Gas Tank cleaning quandray - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 02-27-2013, 01:11 AM   post #1 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
Default Gas Tank cleaning quandray
Picked up a, new to me, Power Wheel (pictured below). The tank is in pretty bad shape inside. At first, I thought the bottom was coated with varnish but, it appears to be mostly rust. Decided so after using a long screw driver to lightly scape the bottom when my first soaking with mineral spirits didn't come out as dirty as I'd expected (soaked about 8 hours).
What did scrape out was certainly rusty scale. I've gone through several phases with rocks/drywall screws/machine screws with a bit of a DIY degreaser (super washing soda and tap water), the net result was extremely rust colored water being poured out after each cycle. However, at the rate it's going, I could be repeating this process for weeks!
So, thought I'd try some distilled white vinegar over-night. After filling the tank, noticed the label said it was diluted to 5% with water but, not expecting to much from such a weak solution.
Now, instead of going out to buy a gallon of muriatic acid, I have some concrete floor stain left over from a previous job. Looked up the MSDS on it (Kemiko brand - cola colored) and here's what it lists as ingredients:
Code:
Ferrous chloride   7758-94-3   15 - 20%
Hydrochloric acid   7647-01-0   5 - 10%
Chromic chloride, basic   50925-66-1   1 - 5%
My guess is, the Ferrous Chloride gives it color and the Chromic Chloride is a catalyst. The Hydrochloric is what were aiming for! So, here lies the quandary:
Are the first and third ingredients going to cause any problems? Hoping someone else may have used this type of acid in a pinch and know for sure... not being a chemist myself.
And secondly, will 5-10% Hydrochloric acid be enough? Muriatic Acid's (Crown brand @ Lowes) MSDS lists the acid content @ 25-35% mix with water.
Of course, I'm open to other suggestions for a remedy too.
__________________
Steve
Current Equipment:
Mahindra 4110 with most standard attachments and then some.
Yazoo Master Mower 62 CH25S
John Deere 118
Western Auto 'Wizard' 5HP RT Tiller (GIS 2130 A38)
Project equipment:
Power Wheel - A one wheel plow
4micaman is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-27-2013, 10:36 AM   post #2 of 20
edgesr
Senior MTF Member
edgesr's Avatar
MTF Member # 26021
Default Re: Gas Tank cleaning quandray
If possible I would use electrolysis to clean the tank. The following are links to a series of 4 youtube videos on how it is done on a small motorcycle tank.
Mike
http://www.youtube.com/watch?v=LCpJR...eature=related
http://www.youtube.com/watch?v=ZmpDt...hannel&list=UL
http://www.youtube.com/watch?v=M_PgA...hannel&list=UL
http://www.youtube.com/watch?v=OcLYP...feature=relmfu
edgesr is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 02:59 PM   post #3 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
Electrolysis was one of the methods I found before my attempts but wasn't sure/convinced it would work.
I'll have a look at the videos you suggested - Appreciate it!
__________________
Steve
Current Equipment:
John Deere 118
Project equipment:
Old 02-27-2013, 03:01 PM   post #4 of 20
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Acids would probably erode the little thin cup at the top of the tank, as well as damaginf the glue that bonds the top and bottom halves of the tank together...
only sure fire way is to clean it up, and do a coating inside, like they use on ATV/Cycle tanks...
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 05:40 PM   post #5 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
I seem to recall reading that someone took their tank to a radiator shop to have it boiled out. IIRC, they found the bowl on the bottom of the tank. Perhaps that shop used Muriatic Acid instead of a lye solution.
Just checked the tank after soaking almost 24 hours with the vinegar. The vinegar appears nearly as clear as when I poured it in! Heck, better luck was had with my diy degreaser and rocks/screws.
Will have to see what sort of contraption can be mangled together for Electrolysis. As a last resort, before replacing the tank, the acids may come into play.
As the tank sits now, it holds liquid as it should. Knock on wood I don't muck this thing up!
__________________
Steve
Current Equipment:
John Deere 118
Project equipment:
Old 02-28-2013, 10:37 AM   post #6 of 20
tomw0
2000 Posts and climbing!!!
MTF Member # 34922
A fellow that modifies old Honda 350 bikes for racing uses lengths of chain and a solution to clean up the insides of the tank. He then uses a two part coating mix. He says he can get two or three tanks cleaned with the chain(s) and one cleaning 'solution' before it wears out, and can coat about the same number of tanks using the epoxy(?) mix, rolling the tank in all positions with covers in the gas cap and the equalizing tube openings.
tom
tomw0 is offline   Reply With Quote Quick reply to this message
Old 03-01-2013, 12:44 AM   post #7 of 20
mrcaptainbob
Proud Member of the 1K Club
MTF Member # 177
I'd tape up all except the fill port and toss in some square nuts and square headed bolts. Count them first! Rattle them around with some kerosene. Dump it out and count the pieces. Rinse with water. Rinse with MEK. Pour in some Red Kote and slosh around until the entire inside is coated red. Drain off the excess back into the can and wait at least a day. You'll never have rust as a problem again. In my area Red Kote can be purchased at Auto Zone. I highly recommend that stuff.
mrcaptainbob is offline   Reply With Quote Quick reply to this message
Old 03-01-2013, 01:37 AM   post #8 of 20
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Before I sold it, I used to have an electric concrete mixing drum. I took a few 5hp briggs tanks, duct taped the ports, wrapped it in an old beach towel, and wrapped ducttape around it, and tossed it in for a while, with random nuts and bolts in the tank.
