Ross Steering rebuild video - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-01-2012, 07:12 PM   post #1 of 5
FORD_LGT_165
Senior MTF Member
FORD_LGT_165's Avatar
MTF Member # 29335
Default Ross Steering rebuild video
Just made this video today. Hope it helps out.
Cheers
http://youtu.be/qIxYUmPLRzM
FORD_LGT_165 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-01-2012, 07:47 PM   post #2 of 5
JRC IOWA
Senior MTF Member
JRC IOWA's Avatar
MTF Member # 4622
Images: 21
Default Re: Ross Steering rebuild video
Thanks for the video i have a extra ross that i would like to rebuild and this will help a lot
CC 3235
CC 1882
CC 1872
CC IH 123
__________________
JRC IOWA is offline   Reply With Quote Quick reply to this message
Old 12-02-2012, 12:21 AM   post #3 of 5
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Thanks I Copied & added this to the Cub Cadet FAQ
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is online now   Reply With Quote Quick reply to this message
Old 12-02-2012, 12:24 AM   post #4 of 5
Merk
Senior MTF Member
Merk's Avatar
MTF Member # 1431
Your video is a good start. There are a few more things I do.
1. The stud usually had some wear/flat spots on it. It needs be replaced or if you have access to a lathe it can be turned to remove the flat spots.
2. You need to check the package seal/retainer to make sure they are ok. I have had several seals that were torn or missing and the retainer in not very good shape. Grease and dirt can get between the lever and bolt assembly (Cub Cadet discription) and cause wear. Replace as needed.
3. Most times the retainer/ball assembly can be cleaned and reused.
4. I use a lite duty grease when I repack the steering assembly. The grease will fill in the areas when the steering gear and stud make contact. I use John Deere's corn header grease.
5. Most of International Harvester Cub Cadets have a plastic bushing at the top of the steering tube. I replace the bushing with the same bearing that I use in the front wheels of a IH Cub Cadet.
6. I use 2 washers, flat roller bearing and a lock nut to hold the lever and bolt assembly. It is cheaper and so far been trouble free for the last 8 years on 3 IH Cub Cadets (70-100-149).
Everyone that drives my Cubs thinks they have power steering.
__________________
Just trying to help
Merk is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-24-2012, 01:30 PM   post #5 of 5
DAC
MTF Junior Poster
DAC's Avatar
MTF Member # 71711
Is is really possible to remove all the play from the steering assembly? Never have owned a new tractor, thus it's been my belief that at least 1" of play was normal. I will pull in all six tractors and get busy if it can be done.
__________________
Current Machines:
Cub Cadet: 2082, 1862, 1541, 1440
John Deere: 100
Toro: 16-38 HXL
Alex in Cincinnati
DAC is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
