Mower deck to low - can it be raise higher - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-12-2013, 05:30 PM   post #1 of 3
Pappy 1954
Senior MTF Member
Pappy 1954's Avatar
MTF Member # 63164
Default Mower deck to low - can it be raise higher
I have a used 281016be rer snapper riding mower with elec start, 10HP B&S engine.
The deck in on the the highest setting #6.
Has anyone tried to raise it so that it does not cut so short? Are there taller tires that can be put on to raise it?
__________________
Riding, Snapper, Rear Engine Mower
20 Year Old, Toro, Rear Bagger, Self Propelled
Pappy 1954 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-13-2013, 09:58 AM   post #2 of 3
pman777
Senior MTF Member
pman777's Avatar
MTF Member # 75226
Default Re: Mower deck to low - can it be raise higher
I have a series 13, 33" deck so we're likely different. I mow on the setting 5 or 6 and it does cut short. When I go to level 4 the deck wheels are always touching the ground.
If I'm not mistaken your deck's rear adjustment is with the chains (mine are cables with spacers) supporting the rear of your deck. At least that's how it appears in the parts manual. My mower has two pivot point settings on the front. I didn't see those 2 options in your parts manual but I can't say for sure. My mower is set on the higher of the two settings.
There are a number of threads on this subject and I don't recall ever reading a suitable answer. When my deck is adjusted to it's highest level, the edge of my deck is about 2" off the ground. The blade is about a half inch higher.
I believe other Snappers RERs differ. One might think the deck should raise higher but mine sure doesn't.
pman777 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-14-2013, 11:20 AM   post #3 of 3
pman777
Senior MTF Member
pman777's Avatar
MTF Member # 75226
Quote:
I forgot to address this issue.
Raising your deck will involve raising the front half of your deck. Putting larger tires on the front of your mower could cause those tires to rub when turning corners.
Another idea I was considering was taking an angle grinder and grinding out a notch where a notch number 7 would be. Then I'd have to find a number 7 decal. :-)
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
