testing the coil / shut off switch on 10301 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 09-27-2006, 08:12 PM   post #1 of 14
scale21
Senior MTF Member
scale21's Avatar
MTF Member # 3513
Default testing the coil / shut off switch on 10301
I cant seem to get spark. I know i seen spark jump once or twice.
I have a clamp holding the handle down so it should be in the start position.......and i run a small cordless drill with a driver on the fly wheel to spin the engine with the plug out. (works well)....
Anyway i suspect either the shut off switch unit or the coil.
Is there any way to test either? I have a volt / ohm meter that i can put on the coil but not sure if i want volts or ohms or what the **** setting to put the tester on to get a proper reading. ....or where to put the leads for that matter.
Also...how does the switch assembly work. THe cable pulls the brake arm but thats all i see. There has to be more to it than that....
scale21 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-27-2006, 09:03 PM   post #2 of 14
Jason
Lawn Mower Fan
Jason's Avatar
MTF Member # 2433
Default Re: testing the coil / shut off switch on 10301
The switch is probably a NO switch, or Normally Open. Meaning, when the bail is released, the switch opens, probably breaking connectivity in the ignition system. I may be speaking out of turn as I don't know the particulars of the Lawn-Boy ignition system, but in general, that's how most of the compliance brake systems work.
You should be able to use your ohm meter to test the switch. With the bail tied down (as you would operate it), I would expect the switch to be CLOSED, or showing ZERO resistance. If it shows a high or infinite resistance, the switch may be faulty.
But frankly, given the seemingly common problem of failing coils on L-B 2-cycle engines, I would think the coil would be a great place to start. It may be bad inside, not allowing spark to properly build inside. This could result in a weak spark or no spark. If it only shows a weak spark, and intermittently, I would suspect the coil.
__________________
Cheers,
Jason
'87 Lawn-Boy Supreme 8157
'95 Lawn-Boy Silver 10301
'96 Lawn-Boy Gold 10523
'99 Lawn-Boy Silver 10330
'01 Honda Masters HR215SXA
Jason is offline   Reply With Quote Quick reply to this message
Old 09-27-2006, 09:23 PM   post #3 of 14
scale21
Senior MTF Member
scale21's Avatar
MTF Member # 3513
where do i put the leads for my tester? And what ohm setting? There is alot of them
Old 09-27-2006, 11:05 PM   post #4 of 14
Walt 2002
Senior MTF Poster
MTF Member # 1229
LBs since the early D600s have a Kill switch. Releasing the handle bail closes the switch shorting out the ignition. To check, simply unplug the kill wire.
Walt Conner
Walt 2002 is online now   Reply With Quote Quick reply to this message
Old 09-27-2006, 11:28 PM   post #5 of 14
scale21
Senior MTF Member
scale21's Avatar
MTF Member # 3513
the kill wire is the one that comes off the bottom of the coil........?? if thats the case and i i still get no spark...can i assume it is bad??
Old 09-28-2006, 09:22 AM   post #6 of 14
Jason
Lawn Mower Fan
Jason's Avatar
MTF Member # 2433
Walt is correct -- I had it backwards. The switch is NC or Normally Closed. When you release the bail, the switch closes and basically grounds the coil to the block (no spark).
The "kill wire" is the small gauge wire that runs from the coil to the switch. If you unplug that wire from the switch, you're effectively taking the switch out of the equation. If you still get no spark, you can pretty safely assume it's the coil (that's bad).
__________________
Cheers,
Jason
Old 09-28-2006, 10:49 AM   post #7 of 14
Walt 2002
Senior MTF Poster
MTF Member # 1229
These coil, like most LB CDI Units, have a high failure rate. I don't THINK these coils are available aftermarket, may cost close to $40.
Walt Conner
Old 09-28-2006, 11:11 AM   post #8 of 14
johnsonmk
johnsonmk's Avatar
MTF Member # 2392
Quote:
Originally Posted by scale21
I cant seem to get spark. I know i seen spark jump once or twice. I have a clamp holding the handle down so it should be in the start position.......and i run a small cordless drill with a driver on the fly wheel to spin the engine with the plug out. (works well)....
As I recall, that coil is grounded to run so...
when you pull the bail back you make the connection.
(that small black wire from the coil).
They sell spark testers for $12.50. I may even get one for myself.
__________________
Mike
johnsonmk is offline   Reply With Quote Quick reply to this message
Old 09-28-2006, 01:56 PM   post #9 of 14
Walt 2002
Senior MTF Poster
MTF Member # 1229
Don't think so, you pull the bail back to BREAK connection, see above posts.
Walt Conner
Old 09-28-2006, 02:06 PM   post #10 of 14
Jason
Lawn Mower Fan
Jason's Avatar
MTF Member # 2433
When the bail is pulled back, the switch is OPEN, which sends electricity to the spark plug. When the bail is released, the switch CLOSES, which provides a direct ground to the coil, and electricity no longer "flows" to the spark plug, killing the engine.
__________________
Cheers,
Jason
Old 09-28-2006, 02:23 PM   post #11 of 14
johnsonmk
johnsonmk's Avatar
MTF Member # 2392
Quote:
Walt Conner
I bow to your greater knowledge.
Also, it's raining and I don't want to go look.
__________________
Mike
Old 09-29-2006, 12:37 AM   post #12 of 14
scale21
Senior MTF Member
scale21's Avatar
MTF Member # 3513
just scored another 10301 so i can test the new mower coil on the other unit and see what happens....
Lucky me
Old 09-29-2006, 12:51 AM   post #13 of 14
johnsonmk
johnsonmk's Avatar
MTF Member # 2392
just scored another 10301 so i can test the new mower coil on the other unit and see what happens... Lucky me
hehehe...You are hooked so bad... hehehe
__________________
Mike
Sponsored Links
Advertisement
Old 09-29-2006, 12:53 AM   post #14 of 14
scale21
Senior MTF Member
scale21's Avatar
MTF Member # 3513
ya no kidding.....cripes........there is somthing about that green though....
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
