Homemade back blade. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-11-2013, 10:27 PM   post #1 of 13
JDfreak2012
Senior MTF Member
JDfreak2012's Avatar
MTF Member # 69816
Images: 8
Garage
Default Homemade back blade.
I made a back blade from an old Gilson front blade and a cheap engine stand. The engine stand has a natural swivel point to adjust blade angle. A hole for the hiych pin, weld it to the blade and viola! In the pics you'll see the sleeve hitch I made for my old 112 mounted to my X500. 2 bolt holes drilled into the side of the rear frame plate and it fit right on!
JDfreak2012 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-11-2013, 10:34 PM   post #2 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Default Re: Homemade back blade.
Here's a pic of the homemade sleeve hitch.
Old 05-11-2013, 10:37 PM   post #3 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Here's the first revision. The blades a little far away from the tractor so I'm gonna shorten it up.
Old 05-11-2013, 10:40 PM   post #4 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Here it is all shortened up. I reinforced the joint with a plate on the side.
Old 05-11-2013, 10:42 PM   post #5 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Primed it all to prep for green/yellow topcoat.
Old 05-11-2013, 11:03 PM   post #6 of 13
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Looks like you did a fine job!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 05-11-2013, 11:27 PM   post #7 of 13
rbick1
Senior MTF Member
rbick1's Avatar
MTF Member # 33806
now why didn't I think of that! excellent idea, I see those engine stands cheap all the time.
__________________
tractors: 74-446, 78-224, 78-446, 79-446, 81-224, 83-444, 84-226, 86-222, 92-3118
decks: M-46, J-45 or J-46, 46 in, and 3 more 48 in
blowers: L84, L80, J80
blades: L50, homemade 48 inch v-plow
http://www.youtube.com/user/TheRBNetwork
rbick1 is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 11:39 PM   post #8 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
I mounted the DPDT switch on the right rear fender. I thought about putting it on the dash but your always turned around to watch the implement when raising and lowering.
Old 05-12-2013, 12:27 AM   post #9 of 13
ericstromberg
Senior MTF Member
MTF Member # 34891
Nice. There's an old Montgomery Wards (Gilson) blade at my dad's, I may have do something like this...
Sent from the MTF Free App
ericstromberg is offline   Reply With Quote Quick reply to this message
Old 05-12-2013, 01:11 AM   post #10 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Yeah the Gilson/Montgomery Ward blades are heavy enough to weld to. Not like the Craftsman blades. Hardest part was cutting off the original mounting system off of the blade. I may remove the large height adjustment shoes before I'm done. I built this to use when I have the snowblower hooked up so I can back drag away from garage doors. I want to get as close to the door as possible. Kinda like a backhoe scraping dirt off of a block wall.
Old 05-12-2013, 01:19 AM   post #11 of 13
KWDAILYD
8K poster and enjoying it
KWDAILYD's Avatar
Will it swivel 180 deg. so you can also push with it?
__________________
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 6 JD suitcase weights. 2-50# cast rear wheel weights.
Thread for 110 RF build http://www.mytractorforum.com/showthread.php?t=287161
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is offline   Reply With Quote Quick reply to this message
Old 05-12-2013, 01:34 AM   post #12 of 13
JDfreak2012
Senior MTF Member
MTF Member # 69816
Images: 8
Garage
Yes, you just let it drop, spin it around, and you can push. Angle has 6 positions forward or back.
Sponsored Links
Advertisement
Old 05-12-2013, 09:22 AM   post #13 of 13
04zrx
Senior MTF Member
04zrx's Avatar
MTF Member # 96729
nice job, I love to see pictures of home made attachments, it gives me ideas.
__________________
1984 John Deere 420 (sold)
home made 3 pt.receiver hitch
2002 X585 with 45 FEL and 54C deck
extended weight bracket (8)
04zrx is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
