My JD420 *Lots of pics* - Page 5 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-02-2013, 08:11 PM   post #61 of 110
dkarst
Senior MTF Member
MTF Member # 60531
Default Re: My JD420 *Lots of pics*
May be an onan B48g in those years, will have points if original.
dkarst is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-02-2013, 08:30 PM   post #62 of 110
biker3777
Three of my friends
biker3777's Avatar
MTF Member # 33453
I suspect the motor mount tabs were broken ( as some do) and the oil pan was replaced.
__________________
Real Lawn Tractors are Green,Just can't have too many toys,and Free is not Cheap.
1965 Round Fender
332 Diesel
F525 A Fantastic Mowing machine
216 fitted with model 31 tiller
91 Honda Goldwing that I REALLY like.
Wife of 52 yrs that tolorates me
biker3777 is online now   Reply With Quote Quick reply to this message
Old 03-03-2013, 12:45 AM   post #63 of 110
Lucas in Alaska
MTF Member
MTF Member # 83019
Well with all the hubbub about the engine I went out and looked at it a little deeper. The bottom half of the air box is broken and has a hole in it so I need to replace that. The engine is a B48G and it still has points on it. I thought the city might have upgraded the electronics but I guess not. I would like to upgrade the electronics but as far as I can tell it's very expensive. I've looked at Kirk Engines and noticed they have a Pointsaver, anyone ever use this? Is there a better route to go with the electronics?
Later this week I hope to get a compression tester and test the compression.
One other problem I have is the fuel pump being used is a pump off an automobile. I would like to either rebuild the original pump or get a smaller Facet pump.
Here's some more pics.
John Deere 420 B48G engine by Lucas in Alaska, on Flickr
Lucas in Alaska is online now   Reply With Quote Quick reply to this message
Old 03-03-2013, 01:06 AM   post #64 of 110
mrbeef
5000 Strong & Climbing
mrbeef's Avatar
MTF Member # 75839
Garage
Boomers_influence should be able to set you up with and air cleaner bottom.
Looking at the engine I am not sure about it being short blocked. Maybe just the oil pan was replaced. I think you would have to look at the internals to really find out if it was short blocked.
Not sure about wanting to go to electronic ignition. I think you might have to replace the timing cover since there are not a mounting location for the ignition module..... (I think being key) Boomer would be able to answer that question.
__________________
A Wonderful Wife that puts up with me, two cats and the dog, and a BAD case of round fenderitis
Tractors:
07' JD X748
88' JD 318 "The Golden Child"
83' JD 214
The Round Fenders: 67' JD 112H, 67' JD 110H "The Frog", 66' JD 110, 65' JD 110, 64' JD 110
In Parts: 65' JD 110, 66' 110H
Former Machines:
60's Power King, 65' JD 110, 66' JD 60, 69' JD 112, 69' JD 140H3, 72' 140 H1, 77' JD 212, 80' JD 317, 80' JD 317, 80' JD 317, 83' JD 318, 84' 420, 86' JD 318, 86' JD 420, 87' JD 430, 87' JD 318, 88' JD 318, 88' JD 318, 88' JD 855, 89' JD 318, 91' JD 430, uk Cab Cadet 2140, 92' JD 320, 93' JD 320, and 01' LX277
mrbeef is online now   Reply With Quote Quick reply to this message
Old 03-03-2013, 01:33 AM   post #65 of 110
hgl1
Senior MTF Member
hgl1's Avatar
MTF Member # 20597
Garage
Hey LIA
Yep that is the sight glass. You want to get rid of those hose clamps as they will crush the glass tube and still not seal. You want to use the original JD spring style (the best option) or some really tiny zip ties (not as good but wwwwaaaayyyy better than the worm / gear style clamps). There is virtually no pressure in this hose so they do not need a lot of tension.
Did you get the rockshaft with your 420?
Good luck with your project.
D
Name:	420 sight glass.jpg
hgl1 is offline   Reply With Quote Quick reply to this message
Old 03-03-2013, 01:49 AM   post #66 of 110
Lucas in Alaska
MTF Member
MTF Member # 83019
Mebeef, thanks for the pointer on parts. Ill do more research on the ignition.
hgl1, Rockershaft? Is that for the 3-point hitch? All I have is what you see. There was a 250+ pound weight box on the back so there was no room for the 3-point hitch. Although it would be nice to have a 3 point on the back I will most likely put the weight box back on for snowblowing next winter.
Also, thanks for the tip on the sight glass.
Old 03-03-2013, 02:00 AM   post #67 of 110
mrbeef
mrbeef's Avatar
MTF Member # 75839
Garage
The rock shaft is to lift the deck (which you do not have and this will just be a snow machine if I remember right) This is what the rockshaft looks like and it attaches where those two recesses are in the back of the frame rails.
http://www.ebay.com/itm/John-Deere-2...item1c305dd943
I am not sure, I think the 420 is a little wider than a 318 so be careful about which one you get. The one I posted says it from a 420.
