Gt235 with vanguard and 54" deck stalls in thick grass - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-08-2013, 11:05 PM   post #1 of 16
MowJoe
Got Grass?
MowJoe's Avatar
MTF Member # 75290
Default Gt235 with vanguard and 54" deck stalls in thick grass
I mowed a yard today with my gt235 and this is the first yard I have mowed since putting on a 54C deck. Yard was tough, thick, and a bit high. I would expect it to bog down the mower some but not to the point where it almost kills it. At times it felt like it was stalling out the deck. Is a 54 too much for the 18 hp Vanguard to handle or do I have other problems?
Sent from the MTF Free App
__________________
'13 X540 48" cut
'08 X520 48" cut
(3) 80 Dump Cart
18 Dump Cart
JVR Mowing "Got Grass?"
MowJoe is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-09-2013, 01:09 AM   post #2 of 16
Todd_D
Senior MTF Member
Todd_D's Avatar
MTF Member # 34566
Images: 1
Garage
Default Re: Gt235 with vanguard and 54" deck stalls in thick grass
There are other variables - blade sharpness, wet grass, etc. I don't think a 54" deck is too much for an 18 hp Vanguard. A lot of people have 18 hp tractors with 54" decks. But 54" decks are as big as they get unless you go to the 400 series.
__________________
Current Machines: X748, GT225, 420, 430, 455
Former Machines: 355D, GX345, X300, 318, 322, 420 w/ 44 Loader, 214, 110 RF, F935
Todd_D is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 08:07 AM   post #3 of 16
MichaelTJD60
Member of the 2K Club!
MichaelTJD60's Avatar
MTF Member # 77358
Is the Vanguard the original motor? Supposedly theyre really good motors, I'd be surprised if thats an issue. Of course, I'm pretty sure HP is measured differently today than it was 10 or 20 years ago. My 26 HP with 54" deck always stalled in pretty thick grass but that was because the valves were out of adjustment. Have you adjusted your valves? And the factors that Todd_D mentioned can also affect the cut too.
__________________
-1983 JOHN DEERE 210 -12 HP KOHLER K301, 47 Deck, 43 Blade, Wheel Weights, Sleeve Hitch, Brush Guard, Tru-Power & All-Trail Tires
-2007 JOHN DEERE LA150 - MAIN MOWER, Hard Worker, Runs Good
-2008 CUB CADET GT2550 - KOHLER Command Powered, Heavy-Duty Shaft Drive, Hard Worker, Runs Good
-SOLD: 2001 JOHN DEERE LT133, 1997 JOHN DEERE LX176, 1984 JOHN DEERE 111, 1992 YARD KING 38-12
MichaelTJD60 is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 08:36 AM   post #4 of 16
JohnnyReb
Proud Member of the 1K Club
JohnnyReb's Avatar
MTF Member # 84763
My dad has a GT235 with the 18hp and 54 inch deck. He bought it brand new and is on its 13th mowing season. A real tuff and lasting mower for sure.
But the 18hp engine is a little underpowered for the 54' on heavy duty. For adverage yard mowing it does just fine, but its not going to " bush hog " knee high grass well...especially with the deck set really low. We always mow on 3 inches or 3 1/4. On the other hand I've never had it stall on me but really thick and tall grass will certainly work the 18horse hard. But it has been a great little engine and mower. 13 years and going strong.
Make sure the blades are sharp and maybe mow a little higher...3 inches works well for dads. Might run some premium non ethanol gasoline too and see if it helps. Of course I realize that can be tuff to find. Fortunately my small Kentucky town has a non ethanol pump for small engines and equipment. Will it help....I guess that's debatable
JohnnyReb is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 08:50 AM   post #5 of 16
toppop52
Senior MTF Member
toppop52's Avatar
MTF Member # 82607
The Vanguard is an excellent engine but the torque peak is 30 ft lbs @2600 rpm, the torque curve is fairly flat from 2200-2800 rpm then falls off dramatically the 3500-3600 rpm cutting speed, so if it starts to stall it won't recover as well as a bigger engine with the same h.P. rating. The Vanguard only has 35 cu. in. to work with so torque output is limited and moved in the rpm band as compared to say a 48 cu in. 18 H.P. Onan. So the V has more peak power but the O will put torque where you need it better in the real world.
