Brush Grubber with a Deere - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-19-2013, 08:11 PM   post #46 of 126
KWDAILYD
8K poster and enjoying it
KWDAILYD's Avatar
Default Re: Brush Grubber with a Deere
Quote:
Originally Posted by Hostaman View Post
You're right, I may give the pallet forks a try. If I clamp them on real tight and keep the chain right close to the bucket, maybe even in the clamp it might work.
Clamp it close to the side of the bucket for more strength.
__________________
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 6 JD suitcase weights. 2-50# cast rear wheel weights.
Thread for 110 RF build http://www.mytractorforum.com/showthread.php?t=287161
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-19-2013, 08:20 PM   post #47 of 126
Hostaman
...and Buddy The Dog
Hostaman's Avatar
MTF Member # 75709
Quote:
Good advice, thanks.
__________________
JOHN DEERE X729(2012)
54" Deck w/BM20827 Mulch Kit, 45 Loader, JD BM23882 Cat 1 3PH, JD LPHDC18JD 18 CuFt Cart, JD LP22862 25 Gallon Sprayer, JD LPPA48JD 48" Core Aerator, JD LP25001 3-Point Receiver Hitch, JD BM17972 50 lb. Cast Wheel Weights, JD BM22725 Wheel Spacers, Custom Heavy Hitch, *TOMBSTONE Ballast Slab, Eight Suitcase Weights, Fluid Filled HDAPs on Stock Wheels, Turfs on SE Wheels, SE Seat, Brush Guard, Click-N-Go Weight Bracket (Modified to hold eight suitcase weights)
named by PA318Guy
Hostaman is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 02:13 AM   post #48 of 126
rockford
Proud Member of the 1K Club
MTF Member # 26868
Thumbs up Re: Brush Grubber with a Deere
Quote:
Originally Posted by jpa2002 View Post
If you are pulling up small stuff, get the small grubber chain! I have both, but the grubber chain is a beast.
Jon
Thanks, I've been waiting to see if anyone had used the chain. I'm gonna order me one for stuff too small for the grubber.
rockford is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 08:39 AM   post #49 of 126
Tulkas
MTF Member
MTF Member # 76714
I'm not too happy with the "Tombstone" tonight, had to pick it up to get some measurements and I'm hurting. I've got to find a better way to handle it.
I drop my ballast box down on a movers dolly, they will hold 1000 lbs. then I can just wheel the box around the garage to where I store it when I have the BH on.
Tulkas is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 10:07 AM   post #50 of 126
Ransx77
MTF Member
Ransx77's Avatar
MTF Member # 82701
I'm planning on using a grabber to pull the buried broken end of fence posts from the ground so I can get a new one in with minimal digging. I have a boom pole and also Ken's Bolt on Hook's on the FEL and a set on the JDQH Forks.
__________________
2012 John Deere 1026R
H-120 FEL, 60D MMM, iMatch, Heavyhitch, BB5060L, LR5060L,
Sundowner Forks for JDQA, Boom Pole, Shaver Post Hole Digger
Tow Behind: Trac-Vac 880, 15 year old Ohio Steel Trailer (begging for a JD green paint job)
Stihl: MS180CB-E; MS391; HT101; FS110; HS81T; SR360
Bees, Chickens, Maremmas, and Corgis.
Ransx77 is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 10:36 AM   post #51 of 126
gman2304
Senior MTF Member
MTF Member # 29419
I've been using a heavy logging chain wrapped tightly around the base of shrubs and small trees. My 332 pulls them out with very little effort. If I had a lot to do I could see how the grubber would do a good job and be easier to work with.
gman2304 is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 03:52 PM   post #52 of 126
Hostaman
Hostaman's Avatar
MTF Member # 75709
Quote:
Just ordered two bolt on hooks, thanks for the link>
__________________
named by PA318Guy
Old 02-20-2013, 04:00 PM   post #53 of 126
Hostaman
Hostaman's Avatar
MTF Member # 75709
Quote:
Thanks for the suggestion. I too have a dolly however two pins protrude down from the bottom of the TOMBSTONE and extend through the flange that was welded onto my BB. This was a classic case of over-execution because I didn't want the TOMBSTONE to move around on the the back of the BB. Fact is, at 175 lbs it is not going to come off. I have now installed an overhead electric hoist to pick it up while I set the BB onto the dolly.
