Lawn Boy Push mower Questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 02-10-2013, 12:12 PM   post #1 of 9
matth8888
MTF Member
matth8888's Avatar
MTF Member # 75894
Garage
Icon2 Lawn Boy Push mower Questions
http://charlotte.craigslist.org/grd/3577705533.html
Is this worth it? what model is this? What do these sell for running?
__________________
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
- 1999ish Simplicity Broadmoor 16hp/38"
-1990 Bolens 1468
And many other mowers, blowers,trimmers ect. Too many to list.
Sold
- Snapper RER 6hp/ 25"
-Murray 11hp/36"
- 1998 Murray 18/42
- 1990 Lawn Boy GT18H
-2008 Simplicity Broadmoor 20hp/ 44"
matth8888 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-10-2013, 12:54 PM   post #2 of 9
Yard Nazi
2000 Posts and climbing!!!
Yard Nazi's Avatar
MTF Member # 64763
Talking Re: Lawn Boy Push mower Questions
Hi! Not sure of the model without better pictures or more info but appears to have a bail so post 1983 year. Seems to be a push rather than self propelled as well but hard to tell. You could easily part this out and make back well more than the $25.00 investment but it would depend what you are interested in it for. If you are looking for a mower for yourself or one to flip then it would only be worth the money if the motor has good compression and is not seized. I paid $125.00 for a 1996 push Lawnboy, one owner and very clean, but had to put no money into it. On the other hand I have purchased two different mid 70's D series Lawnboys at estate and yard sales for $25.00 each. One did not start and the other did start but ran poorly. Didn't take much money to make either of them good running, usable mowers. Also make sure there is no damage to the deck such as missing pieces, cracks, etc. Surface rust is easily cleaned off the handles with as SOS pad or similar method if it is not too bad. Make sure wheels are not worn through or excessively loose. Also make sure bail cable is not frozen as well as the throttle cable. Again, pretty hard to go wrong for $25.00 but it depends what you expect to get for that. Hope this is helpful. Bill
__________________
1968 Lawnboy 3054 Mower
1973 Lawnboy 8231 Mower
1975 Lawnboy 5024 Mower
1975 Lawnboy 5273 Mower
1976 Lawnboy 5274 Mower
1976 Lawnboy 7265 Mower
1977 Lawnboy 5024 Mower
1978 Lawnboy 5026 Mower
1978 Lawnboy 7268 Mower
1979 Lawnboy 5247 Mower
1996 Lawnboy 10401 Mower
1972 Lawnboy 1015 Edger
1987 Lawnboy 1400CL Trimmer
Where there's a will, there's Mr. Bill!
They don't call me MacGyver for nothing!
I have LBAD and DCAD!
Yard Nazi is offline   Reply With Quote Quick reply to this message
Old 02-10-2013, 03:23 PM   post #3 of 9
matth8888
MTF Member
matth8888's Avatar
MTF Member # 75894
Garage
Default Re: Lawn Boy Push mower Questions
Well,i got the mower for $20.
Model #... Can anyone tell me about this model? engie type?
The pull cord dosnt retract in all the way. can anyone help me on this?
And i dont think this is the airfilter cover....it looks like a mulch plate for a mtd.
IT does have good compression though.And yes i have the gastank,ect; i just took it off.
Anyone have a manual or parts schematic?
__________________
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
-1990 Bolens 1468
Sold
-Murray 11hp/36"
- 1998 Murray 18/42
Old 02-10-2013, 04:02 PM   post #4 of 9
Yard Nazi
Yard Nazi's Avatar
MTF Member # 64763
Hi! Your mower is a 7351, 1988 aluminum deck push mower with the reliable F engine. This model was made in 1986, 1987, and 1988. Here is a link to Lawnboy.com with some information about your mower. You can also download the Lawnboy service manual through this link. Typical cause for the rope not to retract would be a broken recoil spring although it could be something else. The service manual may be of some help in disassembly. That plate does look like a deflector for an MTD so search eBay for the correct air filter cover which should be part number 93-1231. Good luck in getting this running. Shouldn't be too hard to clean the carb, check exhaust ports for clogging, check for spark, etc. If you need any help we are here to answer any questions. Bill
https://support.lawnboy.com/portal/s...ificationsPage
__________________
Old 02-10-2013, 11:49 PM   post #5 of 9
BDM53
Mowerholic
BDM53's Avatar
MTF Member # 70022
Nicely done, some of my best mowers started out as $10 or $20 find.
__________________
Branden
BDM53 is offline   Reply With Quote Quick reply to this message
Old 02-11-2013, 09:49 PM   post #6 of 9
matth8888
MTF Member
matth8888's Avatar
MTF Member # 75894
Garage
ITS ALIVE!!!!
I cleaned the carb and she fired right up!Anything else i should do? Should i clean the muffler ports? Now I wish i could find more 2-stroke Lawn Boys. Down here in Charlotte,N.C I dont see many...
__________________
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
-1990 Bolens 1468
Sold
-Murray 11hp/36"
- 1998 Murray 18/42
Old 02-12-2013, 12:41 AM   post #7 of 9
Yard Nazi
Yard Nazi's Avatar
MTF Member # 64763
Hi! Great to hear you got it running with minimal effort. Since you don't know what has been done to the mower I would check the exhaust ports to be sure they are clear. Sharpen the blade and invest in a new air filter and plug and you should be good to go. At some point if you have access to a way to check RPM's you could see how it is running. Just be sure it's not running too fast. Better that it's a little slow than too fast. Bill
__________________
Old 02-16-2013, 03:06 PM   post #8 of 9
Wolfy
Wolfy's Avatar
MTF Member # 49144
Those f engines are great. It usually is just the carb
__________________
Lawn Boy Bricktop My favorite 5024
19" Gold F Engine Push
Liberty, Bicentennial, International Harvesters
Dad's LB 10550, 10525, 10323, 7023
Wolfy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-17-2013, 11:31 AM   post #9 of 9
BDM53
Mowerholic
BDM53's Avatar
MTF Member # 70022
Quote:
no doubt. Think of how many mowers have been posted here being saved with just a carb rebuild or replacement. Ashamed so many give up on a mower because of it.
__________________
Branden
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
