Simplicity coronet pto clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-28-2013, 05:11 PM   post #1 of 10
WooodyII2
MTF Member
MTF Member # 30527
Default Simplicity coronet pto clutch
Hello,
Currently I am working on a Simplicity Coronet 12 Hydro that I got for free as it was not working. The pto switch was busted so I replaced it with the PTO Kit due to update. I got the machine running and was very happy but when I engage the pto for blade operation nothing happens. All the wires looked fine so I crawled underneath and removed the electric pto. I have no experience with electric pto's so I am not quite sure what I am looking for except I thought someone said there should be some sort of liner on the disc but I see nothing. Is this correct? Here is a picture of it.
Any info will be much appreciated.
Thanks
Name:	2013-05-28 15.04.14.jpg
WooodyII2 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-29-2013, 09:05 AM   post #2 of 10
mowman1
Senior MTF Member
MTF Member # 59877
Default Re: Simplicity coronet pto clutch
I would put the clutch back together and back on the rider. do not connect the wires to the clutch. Next take 2 pices of wire and put one on each post of the battery and then touch one to each of the terminals on the clutch. If the clutch is good you should hear it snap in. If it does snap in when you touch and release the wires then the clutch should be ok and that would mean there is a problem with the wiring.
mowman1 is offline   Reply With Quote Quick reply to this message
Old 05-29-2013, 09:12 AM   post #3 of 10
WooodyII2
MTF Member
MTF Member # 30527
Thanks, I will try that today
Old 05-29-2013, 09:41 AM   post #4 of 10
WooodyII2
MTF Member
MTF Member # 30527
Well......
I did as you said and no click, no nothin. The battery is good so I know thats good. So these clutches look a bit pricey. Anyone no of a good place to get one? New or used?
Thanks guys
Old 05-29-2013, 12:39 PM   post #5 of 10
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
You could use a multimeter and check for continuity through the clutch windings. The PTOs are pretty pricey, so I'd make really sure this one was bad before buying another. Since you can get at the windings, you may be able to find a break in the wiring - probably near the terminals. What do you have to lose at this point?
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 05-31-2013, 03:17 PM   post #6 of 10
showags
MTF Junior Poster
MTF Member # 78803
Not familiar with that particular clutch but can you verify if the armature (moveable disc) is free on whatever it slides on? In other words, if there was a magnetic force, is it physicall possible for the two discs to meet? Assuming it can freely move (big assumption = see my post on Conquest Clutch) it is still dependant on a magnetic force (windings, lead, etc. good) and the distance between the moveable and stationaly (vertically) disc. On the conquest, the coil needed to ohm out between 2.5 and 3.0 ohms if I recall (reference my other post). Mine actually ohm'd out at 3.4 but works just fine. You are really looking to make sure it is no 0 or .something ohms(short) or open lead or exponentially higher resistance (open). Check by putting leads in clutch end plug and verfy at coil connection point if possible (vett out wiring connections). Check to make sure there is a 0.012-0.015" spacing between discs at rest.
On my, all of this checked out but it was the visual/physical observation of a stuck armature that solved the issue.
showags is offline   Reply With Quote Quick reply to this message
Old 06-19-2013, 08:58 AM   post #7 of 10
WooodyII2
MTF Member
MTF Member # 30527
I will give it another look today. Thanks for the info. Been on vaction so back to the grind
Old 06-19-2013, 10:03 AM   post #8 of 10
shamrockjack
Proud Member of the 1K Club
MTF Member # 37787
check on Ebay for a used clutch
shamrockjack is offline   Reply With Quote Quick reply to this message
Old 06-19-2013, 10:43 PM   post #9 of 10
sammiefish
MTF Member
sammiefish's Avatar
MTF Member # 35435
I know you said your battery is good ... but ...
on my coronet (9 manual)... if the voltage is low (good enough to start but maybe not good full charge) the pto wont engage..
maybe even just a connection problem not providing enough juice
__________________
AC 3/400's
sammiefish is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-13-2013, 01:20 PM   post #10 of 10
WooodyII2
MTF Member
MTF Member # 30527
Finally fixed. I got a clutch from a junker coronet 13 and installed it. And now all is right the world. Thanks everyone for the help
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