I'm not putting down the newer engines, I have a B&S 26 h.p. V-twin, but at work that requires a heavy load on the engine the old Onan works better.
__________________
Randy
MF 1855 FEL
toppop52 is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 10:42 AM   post #6 of 16
rayjay
2000 Posts and climbing!!!
MTF Member # 53093
Also make sure the deck is adjusted properly with the back of the deck a little higher than the front.
rayjay is online now   Reply With Quote Quick reply to this message
Old 04-09-2013, 11:23 AM   post #7 of 16
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Make sure it's running on both cylinders.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 03:51 PM   post #8 of 16
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
Are the deck and engine the original ones designed for that tractor? If this was a "cobble together" job, then perhaps the pulleys aren't the correct ratio to deliver the correct blade speed at the normal operating rpm of the engine.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is online now   Reply With Quote Quick reply to this message
Old 04-09-2013, 04:18 PM   post #9 of 16
MichaelTJD60
MTF Member # 77358
Agreed. Thats what I meant when I said they don't measure HP the sane way they used to. My uncle's 318 with 46" deck and LX770 Linamar mows foot tall weeds in the nursery every week without a problem. My 210 with 1-cyl Kohler and 39" deck mows foot tall weeds without a problem. My 5-year-old LA150 v-twin may run faster, but it doesn't put out as much torque at max RPMS. And i ALWAYS mow with the deck all the way up (perhaps it wasn't set up right at the factory?)
__________________
Old 04-09-2013, 05:49 PM   post #10 of 16
Nouveau Redneck
3K Poster!!!!
MTF Member # 19566
Images: 1
So the way they measure horsepower these days is insane?
Sorry... I couldn't help myself.
__________________
Nouveau Redneck
Sean in PA
Old 04-09-2013, 08:01 PM   post #11 of 16
MichaelTJD60
MTF Member # 77358
I secretly meant to say that I'm pretty sure a 26 HP Briggs v-twin is weaker than an 18 HP Onan opposed twin...
__________________
Old 04-09-2013, 10:26 PM   post #12 of 16
MowJoe
Got Grass?
MowJoe's Avatar
MTF Member # 75290
Original motor. Blades are new. Deck is the 54c that would have came on it new. Mower has 221 hours on it. I'm thinking I may have a carb issue that's causing it. I noticed today that when I started it and ran the throttle all the way up it stuttered a bit before it caught up. Under a load it would do the same and cause a stall correct?
__________________
'13 X540 48" cut
'08 X520 48" cut
(3) 80 Dump Cart
18 Dump Cart
Old 04-10-2013, 01:56 AM   post #13 of 16
GetOffMyLawn
MTF Junior Poster
MTF Member # 83998
You don't have a mulching kit on the deck by chance do you? Any dense wet grass, thick/ high grass or tall weeds don't do well with a mulch kit on the deck. All of our small mowers on the golf course I work part time at have the 18hp Vanguards and they are pretty darn strong motors. Just curious, good luck to you!
GetOffMyLawn is offline   Reply With Quote Quick reply to this message
Old 04-10-2013, 09:17 AM   post #14 of 16
MowJoe
Got Grass?
MowJoe's Avatar
MTF Member # 75290
No mulch kit. Dry grass and mowed on 2.5.
__________________
'13 X540 48" cut
'08 X520 48" cut
(3) 80 Dump Cart
18 Dump Cart
Sponsored Links
Advertisement
Old 04-10-2013, 09:19 AM   post #15 of 16
JohnnyReb
JohnnyReb's Avatar
MTF Member # 84763
Depends. Does it only do that from a cold start?? I never start mine and let it go straight to full throttle. I let it warm up a few minuets first. If it stutters a lot when you go wide open on a warm engine it very well could be running rich and would cause stalling under a load. Notice any black smoke before it stalls? Is a sighn of too much fuel being fed to the engine. Of course it's natural to puff a little black smoke after choking it to start when cold, but not when it's warmed up. If it blows some black smoke when you open the throttle when it's warm and it stutters then it could be rich....essentially like running with the choke on. It will kill the power. Give the carb a good inspection and look for any wetness or find a freind to help you out. Good luck and feel free to ask all the questions you want.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
