Clutch replacement on 124 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-10-2013, 03:02 PM   post #1 of 9
John Garrison
Senior MTF Member
John Garrison's Avatar
MTF Member # 76588
Default Clutch replacement on 124
I am in the process of replacing the clutch on my 124 and I've hit a snag. While trying to slide the engine back I got upset and just yanked the engine out and put it on the ground and now I'm thinking I shouldn't have. It wouldn't slide back because debris on the framerail prevented it from moving but now how am I suppose to remove the spiral pins on the clutch? The driveshaft just flops around and is no longer being held in place by the engine so I'm not sure if I need to punch out the pins with the engine on or can it be done while off? It's just held being up by the release lever.
John Garrison is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-10-2013, 07:36 PM   post #2 of 9
John Garrison
Senior MTF Member
MTF Member # 76588
Default Re: Clutch replacement on 124
I just thought I'd mention something funny but annoying at the same time. I went to town and checked a few stores for spiral pins(coiled spring pins) and then got home and spent over an hour online searching for one single pin. Suddenly it dawned on me that there is a Fastenal about 10 miles away in the next town.
Old 05-10-2013, 10:57 PM   post #3 of 9
vartz04
Senior MTF Member
MTF Member # 14382
You need to split the tractor and put a jackstand under the driveshaft and then drive the pins out with a roll pin punch. Took me a week of penetrating oil to get them out of my 104.
Good luck doing it without pulling the rear end away from the frame. If you run into a snag post back or pm me and ill give you a hand. Also its cheaper to buy a whole new assembly from a guy named mark hellrung only $175 plus shipping. Ill post the link when i get home if you're interested
Sent from the MTF Free App
__________________
John Deere 300 with 46 mower and 54 4-way blade.
vartz04 is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 11:30 AM   post #4 of 9
John Garrison
Senior MTF Member
MTF Member # 76588
Thanks for your advice but I wasn't getting any immediate reactions to my answer so I just did it my own way last night. I was aware of needing a roll pin punch but being that I have every size roll pin punch EXCEPT the 1/4" one I needed I ended up making my own. I used a 1/4" punch and ground a little centering nipple into the end of it with my bench grinder. I didn't get a response right away to the question of whether or not I needed to support the end of the driveshaft that goes into the pilot bearing so I made my own support. I took a piece of an old wooden 4x4 I had laying around, sawed it to 18" in height, drilled a hole in the side of board to support the driveshaft end, heated the shaft around the pins and drove them out. I had to heat, punch it, and heat it again a few times but I was able to drive both pins out in about 5 minutes. To reduce the amount of pounding needed to drive out the length of pin and to prevent the end I pounded on from mushrooming, I used a portable chopsaw to cut the pins flush with the driveshaft before beating them out. This was not the nightmare job I've heard about from many owners but I can assure you, those pins were really fused in there. A good BFH and a few many swings later and problem solved.
Old 05-11-2013, 11:39 AM   post #5 of 9
vartz04
Senior MTF Member
MTF Member # 14382
http://ihcubcadetparts.net46.net/
Get your new clutch and drive shaft from this guy. Top notch work
__________________
Old 05-12-2013, 07:57 PM   post #6 of 9
John Garrison
Senior MTF Member
MTF Member # 76588
Thanks but I already bought a clutch from my local Cub Cadet dealership and the driveshaft is in good shape.
Old 05-13-2013, 07:39 AM   post #7 of 9
vartz04
Senior MTF Member
MTF Member # 14382
Did you buy new springs, throw out bearing, pins ect. Usually at this point everything needs replacement. Also you should get the pressure plates turned in a lathe to true them up.
__________________
Old 05-13-2013, 04:28 PM   post #8 of 9
John Garrison
Senior MTF Member
MTF Member # 76588
Yep, all is set. I turned the plates myself and replaced everything necessary. I love how easy it is to work on these old Cub Cadets. Some people say it's a headache compared to other brands but they're garden tractors! Even the hardest ones to work on are still fun in my book and a lot easier than what I'm use to working on. Anyway, thanks for your time.
Sponsored Links
Advertisement
Old 05-13-2013, 09:24 PM   post #9 of 9
vartz04
Senior MTF Member
MTF Member # 14382
Good deal just wanted to help out since I just went through all the research replacing mine
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
