John Deere 420 good buy? - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-06-2013, 02:32 PM   post #16 of 37
Kuraki
Nothing takes 5 minutes.
Kuraki's Avatar
MTF Member # 80108
Default Re: John Deere 420 good buy?
I would buy it for parts for my 430 and other projects if nothing else. For $500 you could ignore the problems and part the thing out and probably clear $5-600 on it, without a rear PTO.
__________________
JD 430, 60" deck. Model 47 blower. Future: PFE loader/mini hoe, 3pth
Kuraki is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-06-2013, 02:35 PM   post #17 of 37
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Heck, it's in the back of Glockem's C-130 right now.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 02-07-2013, 05:31 PM   post #18 of 37
Lucas in Alaska
MTF Member
MTF Member # 83019
Default Re: John Deere 420 good buy? *update*
Thanks for all the help and input. I talked to the gentleman selling this machine last night. I told him my concerns about the posi not working and me having to buy parts for the front pto to be able to put on a snowblower and we settled on a greatly reduced price. I hope to pick it up in the next two days.
Lucas in Alaska is online now   Reply With Quote Quick reply to this message
Old 02-07-2013, 05:45 PM   post #19 of 37
Diesel332
Diesels are awesome!
Diesel332's Avatar
MTF Member # 80474
Garage
Good buy!
__________________
Mark
1967 110 RF, 1968 112, 1970 112 Patio Spruce Blue, 1973 70, 1973 110 electric lift, 1986 214, 1987 332 Diesel, and 1989 430 Diesel
Diesel332 is offline   Reply With Quote Quick reply to this message
Old 02-07-2013, 06:01 PM   post #20 of 37
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Glad it didn't get away from you.
__________________
Old 02-07-2013, 06:02 PM   post #21 of 37
mrbeef
5000 Strong & Climbing
mrbeef's Avatar
MTF Member # 75839
Garage
Quote:
SAY WHAT....
Congrats! I will be looking forward to a
"My 420 refurb" thread
__________________
A Wonderful Wife that puts up with me, two cats and the dog, and a BAD case of round fenderitis
Tractors:
07' JD X748
88' JD 318 "The Golden Child"
83' JD 214
The Round Fenders: 67' JD 112H, 67' JD 110H "The Frog", 66' JD 110, 65' JD 110, 64' JD 110
In Parts: 65' JD 110, 66' 110H
Former Machines:
60's Power King, 65' JD 110, 66' JD 60, 69' JD 112, 69' JD 140H3, 72' 140 H1, 77' JD 212, 80' JD 317, 80' JD 317, 80' JD 317, 83' JD 318, 84' 420, 86' JD 318, 86' JD 420, 87' JD 430, 87' JD 318, 88' JD 318, 88' JD 318, 88' JD 855, 89' JD 318, 91' JD 430, uk Cab Cadet 2140, 92' JD 320, 93' JD 320, and 01' LX277
mrbeef is online now   Reply With Quote Quick reply to this message
Old 02-07-2013, 06:10 PM   post #22 of 37
ajcan
Senior MTF Member
ajcan's Avatar
MTF Member # 39156
Just to confirm your rear end issue,
Are you saying it won't move unless you engage the locking rear diff and then only one wheel turns?
If that is the case the wheel that will not turn has a broken axle.
Fairly common on the early ones and a fairly easy repair.Tons of used axles available on ePay and other locations.
Like stated I would buy it and dig into it provided you are mechanically inclined.
If you get into and find something too serious then sell the rear pto for $800ish and part out the rest.
On the front pto the extra pulley and extension was an add on kit it is not part of the original front pto.There should be a pulley on the front of the motor with a belt going down to another pulley that drives that center spindle.
Mower deck drive shaft attaches to the back of that to drive the mower deck.
To run front pto equipment a front add on set up was needed.
Good luck.
On edit,There are a couple different pto styles for that rear.The expensive one was a 2000 rpm gear box to run shaft driven rear implements.
There is also a belt driven style that operated a rear bagger that is not worth near as much money.
Just so you don't go in expecting to sell it to fund things and find the less expensive one.
