Finally fixed Septic System Permanently - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
My Place Pics and stories about your home and property
Reply
Thread Tools Display Modes
Old 01-28-2013, 01:30 AM   #1
Michael
Retired Mod
MTF Member # 21
Images: 9
Default Finally fixed Septic System Permanently
After four years of having issues with the mound septic system at my place I finally just bit the bullet and had a complete new pump system installed in my tank with a new controller installed. The issues I had were the old floats would last a year and fail which would take out the pump and then over flow into the back yard.
In December the county sent me a not so nice letter saying that all systems in my neighborhood had to comply with new rules and that I had 2 months to comply, so I called a approved company that was listed and had them do a complete in tank replacement with a new pump, transducer, risers, new baffles, filter and a complete new electrical system with new controller. The whole system is now electronic controlled so no more clunk from the old mechanical controller. I was really surprised that the new controller is silent compared to the old controller. The reason I wanted new electrical hook up as the old electric system was direct burial of the lines to the back side of my new garage and I knew that this was not code. I also wanted the electrical hookup into the houses breaker box.
I hired the company after they sent me a bid that was a bit high priced but they also had a 3 year warranty on everything they did. I also signed a contract with them to perform yearly maintenance for five years (I am required to have yearly maintenance by the county as this is one of the new rules)
I did save some money as I did all the digging in my back yard and I will do the finish work as I did not want the cost of having someone else do the digging when I had my JD 2305 with a backhoe. When my electrician (who happens to be my neighbor) showed up he ask me where was the tench and I said where do you want it and how deep, he laid it out and I went to my tractor shed and got the 2305 out and he said I cheated him, I asked why and he said "I figured that you were going to dig it out with a shovel" The finish work can be done next spring after our winter rains are over.
So the cost was $550.00 for the tank pump out, $2600.00 for the new system and my sparky (electrician) was another $500.00
The rest of the system including the tanks, the plumbing and the mound were in great shape and passed all test as required by the county.
__________________
Michael is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-07-2013, 11:57 AM   #2
MacLawn
外人Geezer MTF Member
MacLawn's Avatar
MTF Member # 6284
Default Re: Finally fixed Septic System Permanently
Great to know your 2305 did the job for you!
__________________
That old man - he don't think like an old man...
Now I wouldn't want to be within 400 - 500 yards of one of them nuclear bombs when it goes off, I tell ye! WW1 Vet Old Man
"He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive".
Dirt, it's nothing but dirt, I tell ye...
"I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
MacLawn is offline   Reply With Quote
Old 02-07-2013, 12:03 PM   #3
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
You know this Michael...
__________________
SonnyT is offline   Reply With Quote
Old 02-07-2013, 03:07 PM   #4
Michael
Retired Mod
MTF Member # 21
Images: 9
For some reason when I attempt posting pictures the manage attachment window starts then goes white and nothing happens. I tried clearing all cookies and tried even running Firefox and Safari the issue is on both versions. I would try my iPhone but I have not had the time to try from there if it even would allow me to post from phone.
__________________
Old 02-07-2013, 04:34 PM   #5
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Sounds like a good job to have done and over with and no worries for the foreseeable future.
You can always link photos from a hosting site, or email them to me and I'll put them in if you like.
Nice to see you on again!
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote
Old 02-10-2013, 09:49 PM   #6
Michael
Retired Mod
MTF Member # 21
Images: 9
Well I finally got all the bills and it was $2,890 for the controller, pump, ground lever covers on the septic tank (4 each) new transducer with new connections. The septic repair company did one additional thing and it was flush the lines of the mound and put in ground level maintenance plugs on the mound runners. I had to get a pump out of my septic system and it was $753 for 2,000 gallons. The bill from my electrician was $983.00 for wiring the pump to the controller, wiring from the house to the controller this also included the cost of the electrical permit required to connect to the house.
I think that the issues are finally solved for the septic and everything done is under warranty for 3 years.
All testing by the septic repair company after the repairs and the setup of the system is showing good operation of the system, this was all due to the changing the rules by the county requiring yearly inspection and maintenance but I also annoyed by the fact that the system was really worn out in the tank and doing the repair with all new equipment in the tank with a new controller should take care of the system for the next ten years. When we pulled the old control box from the small post under my back deck it was rusted out on the under side of it. The new control box is made out fiberglass and should take the elements better as I also had it mounted a lot higher on the side of the house.
So basically I have a new pump system on a 20 year old septic tank and mound.
__________________
Old 02-21-2013, 05:33 PM   #7
racer4
Senior MTF Member
racer4's Avatar
MTF Member # 12108
Glad to see you used a filter. I just saw one of those for the first time on a renovation job we just did which involved new tanks. I like the idea of keeping stuff out of the drainfield (or mound). Ground level risers are nice too, and you can hide the with something decorative. Beats the **** out of trying to find the lid underground. We do property maintenance on about 40 vacation houses and I can't tell you how many hours I've spent looking for tanks and lids with a piece of steel rod and a hammer! Sucks you have to get a mandated yearly maintenance though. What exactly does that involve? Flushing the pipes? That should be unnecessary with a filter installed, right?
__________________
2010 MF 2410TLB
Woods 60" Landscape rake w/ guide wheels
MacKissic 3pt chipper
2000 314-8 with electric lift
numerous attachments
racer4 is offline   Reply With Quote
Old 02-21-2013, 09:45 PM   #8
rockford
Proud Member of the 1K Club
MTF Member # 26868
You got easy! On an island made of lava and coral you dig six inches down and hit solid rock! Now the gummint making everyone hook up to sewer, and it is expensive! We pay around $250 a month sewer charges, and they keep raising it to pay for everything else>
rockford is offline   Reply With Quote
Old 02-22-2013, 08:16 AM   #9
witco
Senior MTF Member
MTF Member # 25722
I ve done septic work and have held a liscense (inactive at this time). I am a big beleiver of filters and added one to my system when I installed new latterals. Only three of use living at home now. I have my system pumped every 2/3 years and pull the filter and clean it. You will be suprised what that thing will stop from going out to the latterals. I would tell my customers that their systems were just a very large "filters" and the cleaner the stuff you put through it and the more you maintain it the longer it should last.
witco is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-23-2013, 04:44 AM   #10
Michael
Retired Mod
MTF Member # 21
Images: 9
Because we are in a watershed that has high levels of fecal chloroform we are now required to have yearly maintenance and inspections. Our system is 20 years old and a mound system because my property has a lot of clay in it.
The inspection is to check the sludge layer, scum layer, the operation of the pump system, cleaning the filter, flushing the mound and checking the operation of the laterals.
Since I decided not to have repairs but to replace everything in the pump chamber and have the ground level risors installed. I am getting a $200 rebate for the inspection and $150.00 for the risors.
The filters are required on all systems in our area as the filter really do protect the mounds.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
