X728 Fender Deck Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-06-2013, 08:38 PM   post #1 of 7
aquist06
Senior MTF Member
aquist06's Avatar
MTF Member # 52098
Default X728 Fender Deck Question
Hi everyone, I was wondering if your cupholders on your X700 series tractors have holes in the bottom or are they solid? Mine is solid and always fill with water when I wash it or get caught in the rain. I think I am going just drill a few small holes in the corners but was curious.
Thanks
Adam
__________________
2014 1025R, 54" AutoConnect Deck, H120 Loader, 14 Bushel Bagger, 60" QH Blade, 49" Kuhn Tiller, 47 snowblower, 54 rotary cutter
2005 X575, 54" mower, QH, three point hitch
aquist06 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2013, 08:40 PM   post #2 of 7
Mike X485
New Guy....Trainee
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Default Re: X728 Fender Deck Question
My X485 has three holes in the bottom.
__________________
JOHN DEERE X748
Mike X485 is online now   Reply With Quote Quick reply to this message
Old 04-06-2013, 08:41 PM   post #3 of 7
rlowe
Senior MTF Member
rlowe's Avatar
MTF Member # 74740
Images: 2
Quote:
Thanks
Adam
Adam,
I have 2012 X748SE and it has 3 small (1/8" maybe) evenly spaced holes in the bottom of it to drain any fluids.
Roger
__________________
Current Machine: 2012 X748SE "H5" Edition, 60" 7-Iron Deck, 45 Loader, 54" Blower, Curtis Hard Cab
Former Machines: JD 140 H3, JD 345,
Ford 1710, Ferguson 2085
YouTube Channel: X748SE
rlowe is online now   Reply With Quote Quick reply to this message
Old 04-06-2013, 09:22 PM   post #4 of 7
Hostaman
...and Buddy The Dog
Hostaman's Avatar
MTF Member # 75709
Thanks
Adam
The holes get stopped up due to being the exposed to the wheel well. Look again.
__________________
JOHN DEERE X729(2012)
54" Deck w/BM20827 Mulch Kit, 45 Loader, JD BM23882 Cat 1 3PH, JD LPHDC18JD 18 CuFt Cart, JD LP22862 25 Gallon Sprayer, JD LPPA48JD 48" Core Aerator, JD LP25001 3-Point Receiver Hitch, JD BM17972 50 lb. Cast Wheel Weights, JD BM22725 Wheel Spacers, Custom Heavy Hitch, *TOMBSTONE Ballast Slab, Eight Suitcase Weights, Fluid Filled HDAPs on Stock Wheels, Turfs on SE Wheels, SE Seat, Brush Guard, Click-N-Go Weight Bracket (Modified to hold eight suitcase weights)
named by PA318Guy
Hostaman is online now   Reply With Quote Quick reply to this message
Old 04-06-2013, 11:27 PM   post #5 of 7
Jere39
Have Dog - Will Travel
Jere39's Avatar
MTF Member # 47088
My 2010 x728 cup holder does have holes, but they are too small in my mind, and clog up so that I always need a tooth pick or other similar sized probe to open the holes to drain the water after a wash. I'd guess your holder has the holes, and they are clogged.
Anyone drill the holes out a little bigger?
__________________
X728 - 62" Deck, 54" Blade, 42" JD Sweeper,JD 15S Cart
TracVac 880, Gandy 36T Spreader, Feldmann 48" Aerator
Dolmar P510, Pioneer/Partner 330 Chainsaws, Home made Log Arch - LA1000
Jere39 is offline   Reply With Quote Quick reply to this message
Old 04-08-2013, 01:07 PM   post #6 of 7
MNvet
Jerry
MNvet's Avatar
MTF Member # 69513
Garage
After washing the winter crud (salt) off the X748 and blower before removing the blower, I noticed the cup holder still had water in it. I looked it over and determined the holes needed to be cleaned out...that is to say drilled out to remove burrs left after manufacture/assembly. I simply used a drill bit by hand from under the fender pan. I would say the holes were about 90% closed. They drain good now!
__________________
John Deere X748 and assorted attachments
MNvet is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-08-2013, 09:06 PM   post #7 of 7
aquist06
Senior MTF Member
aquist06's Avatar
MTF Member # 52098
Thanks for the help, I do have them, but they will need to get opened up some.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