AJ
ajcan is offline   Reply With Quote Quick reply to this message
Old 02-07-2013, 06:57 PM   post #23 of 37
Lucas in Alaska
MTF Member
MTF Member # 83019
Quote:
Originally Posted by mrbeef View Post
SAY WHAT....
Final price was $250
ajcan-
I can't say I know exactly how the drive unit works on these. From what I understand is when you shift out of neutral it starts to drive in posi. when you press the red pedal/button with your right foot only one wheel is engaged.
Please confirm how this works.
What happens on this one is when you shift out of neutral nothing happens then when you depress the red pedal/button (I don't know what is really called) it takes off in one wheel drive, the right wheel. I don't know if it's an axle or linkage adjustment. From what I understand the posi worked when the guy bought it form the city.
The front PTO, there is the pulley in front of the motor and it appears that the lower PTO drive shaft is there but I didn't see the lower PTO pulley or the horizontal belt tensioner.
It has the rear shaft PTO. I visually saw it and saw it turning.
I guess I'll see what I have when I get it home.
Old 02-07-2013, 10:53 PM   post #24 of 37
ajcan
Senior MTF Member
ajcan's Avatar
MTF Member # 39156
Lucas
When you take off out of neutral it should move on its own.When the red button is pushed it goes into lock mode and both wheels will then turn.What you are describing is the left axle is broken.If you move the lever forward and it does not move then the load is being transferred to left wheel and it is not moving.When you engage the posi by pushing the red button both wheels lock and only the right wheel turns so the left axle is broken most likely.Like I said,common for the early units.Used parts are readily available to fix it and I am pretty sure new is still available too.
Sounds like the pto is missing part of it.There should be a belt connecting the two and the lower pulley set up in place.If there is no lower pulley then it was removed at one time for one reason or another.You can snap some pictures when you get it and we can help you figure out what is missing.
On the rear pto both units had a shaft coming from the rear to a clutch.Clutch either attached to a set of pulleys or a gear box.
Again pictures when you get it will clear it up.
Still a definite yes even though it is going to need a good bit of work.You can assess to fix or part it when you get it.Plenty of parts to make way more than the $250 invested.
I will send you private message in a few minutes with some other valuable information.
AJ
Old 02-08-2013, 08:33 PM   post #25 of 37
Lucas in Alaska
MTF Member
MTF Member # 83019
AJ,
Thanks for the help. I'll have to see what I have when I get it home. It sounds like I'm in for a new axle and some parts for the front PTO. I'll keep you posted.
Old 02-08-2013, 11:56 PM   post #26 of 37
ajcan
Senior MTF Member
ajcan's Avatar
MTF Member # 39156
Glad to help Lucas.
I look forward to pictures.
AJ
Old 02-09-2013, 02:14 AM   post #27 of 37
BillCavanaugh
Green with Envy
BillCavanaugh's Avatar
MTF Member # 65575
Buy! Buy! Buy! A non-functioning 420 goes for more than that... and when i say non-functioning... I mean push it on the trailer...
__________________
Nemesis
BillCavanaugh is offline   Reply With Quote Quick reply to this message
Old 02-09-2013, 09:49 AM   post #28 of 37
Diesel332
Diesel332's Avatar
MTF Member # 80474
Garage
BillC is right; I would probably be happy paying for a 420 like yours, but it wouldn't run.
__________________
Mark
Old 02-09-2013, 04:22 PM   post #29 of 37
k91
MTF Member # 19618
Yeah $250 for that?? It would be gone around here weeks ago. Heck I'd try to sneak it home and I just made a major purchase LOL Look forward to a resto thread.
k91 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-09-2013, 08:27 PM   post #30 of 37
FORDLT75
Proud Member of the 1K Club
MTF Member # 78469
Oh yeah i would have bought it for $250. Good buy even with the problems. **** 210's are going for more then that around here.
__________________
1975ish Ford LT75 - Needs carb worth a hoot
1960's Minneapolis Moline - runs
1971 Sears SS14 - Needs nothing runs great.
1980's GTV16 - runs great but deck needs work
1975 Sears SS16
1970's Allis Chalmers 314H and 314V
1960's Simplicity 3314H
FORDLT75 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
