need quick review of fuel pump change on 345 with FD590 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-04-2013, 10:34 PM   post #1 of 5
nwohio345
MTF Junior Poster
MTF Member # 84843
Default need quick review of fuel pump change on 345 with FD590
As I'm reviewing my new acquisition, I read about the fuel pump issue.
I hadn't found a great deal of information on the steps/correct method of changing it out (top barb-fuel, Lower outlet to carb, and bottom barb is vent).
My question is that the JD "kit" comes with no gaskets/insulator as shown in their online lookup. Do I need to order these or can I reuse. Do I need to use Permatex or any other sealer on them etc.? Thanks to someone that has done this!
nwohio345 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-04-2013, 10:58 PM   post #2 of 5
Cementhead
Proud Member of the 1K Club
Cementhead's Avatar
MTF Member # 48243
Default Re: need quick review of fuel pump change on 345 with FD590
When I updated the fuel pump on my older 345 I just ordered the gaskets with it,they werent much and you will need a small hose for the vent barb on the new style pump to route it to a safe location.Stay away from gasket sealer if possible,you shouldnt need it.It was an easy job to replace it and well worth the safety factor.My orig pump was not leaking but when reports of fires started circulating I changed it out.
Cementhead is online now   Reply With Quote Quick reply to this message
Old 04-05-2013, 01:38 AM   post #3 of 5
sternzy
Senior MTF Member
MTF Member # 72136
I just replaced mine and also ordered a new insulator, gasket, pushrod.... They are very cheap. My pump came with the hose and clamp.
I also didn't use any type of sealer.
sternzy is offline   Reply With Quote Quick reply to this message
Old 04-05-2013, 03:11 AM   post #4 of 5
Hendo
MTF Junior Poster
MTF Member # 71162
Don't forget to check and see if it had the plastic cam gear! Get that swapped before it fails!
Sent from the MTF Free App
Hendo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2013, 09:26 PM   post #5 of 5
sternzy
Senior MTF Member
MTF Member # 72136
nwohio345, my camera was being a pain in the butt so only one picture wound up coming through.
Fuel in at the top.
Fuel out at the side.
The weep hole at the bottom I routed strait out the large hole below the fuel pump.
For installation:
-Clean engine to fuel pump mating surface
-Put a light film of oil on the push rod, and slide it into the hole in the engine block.
-Install first fuel pump gasket.
-Install insulator
-Install second fuel pump gasket
-Now mount he pump and begin tightening the bolts.
-Move slowly, alternating bolts a little at a time until both are snug against the engine.
-Use a torque wrench and tighten the fuel pump bolts to spec.
Sadly my hard drive was a complete loss this week, including my digital manuals so I don't have the exact torque spec for the FD590v handy. I'm sure someone here can help you out with that.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
