Help, x728 died - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-26-2013, 08:50 PM   post #1 of 40
oaker55
Senior MTF Member
oaker55's Avatar
MTF Member # 48448
Default Help, x728 died
OK, so I went out to clear the snow and everything was fine. Tractor started fine, had about 1/3 tank of gas, etc. Cleared the driveway and went out to the street to clean up and tractor started to sputter, almost like it was starving for gas. Finished up in the street and was finishing up our little turn-around and the sputtering got worse and then the tractor died. I thought maybe the gauge was wrong for some reason and added about 5 gallons for gas. Tractor doesn't fire. When I turn on the key, I can hear the fuel pump and the light goes out in the dash indicating fuel pressure, but tractor just turns over with no fire. Any ideas?
oaker55 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-26-2013, 08:57 PM   post #2 of 40
Diesel Powered
MTF mile high club member
Diesel Powered's Avatar
MTF Member # 69612
Default Re: Help, x728 died
Sounds like you ran it out of gas. There's a purge procedure that you need to do. If one of the Kawasaki guys doesn't come along soon, I'll look it up or you can search the site to find it.
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Diesel Powered is online now   Reply With Quote Quick reply to this message
Old 02-26-2013, 09:00 PM   post #3 of 40
Jimbochap
3K Poster!!!!
Jimbochap's Avatar
MTF Member # 72763
Someone just showed that on here how to prime it, there is a screw on top , you loosen it and then turn the key until the gas comes out and then screw the screw back in.
__________________
JD 345
*48C" Deck
*44" Piranha Mulching/Rear
Discharge Mower Deck
*48" Snow Blade
*42" Snow Thrower
*** Chute Rotation Kit
*38" Front Thatcher
*2-50# Wheel Weights
*7-42# Suit Case Weights
** Power Flow
**All Trail HDAP's
**John Deere Mulch Kit For 48C Convertible Mower Deck - BM20007
***OTC Snow Cab
FOR SALE
*30" Mechanical Rototiller*
**2- JD Wheel Weights (#50 Plastic)
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 09:01 PM   post #4 of 40
oaker55
Senior MTF Member
oaker55's Avatar
MTF Member # 48448
I have run it out of gas before, but never in the winter and never had to do the purge. I will look it up and try that in the morning when I can see. Thanks!
Old 02-26-2013, 09:07 PM   post #5 of 40
Jimbochap
3K Poster!!!!
Jimbochap's Avatar
MTF Member # 72763
You might have some issues with the fuel pump or fuel pickup inside the tank. Try the easy cheap stuff first.
__________________
JD 345
*48C" Deck
*48" Snow Blade
*42" Snow Thrower
*38" Front Thatcher
** Power Flow
**All Trail HDAP's
***OTC Snow Cab
FOR SALE
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Old 02-26-2013, 09:38 PM   post #6 of 40
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
Quote:
Yeah there's a short piece of fuel line inside the tank on the fuel pump that likes to loosen up or rupture. If you have gas in the tank that would be my next check. You'll have to remove the fender pan to get at the top of the gas tank and the fuel pump.
Harryc is offline   Reply With Quote Quick reply to this message
Old 02-26-2013, 09:41 PM   post #7 of 40
oaker55
Senior MTF Member
oaker55's Avatar
MTF Member # 48448
That sounds like fun!
Old 02-26-2013, 10:49 PM   post #8 of 40
KWDAILYD
8K poster and enjoying it
KWDAILYD's Avatar
Here is the fuel bleed procedure.
Name:	Fuel Bleed (2).jpg
__________________
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 6 JD suitcase weights. 2-50# cast rear wheel weights.
Thread for 110 RF build http://www.mytractorforum.com/showthread.php?t=287161
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is online now   Reply With Quote Quick reply to this message
Old 02-27-2013, 09:52 AM   post #9 of 40
njdeerefan
Senior MTF Member
njdeerefan's Avatar
MTF Member # 58672
Another thing to check is the fuel filter, maybe you got gas with water or crud in it. Obviously also get your electrical connections (I.e. plug wires, coil wires, etc), and check to see if your air filter is wet or dirty. Took alot of ASE courses on auto repair over the years, I always start with the three basics, when engine wont start. Spark, fuel, Air.......is what an egine needs to run.
__________________
2007 John Deere la130
2010 John Deere X740
1950 John Deere M
njdeerefan is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 10:49 AM   post #10 of 40
oaker55
Senior MTF Member
oaker55's Avatar
MTF Member # 48448
Quote:
Unfortunately, I got called into work early this morning so I didn't have a chance to check anything this morning but will this afternoon. One simple question, like I said when I turn on the key I can hear the fuel pump run and then the indicator light on the dash goes out which I was always told indicated that the system had fuel pressure. Where is this pressure measured? Is there a separate pressure switch or is it back pressure on the pump itself? I think I will stop and pickup a fuel filter on the way home. I usually change it in the spring so it's due.
Old 02-27-2013, 11:45 AM   post #11 of 40
smithrngr
Senior MTF Member
smithrngr's Avatar
MTF Member # 5639
Images: 2
since you are going to change the filter,hold the line from the tank in a can and turn the key.if you don't get fuel flowing out the line it is going to be the rubber hose that is in the tank for the pump.
__________________
corey
2005 jd x485 with a 62c deck and 54" front blade
2003 jd 4510
1989 w/h 520-hc
42" brinly sweeper
brinly plow
36" w/h tiller
175lb jd/brinly spreader
stihl fs56-rc
smithrngr is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 01:47 PM   post #12 of 40
KWDAILYD
KWDAILYD's Avatar
You should loosen that bleeding screw and take the pressure off the system before removing the filter.
__________________
Just call me Larry
Old 02-27-2013, 02:10 PM   post #13 of 40
Jere39
Have Dog - Will Travel
Jere39's Avatar
MTF Member # 47088
I've shared this sequence before, but here are a couple color photos from my Spring maintenance last year:
Bleed off pressure:
Capture the remaining gas in a small cup (the one I chose was much larger than I needed):
After draining line and filter you can see more than a little dirt in my drain cup:
And for academic exercise, I cut open my filter to see what it was straining out of injectors:
New filter on,
Bleed air as described in scan of Owners Manual. Hopefully start her up.
__________________
X728 - 62" Deck, 54" Blade, 42" JD Sweeper,JD 15S Cart
TracVac 880, Gandy 36T Spreader, Feldmann 48" Aerator
Dolmar P510, Pioneer/Partner 330 Chainsaws, Home made Log Arch - LA1000
Jere39 is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 06:22 PM   post #14 of 40
oaker55
Senior MTF Member
oaker55's Avatar
MTF Member # 48448
Jere, thanks for those photos! I did get it started, but it is still stumbling/sputtering under load. I did not get to the dealership for a filter as of yet, so that is my first thing to change. One question about that bleed screw, how far do you back it out? I turned it out about 2-3 turns and cycled the ignition switch several times and then tightened it back down and tried to start it and it still turn over a good 5-10 seconds before it started. Will that screw actually come all the way out (as in fall out) or will it stop before it falls out? I didn't want to take a chance to lose the screw in the snow, so I only turned it about 2-3 turns like I said. About this hose that several have spoken about, how long is it and what size? Is this something I have to get from JD or can I just go to the local auto parts store?
Has anyone ever had to mess with the filter that is in the tank? I'm beginning to think that I may have gotten some bad gas that has caused all of this.
Sponsored Links
Advertisement
Old 02-27-2013, 06:43 PM   post #15 of 40
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
The hose is just a couple of inches long if that...1/8" fuel line.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
