How much hp for a tow behind mower? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-01-2013, 04:27 PM   post #1 of 12
7sleeper
Senior MTF Member
MTF Member # 33172
Default How much hp for a tow behind mower?
How much hp would I need for a tow behind mower? I have a extra lawnmower engine at about 5 hp. Would it be possible to hook it up to a extra lawndeck 38-40 inch wide? Would it cut tall grass well?
I know many small 38-40 inch mowers have 10-15hp engines. But they have a extra load to pull(person, and the rest of the tractor). So would a small engine be a bare minimum?
I was looking at something like this.
http://www.mytractorforum.com/showthread.php?t=180722
or this
http://www.mytractorforum.com/showpo...59&postcount=7
Thanks for the feedback!
7
7sleeper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-01-2013, 05:04 PM   post #2 of 12
Loremaster72
Proud Member of the 1K Club
Loremaster72's Avatar
MTF Member # 25731
Default Re: How much hp for a tow behind mower?
I'd say you'll be a bit short of horsepower for cutting tall (field) grass at speed. An 8hp Gravely walk behind (all gear drive, minimal loss) can easily bog out on high grass with a 40" deck in high gear. In low gear with a 30" deck, they are pretty good. Remember that small mowers are typically used for mowing LAWNS, not high grass. Deck throughput clearing the grass end up sucking up a good bit of horsepower. I think that what you are proposing would probably work OK for lawn mowing, but will bog down in high grass.
__________________
Loremaster72
Mechanical Engineer, Book Collector, and Tractor Nut
Current Machines:
1979 Gravely 5265 Commercial
1990 Gravely 16G Professional
1973 Sears SS16 Twin
Loremaster72 is offline   Reply With Quote Quick reply to this message
Old 05-01-2013, 07:48 PM   post #3 of 12
rhenning
3K Poster!!!!
MTF Member # 4880
I have rebuilt my friends Haban 42 inch tow behind twice now. First time replaced the 8 HP Briggs (lost a valve seat) with an 11 HP Briggs engine that also last a valve seat. The second time went to a 13.5 HP Briggs OHV. More HP is better. 5 HP is for a 18 to 22 inch deck. Most tow behinds are much wider. Roger
rhenning is offline   Reply With Quote Quick reply to this message
Old 05-02-2013, 01:55 AM   post #4 of 12
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Minimum of 2 hp per foot of width for a manicured lawn. More for mulching or bagging.
Minimum of 4 hp per foot of width for tall grass.
As has been stated, more horses eat more grass!
You're a wee bit light in the horsepower department for that mower.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is offline   Reply With Quote Quick reply to this message
Old 05-02-2013, 07:49 AM   post #5 of 12
7sleeper
Senior MTF Member
MTF Member # 33172
Thanks for the feedback!!! Really good info here. Now I just have to find out how many inches are a foot....
Too bad, I was hoping for a nice project next winter. Well maybe I can hunt down another lawnmower engine => one engine per spindle!
7
Old 05-02-2013, 08:06 AM   post #6 of 12
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
This tractor is only 4 hp. I've mowed grass over the hood with no problem. I've pulled full size pickups with no problems.
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 05-02-2013, 10:31 AM   post #7 of 12
DonF
MTF Member # 53676
Yes you can use a 3 1/2 HP 20" or 22" push mower. I have mowed more then enough acres that way 60 years ago. It's how fast you want to mow. My guess is with a pull behind you want to cover a lot of area fast. I would say 10 to 12 HP minimum and more is better. As I remember it you went very slow in heavy grass and real heavy grass there was stop and back up to keep from killing the engine.
DonF is online now   Reply With Quote Quick reply to this message
Old 05-02-2013, 10:35 AM   post #8 of 12
CADplans
5000 Strong & Climbing
CADplans's Avatar
MTF Member # 66233
Quote:
I do not believe that mowing deck is OSHA approved!!
The new decks are so "safe", they require more HP.
CADplans is online now   Reply With Quote Quick reply to this message
Old 05-02-2013, 01:33 PM   post #9 of 12
TUDOR
MTF Member # 28463
As long as speed is not part of the equation, 1 hp could probably run that mower.
Any riding mower should have no problem pulling a full size pickup. after all, it only takes a pair of 10 year old kids to push one. Not a whole lot of horsepower involved there!
__________________
Bob
In Service
Down for Repairs
Old 05-07-2013, 09:03 PM   post #10 of 12
timflury
What happened?
timflury's Avatar
MTF Member # 33250
The 5hp tractor to your left runs a 28" deck, and a 27" snowblower.
Simplicity had a 6hp RER that ran a 32" deck.
The Simplicity 700 ran either a 36", OR the 42" deck with a 7hp 19D Briggs engine.
I would say that you might be working the 5hp engine a little hard if you end up cutting thick grass. You might find yourself with very slow ground speed if the engine is working too hard.
__________________
timflury is offline   Reply With Quote Quick reply to this message
Old 05-07-2013, 09:30 PM   post #11 of 12
john9001
Senior MTF Member
john9001's Avatar
MTF Member # 45837
Images: 1
60 inch three blade tow mower, 14.5 HP
john9001 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-08-2013, 08:51 PM   post #12 of 12
biker
biker's Avatar
MTF Member # 35905
The onew behind the Ford looks nice. I don't why you cant do what you want to do. All you can do is try it.
__________________
John Deere 750
Kubota B6200
Craftman GT5000
Building A Hydraulic Drive Homemade Tractor
Happy Wife Happy Life Sad Wife OOH No
Nothing But The Truth
biker is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
