Kohler K321 rebuild questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 12-24-2012, 01:40 PM   post #1 of 9
nick4030
Dirt Player-iner
nick4030's Avatar
MTF Member # 53593
Default Kohler K321 rebuild questions
I am in the process of rebuilding the K321 in my '73 JD 140H3. It was smoking so I sent it to the machine shop. New valves and guides and 0.010" over and polished crank and I just picked it up. The machinist did a pretty good job cleaning it after machining, but I decided that I wanted to clean the main bearings even more rather than trust the machinist. I pulled the cam and got the bearings out and they were a little rough turning due to machining particles so I cleaned them thoroughly and now they roll nice and smooth again. My question is this- if I lay the bearings down flat on the table, the inner race has a little bit of play vertically to the outer race if that makes sense. How much play is normal? Is it worn or is that normal to have a little play there? There is no play in the other direction as if I were trying to move the races towards each other. No play at all, but there is a little the other direction as I was saying. If I installed them would it give the crank endplay or is that even possible? I know most people do not replace them and I don't want to have too but I will if it is needed. -Nick
__________________
1974 Case 646
1961 Cub Cadet Original
1991 John Deere 332
1975 John Deere 300
1973 John Deere 110
1979 Sears LT10 36 (restored, it was my first tractor)
nick4030 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-24-2012, 03:23 PM   post #2 of 9
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Default Re: Kohler K321 rebuild questions
These big ball gearings also act as thrust bearings, so some side ot side wear is normal, As to how much play is acceptable..i dunno, never had one bad enough to send up any red flags so far.
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Old 12-24-2012, 06:26 PM   post #3 of 9
nick4030
Dirt Player-iner
nick4030's Avatar
MTF Member # 53593
Well we did the best we could and checked them with a dial indicator. It looks to be 0.003"-0.004" for one bearing and 0.004"-0.005" for the other. It feels like a lot, but apparently its not. At least that doesn't seem like a lot to me, maybe someone could check some that they have?
On a different note, is there anything I need to check out with the governor gear before assembly?
__________________
1974 Case 646
1991 John Deere 332
1975 John Deere 300
1973 John Deere 110
Old 12-24-2012, 06:44 PM   post #4 of 9
WNYTractorTinkerer
5000 Strong & Climbing
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: Kohler K321 rebuild questions
Consult the Kohler Service Manual for any questions and guidance Nick. Here's a link: Kohler K-series Service Manual
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is offline   Reply With Quote Quick reply to this message
Old 12-24-2012, 09:01 PM   post #5 of 9
nick4030
Dirt Player-iner
nick4030's Avatar
MTF Member # 53593
Thanks for the link, I was actually using the manual to remove the camshaft and it didn't even dawn on me to check it for bearing specs. It is actually very vague with these bearings though. Just says do not replace unless they are out of running specifications. Does not say what those are. I think they are probably just fine. Unless I can find them super cheap, they will get reused. The manual did say to check the governor gear for wear, chipping or cracking teeth; if they are absent, it is fine. Thanks for your help Red and WNY! -Nick
__________________
1974 Case 646
1991 John Deere 332
1975 John Deere 300
1973 John Deere 110
Old 12-24-2012, 09:34 PM   post #6 of 9
WNYTractorTinkerer
MTF Member # 26264
Images: 13
Garage
3-4 thousandths is pretty tight in my book..
**Is is the measurement vertical or horizontal to the C/shaft's axis?
You don't want the crankshaft pushing on the crank-case, bearing mounts rod & piston pin (thus the piston).. If I remember right the manual lists crank clearances in the specifications charts in the manual. If it's loose you can install shims.. Take a look there..
Old 12-24-2012, 09:40 PM   post #7 of 9
nick4030
Dirt Player-iner
nick4030's Avatar
MTF Member # 53593
So it says crankshaft endplay for a K321 is 0.003"-0.020" if that clearance is coming from the bearings, it is still in spec?
__________________
1974 Case 646
1991 John Deere 332
1975 John Deere 300
1973 John Deere 110
Old 12-24-2012, 09:51 PM   post #8 of 9
nick4030
Dirt Player-iner
nick4030's Avatar
MTF Member # 53593
Another interesting thing I found, each bearing were different brands, meaning someone must have replaced one at some point. That tells me that since they both have about the same wear, they must have a couple thousandths when new?
__________________
1974 Case 646
1991 John Deere 332
1975 John Deere 300
1973 John Deere 110
Sponsored Links
Advertisement
Old 12-25-2012, 12:03 AM   post #9 of 9
Bolens Nate
Senior MTF Member
MTF Member # 80844
You have to have some clearance between the balls and the races for the oil film, when the motor is running and the bearings are full of oil it takes up the clearance. This is the same concept as journal bearings and why they need clearance.
Nate
__________________
Allis Chalmers B-12: Front, center, and rear PTO; Hydraulic lift; Two-speed pulley; Front and rear work lights; Rear stinger and doughnut weights; and Bolens outer cast wheel weights w/ Cub Cadet cast inner weights
Still needed: Right hand lift, ball hitch, sleeve hitch, and front counterweight.
Bolens 1250 Repowered with Briggs 32 cube iron single
Bolens Nate is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
