196? Ford 2000 LCG. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-03-2013, 05:44 PM   post #1 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Default 196? Ford 2000 LCG.
I will be picking up a Ford 2000 Low Center of Gravity, tractor that I found on craigslist. I went and looked at it this morning, and gave the guy some money to hold it for me. I will post some pics up of it as soon as I get it home.
__________________
196? Ford 2000 LCG (Project).
1986 John Deere 318.
Colin.
640 FORD is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-04-2013, 03:38 PM   post #2 of 20
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
Default Re: 196? Ford 2000 LCG.
Looking forward to the pictures. The main difference between the regular 2000 and the LCG version is the height of the front axle spindles. They just fitted the rear with shorter wheels and tires to make it look level relative to the shorter front end. They're supposed to make great mowing tractors, especially if you've got a lot of hills.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is online now   Reply With Quote Quick reply to this message
Old 04-05-2013, 12:04 AM   post #3 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Here are the pics of the tractor. All I have done it take the hood off. I plan to do a little body work to it paint it up and sell it.
Here is the grill I got with it. And nose cone.
Here is the drawbar that I got for $10 bucks.
__________________
Colin.
Old 04-05-2013, 07:12 AM   post #4 of 20
Kirk-NJ
2000 Posts and climbing!!!
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
I forgot to mention in my email this morning about the shorter spindle/knees. The FORD letters for the grill are useally on ebay some of the early square nose models are the same. Some red paint on the trans and rear indicate a possible switch as discussed in the email. Good luck with it.
Kirk
Kirk-NJ is offline   Reply With Quote Quick reply to this message
Old 04-05-2013, 09:59 AM   post #5 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Quote:
Kirk
Thanks Kirk.
So far is looks like it is going to be, just some body work and paint, ( I hope ) It is smoking a little bit, so I am going to put some atf, in the motor to help clean it out.
Will keep you guys up to date on the progress as I go along.
Thanks Colin.
__________________
Colin.
Old 04-11-2013, 11:39 PM   post #6 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Here are some more pics of what I have done so far.
I got one of the dog leg's welded back on, I have taken one fender off, and done some Bondo work on it. Tomorrow I will get pics of what I did today.
__________________
Colin.
Old 04-12-2013, 07:25 AM   post #7 of 20
Kirk-NJ
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
coming along nicely Colin. Keep those photos coming.
Kirk
Old 04-12-2013, 11:20 AM   post #8 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Kirk
Thanks Kirk.
__________________
Colin.
Old 04-12-2013, 04:19 PM   post #9 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Here are the pics of what I did last night.
__________________
Colin.
Old 04-12-2013, 05:17 PM   post #10 of 20
rscurtis
5000 Strong & Climbing
MTF Member # 25367
As long as you have it this far apart, may as well look into the engine to check the smoking. It's a pre-1965, as that's when they went to the 3-cylinder engine.
rscurtis is online now   Reply With Quote Quick reply to this message
Old 04-12-2013, 11:38 PM   post #11 of 20
Ecnerwal
Not a restorer
Ecnerwal's Avatar
MTF Member # 47854
Images: 8
Do you mean post '65 - I only count 6 ports, so I'd assume it's 3 cylinders.
but one of the earlier pictures does seem to show 4 sparkplugs. Huh. Do they share intake ports or something?
Not only am I (clearly) not all that versed in pre-'65 tractors, I haven't even had the post '65's I do have anywhere near this far apart.
__________________
Ford 4500 diesel TLB (740/753)
Ford 4500 gas 740 Loader/3-point (no pto)
Ecnerwal is offline   Reply With Quote Quick reply to this message
Old 04-13-2013, 12:07 AM   post #12 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
It is a pre 65. I just don't know what year it is, because it looks like someone took a grinder to where the Serial Number is. Being a pre 65, it has the 134ci 4cyl engine in it. My last tractor was a Ford 850, it had the 172ci 4cyl like my Dads Ford 861 has.
__________________
Colin.
Old 04-13-2013, 07:37 AM   post #13 of 20
Kirk-NJ
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
Colin,
You can check the date code on the engine for a better idea of the year.
Not that paint means anything, because we already think the back half has been changed out but I see some read paint on the engine so it might have started out like this.
Kirk
Old 04-13-2013, 09:11 AM   post #14 of 20
640 FORD
MTF Member
640 FORD's Avatar
MTF Member # 83966
Colin,
Kirk
Thanks Kirk.
How do I check the data code's? I have never done that before. When I first saw the tractor, I thought it was going to be a red and buff one. There is red paint under the blue paint, but there is also more blue under the red paint. So I don't know how many times it has been painted.
Last night I got the rear tires, and front bolster off of the tractor. I am going to have to re wire it, and I will be converting it to 12v, I just have to get a battery, we have an alternator that I think came off another tractor that I had tested and it is still good. And if all goes good I should have some paint flying by mid to end of next week. I will get some more pics of what I did last night.
Thanks Again.
__________________
Colin.
Sponsored Links
Advertisement
Old 04-13-2013, 10:08 AM   post #15 of 20
petra79
Still learnin!
petra79's Avatar
MTF Member # 29815
Yep, Intake ports are shared. Second one in from each end.
__________________
Ron
petra79 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
