Correct Engine RPM, set? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 07-19-2006, 10:31 AM   post #1 of 6
jerry_nj
2000 Posts and climbing!!!
jerry_nj's Avatar
MTF Member # 1077
Images: 1
Default Correct Engine RPM, set?
I have a Sears 6.5 B&S 22" push mower that I run in the mulch mode most of the time.
It came with an OEM mulch blade, single blade with extra cutting surface and curves. It works ok, but I think it may work better if the engine were at a higher RPM, engine sound is the usual loud, but not very high RPM. These come factory set and I don't think one can change the RPM without making up some kind of a kludge. As noted on another thread, I replaced the OEM blade with a Viper blade and the mulching is improved. I still wonder about the RPM, is there an inexpensive ignition pick-up tachometer good for lawn equipment anyone can recommend? Then if one has a tach, what is the correct RPM, I suppose it depends on the size of the blade, higher for a 20" than for a 22".http://www.mytractorforum.com/newthr...wthread&f=155#
Biglaugh
jerry_nj is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-19-2006, 11:11 AM   post #2 of 6
slipshod
slipshod's Avatar
MTF Member # 17
Images: 4
Default Re: Correct Engine RPM, set?
If it is mulching OK why do you want to run at higher RPM's?
__________________
slipshod is offline   Reply With Quote Quick reply to this message
Old 07-19-2006, 11:45 AM   post #3 of 6
jerry_nj
jerry_nj's Avatar
MTF Member # 1077
Images: 1
Good point, low RPM, better gas mileage I suppose. Still, I'd like the mower to run at the "design" RPM. My ear says it isn't, so a tach and spec would answer the question unambiguously. I suppose larger engines may run at lower RPM. 6.5 HP is the largest walkbehind (not power driven) engine I've ever had. Then too, I wear ear protection, to protect my already damaged hearing (horse it out of the barn) and that says I hear only part of the sound the engine makes. But, I think I do hear the "tempo" of the RPM.
Old 07-19-2006, 02:09 PM   post #4 of 6
DLF_IN
MTF Member # 1844
Jerry,
All push mowers have the engine speed set by the blade tip speed, not the top goverend speed . Somewhere, I have a chart that shows the maximum tip speed for all blades up to 30" . I got it from a Briggs field tech about 10 years ago. You can get a small tach called a Vibra Tach at most small engine shops.
Dave
DLF_IN is offline   Reply With Quote Quick reply to this message
Old 07-19-2006, 08:14 PM   post #5 of 6
Jason
Lawn Mower Fan
Jason's Avatar
MTF Member # 2433
Blade tip speeds are federally-regulated to 19,000 feet per minute.
__________________
Cheers,
Jason
'87 Lawn-Boy Supreme 8157
'95 Lawn-Boy Silver 10301
'96 Lawn-Boy Gold 10523
'99 Lawn-Boy Silver 10330
'01 Honda Masters HR215SXA
Jason is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-19-2006, 10:53 PM   post #6 of 6
jerry_nj
jerry_nj's Avatar
MTF Member # 1077
Images: 1
Yes, I have understood that manufacturers have to limit blade tip speed, and it is lower for residential than for commercial machines. As residential lawn mowers are all direct drive, that is the blade is directly attached to the crankshaft there is a simple relationship between the RPM and tip speed. Let's see I if I can do the math:
2"pi"R (R = Radius, is 11" for a 22" mower) is the Circumference, is 69 Inches. and if limited to 19K feet per minute, or 209K inches per minute, I get RPM(max)=209,000/69 = about 3,000 RPM, hum if I didn't make a mistake, this sound a bit high. Well, as I compute it I'd not want the engine to run higher than 3K RPM, still need a tach to find the RPM.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
