D100 wont start - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-17-2012, 11:48 AM   #16
TexasUltra
MTF Junior Poster
TexasUltra's Avatar
MTF Member # 81544
Default Re: D100 wont start
So I google RIO relay...
This it what I find.
TexasUltra is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-17-2012, 11:56 AM   #17
ryanpf
L120/G110 Hybridizer
ryanpf's Avatar
MTF Member # 31574
Quote:
Originally Posted by TexasUltra View Post
From Acronym Finder website...
** RIO Reverse Implement Option (riding lawnmowers) ???
What does it do?
Is there a test for it?
The relay is part of the circuit that shuts off the engine if you try to mow in reverse without taking the proper (JD definition) actions to keep the blades spinning. To test if it's working, engage the deck and try to mow in reverse. Unless you press the button on the dash first, the engine will quit. If it doesn't, the circuit has been "defeated".
Did you find your light problem?
__________________
L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline   Reply With Quote
Old 12-17-2012, 12:20 PM   #18
TexasUltra
MTF Junior Poster
TexasUltra's Avatar
MTF Member # 81544
A little more specific...John Deere RIO relay search
Question:
Why is RIO (Reverse Implement Option) Necessary?
Affected Equipment:
Riding Mowers
Answer:
Throughout our history, John Deere has been concerned about the safe operation of its equipment. John Deere lawn care products have been leaders in safety innovation. It is one of the reasons they continue to have the highest resale value in the industry. Anyone who can imagine the tragedy of an accident can readily appreciate effective designs that improve the safety of the products they use. The following is a chronology of some major John Deere safety features:
PTO Starting Interlock 110 Tractor - 1963
Transmission Starting Interlock 110 Tractor - 1963
Seat Switch PTO Interlock Riding Mowers, 100-400 Tractors - 1977
Brake Starting Interlock 111 Hydro Lawn Tractor - 1982
Seat Switch Interlock Delay 300, 400 Series Tractors - 1984
Blade Contact Pictorial Decal Mower Decks - 1989
Discharge Door 60-inch Power Flow Blower - 1993
Reverse Implement Option (RIO) Riding Mowers & Tractors - 1999
RIO is a well-thought-out design feature. After years of study and with the use of innovative technology and components, the engineers at John Deere developed a RIO system that is both easy to use and effective. It is less restrictive than the design on many competitive brands that will not allow the operation of the mower or other attachment to be maintained while moving backward under any circumstances. It is also more effective than systems that provide no safety reminder or those that can be turned off by the operator. The John Deere system provides a safety reminder each time the vehicle is moved backward, but will allow the operator to maintain power to the mower or other implement when it is necessary to do so.
You should always look behind you before moving in reverse to make sure that all people, especially children, as well as pets, are out of harm's way. Sometimes it is possible to get caught up in maneuvering and forget about looking behind you before driving in reverse. RIO provides a reminder by requiring you to engage a switch each time you want to keep a mower or implement operating when moving backward. Its intent is not to slow you down, but to help you operate as safely as possible. We regret any inconvenience, but safety is so important, we believe it is necessary to include this feature.
RIO is an exclusive John Deere feature to remind the operator of safety before moving in reverse. Mowing in reverse is not recommended; however, we want to make sure you are aware that RIO allows you to keep the mower or other implement operating while backing up, if necessary. And you only need to activate the RIO switch for an instant before putting your hand back on the steering wheel. We hope you are already aware of this, but we have found that some customers who have expressed concern about the RIO system were not. If you do not know how to operate RIO, please consult your Operator's Manual.
Old 12-17-2012, 12:26 PM   #19
TexasUltra
MTF Junior Poster
TexasUltra's Avatar
MTF Member # 81544
Did you find your light problem?[/QUOTE]
No, not yet. I'll trace out the wires later in the week, and check to see if there is power @ the headlight. At the rate I'm going it could be a burned out bulb.
Old 12-17-2012, 12:28 PM   #20
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Not sure about the D Series, but alot of Tractor lights work off the AC power, then converted to DC, so the engine has to be running to supply the AC Voltage.
__________________
SonnyT is offline   Reply With Quote
Old 12-17-2012, 12:35 PM   #21
Dan33Klein
2000 Posts and climbing!!!
Dan33Klein's Avatar
MTF Member # 55503
Quote:
Lights should work work with motor off
__________________
2000 John deere 455 Diesel.
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/showthread.php?t=178233
http://www.mytractorforum.com/showthread.php?t=214280
Dan33Klein is offline   Reply With Quote
Old 01-22-2013, 05:55 PM   #22
TexasUltra
MTF Junior Poster
TexasUltra's Avatar
MTF Member # 81544
No, not yet. I'll trace out the wires later in the week, and check to see if there is power @ the headlight. At the rate I'm going it could be a burned out bulb.[/QUOTE]
So, that was it...burned out both bulbs at some point during the process. All is well in paradise.
Sponsored Links
Advertisement
Old 01-22-2013, 06:31 PM   #23
KATT
5000 Strong & Climbing
KATT's Avatar
MTF Member # 34056
What does it do?
You forgot RIO Shuts off you impliment ( mower in this case ) when going into reverse ....ergo RIO
KATT is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