It was either going to come out in peices, or clean...
but it was incredibly noisy and people complained.
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 03-01-2013, 11:09 AM   post #9 of 20
tomw0
MTF Member # 34922
Red: "but it was incredibly noisy and people complained."
Need more towels.... or a buncha old tennis balls to cushion the tanks. Wrap each tank individually in its own towel. They don't need the shock of hitting the inside of the mixer drum, just the 'slosh' back and forth.
I expect that an old clothes dryer would do the same, and it could be quieter because it might still be in its cabinet. Either disconnect the heating element or don't connect the gas fitting. A gas dryer would be easier to connect as it only requires 120VAC for the motor vs the 220 for an electric.
I would not invest a lot into an old dryer for this purpose as I think they are pretty much available for zero cost in c-list if you watch.
tom
Old 03-01-2013, 03:44 PM   post #10 of 20
rons old ford
Senior MTF Member
MTF Member # 69272
I have the tank from my Ford 125, and took it to a cycle shop to be cleaned. They said they had a hard time because it had baffles in it. Their idea was to shake it with beads inside to loosen anything. It cam back just as dirty, but this stuff is real dirt, like powdered clay. We get that a lot around here. Clogged the cutoff fitting after a while, and then I noticed some powdered clay in the fuel filter. Not sure what to do next.
rons old ford is offline   Reply With Quote Quick reply to this message
Old 03-01-2013, 04:46 PM   post #11 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
Quote:
Is MEK fast drying and that's why you suggest using it? If so, I have some Toluene I could use instead.
As for the Red Kote, I'd read of it in my research for this tank cleaning process. After you suggested it, I found it at O'reilly's but Autozone appears to no longer carry it. If I decide to use a tank liner/sealer, it's now between red kote and por15.
Thanks for the advice!
The former is the part I'm dead-set on avoiding. It sucks being broke!
Update:
Left the tank with vinegar thinking it just needed more time to work at the rust. When the top was removed a strong varnished gas odor slapped me upside the head! Guessing now my *cough* assumptiom of it being strictly rust on the bottom was wrrr wrrrrrong. After doing more research on vinegar I found this on wisegeek:
Quote:
Industrially, acetic acid is used in a wide range of processes. It is also used in chemical production and research, in settings where people have need for a weak acid. Like other acids, acetic acid is corrosive for many substances, and it can be involved in a variety of chemical reactions. Acetic acid is used as a solvent, a reagent, a catalyst, and a pesticide. It can be used in the preparation of paints, varnishes, and glazes, and in medical treatment, as for example in the treatment of jellyfish stings.
At this point, we'll top it off with vinegar just below the line where the cup attaches to the top, and let it sit.
Thanks folks - all the shared wisedom is appreciated!
__________________
Steve
Current Equipment:
John Deere 118
Project equipment:
Old 03-01-2013, 04:55 PM   post #12 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
Quote:
Obviously, I'm not speaking from experience. But, having read many threads and articles on the matter, in your case; you may be limited to electrolysis or an acid bath.
As for baffles being in a tank that holds less than 50 gallons boggles my mind. It seems as weird as some tanks having foam in them to prevent sloshing.
__________________
Steve
Current Equipment:
John Deere 118
Project equipment:
Old 03-01-2013, 11:26 PM   post #13 of 20
mrcaptainbob
MTF Member # 177
Yeah, the MEK is quick drying and leaves no residue. I did a few tanks around here. One was for a neighbor's tractor. It was so severely rusted that the glass bowl filled inside of five minutes running from the crud. It's about a 15 G tank. Power washed the worst out, then did the kerosene and bolts thing to loosen anything that my be easily loosened, then the MEK thing. One wall that faced the battery had some rather large pin holes. JB welded that area after serious wire brushing and facing with a soft window screen material. The Red Kote came next. THis ws about six or so years ago. Maybe seven. THe glass bowl is still clear and the project was FAR cheaper than trying to dig up a used tank for that old tractor beast. And that may have had similar issues anyway! Years ago I used the aircraft stuff called Sloshing Compound. It was pricey stuff, hard to find and worked great. Until our gasoline integrity started getting compromised. Red Kote claims to be impervious to most new grades of fuel. This tractor tank alone is a testimonial (to me) of how good it is. It's just a one part liquid and is very easy to use.
Old 03-02-2013, 12:04 PM   post #14 of 20
jdrobison
Senior MTF Member
jdrobison's Avatar
MTF Member # 72142
Thumbs up Re: Gas Tank cleaning quandray
I worked for a elderly man in high school that had a mower shop, he would clean them with pebbles a little kerosene. put that in seal it up and put in a old paint shaker for 5 min. most would come out shiny inside.
__________________
1811 cub
1720 cub
147 cub
102 cub
soon a 214 JD
2 Farmall regulars
1928 & 1929
Farmall M
jdrobison is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-23-2013, 07:58 PM   post #15 of 20
4micaman
MTF Junior Poster
MTF Member # 61134
To update this "quandry" - now a quagmire! In other words, SNAFU!
Seems the tank was not only coated in varnish but rust as well. My final clean out today I see clean metal (clear signs of pitting) but, with vigorous shaking by hand and the combination of drywall screws, I've butchered the tank.
I count 4 pin holes on the bottom of the tank itself and the cup/reservoir has many more than that. *smacks forehead*
__________________
Steve
Current Equipment:
John Deere 118
Project equipment:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