Or you can buy a 3pt which comes with a rockshaft Then you can buy suitcase weights and then..... you get the picture John Deereitis can get severe real quick (I just wanted a 318, yet today it looked like my garage upchucked John Deere green on to the driveway)
__________________
Tractors:
07' JD X748
83' JD 214
Former Machines:
Old 03-03-2013, 02:18 AM   post #68 of 110
coalminer16
Proud Member of the 1K Club
coalminer16's Avatar
MTF Member # 64251
Images: 23
Don't worry-the rockshafts/3 points are the same for the 318, 332, 330, 322, 430, 420, etc. I took the 420 3 point and mounted to my 332 and took my 332 rockshaft and put on the 420. The rear axles of a 430/420 also fit the 300 series tractor as well-they are just longer. The rear frame spacing is the same. Front-no so.
Sight tube-just replace with 1/4 inch clear hose as it does get brittle with time. The 420 I had-still said John Deere on the hose-but it basically shattered. You will need a lower PTO belt pulley for the front. Looking at it you need that and I think there is a guard as well that goes around the pulley as well. If this will only be a blade tractor neither the PTO nor the rear rockshaft are needed. But mowing you will need both.
__________________
first year 332 with H3 added X 2, JD 3 pt, JD factory delux seat with flip pan. 430 rear diff. 430 fender deck(have two that are mirror copies of themselves).
Attachments:JD 44 loader, JD 50 inch mowing deck, JD 48 replacement mowing deck JD 47 two stage snow blower, JD Hyd 30 tiller X 2 (one belly drive with 12" extension one rear PTO drive with extension-Jim Briney 3 point mounts), Gannon Earthcavator 42 inch 3 point mount, Cozy cab, JD 20 plow, Brinly 12 inch plow.
coalminer16 is offline   Reply With Quote Quick reply to this message
Old 03-03-2013, 07:50 AM   post #69 of 110
k91
MTF Member # 19618
Nothing wrong with keeping the points. They are fairly simple, rarely fail and are cheap to replace when you need to. But that's up to you
k91 is online now   Reply With Quote Quick reply to this message
Old 03-03-2013, 09:39 PM   post #70 of 110
ajcan
Senior MTF Member
ajcan's Avatar
MTF Member # 39156
My Nephew has the points saver on his round fender 112.Works good.The previous owner installed it and said it now starts much easier with the points saver.
AJ
ajcan is offline   Reply With Quote Quick reply to this message
Old 03-03-2013, 10:34 PM   post #71 of 110
Lucas in Alaska
MTF Member
MTF Member # 83019
Thanks for all the replies. I would love to get a 3 point hitch and put suitcase weights on the back but I have seen how much those are and I would have more in the weights than I do in the 420. I will most likely go with a pointsaver. I am slowly acquiring a list of stuff that I want to get and will most likely start ordering stuff here in about a month. Sadly the list is getting long.
Here is the before and after pics I find most impressive with the cleanup.
Untitled by Lucas in Alaska, on Flickr
John Deere 420 after wash by Lucas in Alaska, on Flickr
Old 03-03-2013, 10:48 PM   post #72 of 110
Kansas John Deere
Kansas John Deere's Avatar
MTF Member # 32517
Images: 1
You could pull the rear PTO and all the wiring put it on E-Bay for a buy it now price of 700.00 to help finance what you need................KJD
Kansas John Deere is offline   Reply With Quote Quick reply to this message
Old 03-04-2013, 03:20 PM   post #73 of 110
hgl1
Senior MTF Member
hgl1's Avatar
MTF Member # 20597
Garage
Quote:
Most of what you said is correct however you do not need the rear PTO for a mower unless you are going to run a rear 3 point mower / tiller or ????
The belly (MMM) mower runs off the back side of the front PTO shaft on a 420 so you will need to replace the pulley. I believe they are still available new and unless you get a really great deal on one I would go new. They all wear the splines. You will also need the regular rockshaft or 3 point rockshaft to lift the MMM.
Most of what you will run on these will drive from the front or mid PTO so unless you specificially need the rear PTO it will definitely finance a good amount of other repairs. Just remember to include all the clutch / wiring / switch and the rear PTO unit so it will be complete and you will get the most $ from it. The harness all unplugs from the tractor and you only need to make a small jumper wire for your tractor once you remove it. Clean it up and then start the bidding at $700.00 and see if gets any better. Some do.
Old 03-04-2013, 03:59 PM   post #74 of 110
coalminer16
MTF Member # 64251
Images: 23
I should have stated front PTO as that was what I meant since currently that is the onet that doesn't work. Thank you for making sure everyone else knows that as I would hate to have others buying rear PTO's due to miss information.
What are the full plans. I know you said a blower is a possble future (which you would need the Front PTO to work then). Any mowing in the future of this? Any rear implements? Garden?
__________________
Sponsored Links
Advertisement
Old 03-04-2013, 05:51 PM   post #75 of 110
biker3777
Three of my friends
biker3777's Avatar
MTF Member # 33453
Lucas,when an Onan is shortblocked from Onan they stamp a number followed by xxxxxx on top on the block on a flat spot.I can't recall where it is.Boomer would know but the one I have seen shortblocked also had a sticker on the engine tin saying just that.
__________________
1965 Round Fender
332 Diesel
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
