Any reason I couldn't put bigger tires on X340? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-26-2013, 08:15 PM   post #1 of 11
JohnnyReb
Proud Member of the 1K Club
JohnnyReb's Avatar
MTF Member # 84763
Default Any reason I couldn't put bigger tires on X340?
After looking at some X500 series I really like the beefier tires and the knobby tread. Considering my X340 and the 500 are basically on the same frame and tractor body is there any reason why I couldn't go to a 24 inch back tire and up to the 16.5 on the front like the 500???
Now some will say why not just buy a 500 series. Well I don't really need the extra features and liquid cooled ect ect. Don't really need a heavier tranny either. But I do like the larger tires. Might be a little better for crossing a few rough spots on my property. And that knobby ATV like rear tire on them would be great for better traction up a slope I have on my land. I'm just wondering how it will effect my deck height. The tractor will set taller I would think so my deck setting will be off. I normally mow at 3 inches so I guess I could drop it to 2.75 to compensate??
__________________
2004 JOHN DEERE X485 62C
1983 JOHN DEERE 318
2000 JOHN DEERE GT235 "Old Faithful"
[/COLOR]
1953 IH FARMALL SUPER A
2002 HARLEY DAVIDSON WIDE GLIDE
JohnnyReb is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-26-2013, 08:19 PM   post #2 of 11
brokenbeak387
Senior MTF Member
MTF Member # 84676
Default Re: Any reason I couldn't put bigger tires on X340?
If you're lookin for better traction i'd go for an AG tire in the same size of the stock tire.
__________________
I said I work on em', I didn't say I fix em'.
brokenbeak387 is offline   Reply With Quote Quick reply to this message
Old 04-26-2013, 08:25 PM   post #3 of 11
robcfo
MTF Junior Poster
robcfo's Avatar
MTF Member # 85737
The only thing I can think of is that a lager tire will change the gearing and added weight can rob you of a little horse power - but if you have plenty to spear, go for it. I also like the bigger tire look.
robcfo is offline   Reply With Quote Quick reply to this message
Old 04-26-2013, 08:51 PM   post #4 of 11
JohnnyReb
JohnnyReb's Avatar
MTF Member # 84763
It's got the 25hp Kawasaki so power isn't a issue.
The rear is fine for now. There 22x11 I think. But I'd rather habe the 16.5 on the front. Would I notice the front being taller going from 15.5 to 16.5?? Don't wanna get everything out of whack
__________________
1983 JOHN DEERE 318
[/COLOR]
Old 04-26-2013, 09:42 PM   post #5 of 11
jdaws
Senior MTF Member
jdaws's Avatar
MTF Member # 42666
I don't know what transaxle you have, but I know they have a max tire size rating. This would be your limiting factor.
jdaws is offline   Reply With Quote Quick reply to this message
Old 04-26-2013, 09:48 PM   post #6 of 11
wizzo
MTF Tractor Nut
wizzo's Avatar
MTF Member # 32657
The transmission manufacturer lists the max tire size as 23" http://www.tufftorq.com/?page_id=141 for whatever that would mean to you. Not sure that you could tell the difference between a 22 and a 23" tire if you kept the same rims. There should be lots of ATV tires in both sizes. Will a 24" tire hurt the transmission, I doubt it... Send an email to Miller Tire, mention MTF and see what they can do for you.
__________________
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline   Reply With Quote Quick reply to this message
Old 04-26-2013, 10:04 PM   post #7 of 11
JohnnyReb
JohnnyReb's Avatar
MTF Member # 84763
It's a K58 tranny. Mowing and pulling a 2 wheel cart sometimes with a light load. I may just stay at 22 rear with a more aggressive tread. But I want to go to a 16 inch front tire like the 500s. Just not sure if it will affect the stance of the tractor. I don't want the front sitting up higher than the rear or having a " raked" stance
__________________
1983 JOHN DEERE 318
[/COLOR]
Old 04-26-2013, 10:11 PM   post #8 of 11
wizzo
MTF Tractor Nut
wizzo's Avatar
MTF Member # 32657
If you change one tire size or the other (front or rear) I'd still relevel the deck after you put the new tires on because the front and rear height of the deck are supposed to be different. I'm not sure most people would notice the difference in stance, maybe put the front of your X340 up on some 1/2" thick boards and see if it feels weird.
__________________
Old 04-28-2013, 12:45 AM   post #9 of 11
forum009
Senior MTF Member
MTF Member # 82054
I agree that you may be better served with changing to a more aggressive tires rather than upsizing it. Larger tires lowers the overall gear ratio, it increases speed but reduces torque. It increases stress on the hydro, and makes your brake less effective. You mention about going up a slope, not knowing how steep it is, your tractor will actually has less torque to tackle the hill even if you get better traction. I would not want to chance it with a K58. You weakest link is not your engine, but your hydro.
For the mower deck, you will need to re-level it as front vs. rear now has a half inch difference. You will also need to drop mowing height by 1 inch as your tractor is now a inch higher off the ground in the back, and 0.5 inch higher in the front.
Personally, lawn tractor is form follows function, I would not sacrifice durability and performance for look.
forum009 is offline   Reply With Quote Quick reply to this message
Old 04-28-2013, 12:58 PM   post #10 of 11
Onan18
2000 Posts and climbing!!!
Onan18's Avatar
MTF Member # 40653
Is there a hub kit that will fit on the K58 axle and allow you to use a bolt on rim like a 500 series? I would rather have bolt on rims for the convince of being able to service/change the tires.
Joe
Onan18 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-28-2013, 07:34 PM   post #11 of 11
Mach-1
Proud JD Owner
Mach-1's Avatar
MTF Member # 51303
Quote:
Joe
Hubs from a K66 would probably work. Both have axles that are 1" diameter.
__________________
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
2003 Poulan 1742 (not ultimate)
Mach-1 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
