112H SF 1982 John Deere 400
10 s cart
26T John Deere sweeper
Model 50 cart
1969 Patio model 80 cart
1982 John deere 80 cart
1976 John Deere 80 cart
Former equipment. 1979 JD 216 so others can live.
1999 Scott's 46 inch cut
1972 simplicity 3415H w/tiller
1977 JD 214
QAFarm is offline   Reply With Quote Quick reply to this message
Old 06-04-2013, 01:12 AM   post #14 of 21
QAFarm
3K Poster!!!!
QAFarm's Avatar
MTF Member # 83194
And apparently now I have to go buy an 18mm socket because there is a worldwide shortage
__________________
10 s cart
Model 50 cart
1977 JD 214
Sponsored Links
Advertisement
Old 06-04-2013, 01:15 AM   post #15 of 21
littletractorguy
MTF Member # 36339
Images: 6
Garage
Quote:
Once that z425 is no more, I'll be auctioning MY 18mm off on eBay... If you can wait 10, 15 years, I'll let you have it for a reasonable Buy-It-Now price!
(seriously, I'm keeping that 18mm socket at MY house, 'cuz I KNOW if I let my dad have it, we'll be lost next season when I go to change the blades)
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