__________________
named by PA318Guy
Old 02-20-2013, 06:26 PM   post #54 of 126
Hostaman
Hostaman's Avatar
MTF Member # 75709
Just received an email from Ken at Kens Bolt on Hook's. He will be shipping my hooks out tomorrow. This is something that I've been wanting on my FEL all along. I see the hooks being very useful for many things including using the Brush Grubber. Thanks again for the link.
__________________
named by PA318Guy
Old 02-20-2013, 06:37 PM   post #55 of 126
Ransx77
MTF Member
Ransx77's Avatar
MTF Member # 82701
My pleasure. I have to tell you, working with Ken is amazing. He will do anything he can to help you out. I just finished painting mine green, will be mounting them this weekend.
Randy
__________________
Old 02-20-2013, 07:15 PM   post #56 of 126
SilverGhost
"The Shadow Knows"
SilverGhost's Avatar
Location: Northern Virginia 20 miles from Scenic Skyline Drive
MTF Member # 69214
You folks have me all excited about the Brush Grubber. In the Norther Virginia Piedmont, we are being attacked by an extremely invasive bush call the Autumn Olive. They will take over your entire property if not addressed. They grow up to 20 feet tall, and 4" in diameter. If you cut them down, or burn them, they come back with a vengeance. Once they leaf, they grow 4" thorns along the branches, so you can't get near them.
I had hundreds before I tackled them one winter. I cut them down, small ones with a lopper, larger ones with a chain saw, then coated the stumps with the strongest stump killer I could find. They came right back. They grow a sweet berry in the spring which are eaten by birds, then spread from bird droppings. When they came back, I cut them again and this time sprayed the stumps with Roundup. It killed some, some came back. Every time I see new leaves on the stumps, I spray Roundup. This is slowly killing them off.
I have too many mature trees to get to them with a Bobcat, as one neighbor did. As soon as I saw this thread, and read the posts, I went to Amazon and ordered one. I think the roots are fairly shallow, so am expecting the X500 to pop them out of the ground. The ground is soaked from steady rains all winter, so that will help.
The Brush Grabber arrives Friday. The first day of no rain, I'm starting. At this point I have dozens to pull up, not hundreds. Wish me luck................
Oh, and once again - Thank You all for providing another way I can get some seat time on my John Deere!
__________________
2012 John Deere X-500, 48" deck
Johnny Bucket Jr bucket and plow
Single Bucket Holder
Tilt Trailer
25 gal. spot Sprayer
Agri-Fab plug aerator and tine aerator
Precision Products 130 lb tow broadcast spreader
Stihl Ms250 chain saw
Echo PB25 leaf blower & SRM225 string trimmer
Generac 7500w backup generator
100 lb. German Shepherd "Shadow"
2000 Harley Davidson Road King
SilverGhost is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 07:33 PM   post #57 of 126
kennyd
Senior MTF Member
kennyd's Avatar
MTF Member # 50540
Thanks for the referral!
Thanks for the order!
__________________
John Deere 4110HST
FEL, MMM, Artillian 42" Forks, I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Our YouTube Channel
Simple JDParts Tutorial HERE
Also check out www.greentractortalk.com
kennyd is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 08:22 PM   post #58 of 126
Hostaman
Hostaman's Avatar
MTF Member # 75709
Well Ken, I'm even happier to learn that the fine product that I have purchased is provided by a fellow MTF Poster. I can't wait to get them painted and installed. If I can find the dog and get the camera back I will post some pics.
__________________
named by PA318Guy
Old 02-20-2013, 08:40 PM   post #59 of 126
Hostaman
Hostaman's Avatar
MTF Member # 75709
Quote:
Think about using something to help with the upward tension on the bush. Some have spoken of a wheel, empty propane tank, something like that. The section of pipe that I used worked great. The Brush Grubber UTube video shows the tree being pulled from about 3 feet above the ground and seemed to work as well. Sounds like you've got plenty of practice ahead of you so be sure to let us know what nets the best results.
__________________
named by PA318Guy
Sponsored Links
Advertisement
Old 02-20-2013, 11:13 PM   post #60 of 126
KWDAILYD
KWDAILYD's Avatar
Everytime you get on here you spen money!
__________________
Just call me Larry
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
