Model 49 snowblower sprocket upgrade step by step - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-06-2012, 04:52 PM   post #31 of 53
TNTFarms
Senior MTF Member
TNTFarms's Avatar
MTF Member # 39999
Default Re: Model 49 snowblower sprocket upgrade step by step
gcaldicott - thanks for the tip, it doesn't appear that mine is going to hit but I will be sure to check it before I bolt the cover back on.
dan33klein - that makes two of us
__________________
07 Hustler Z, Deere -87 - 332, 88 - 322, 90 - 318, 68 - 140 H3, 67 - 112 round fender, , Power flow belt drive, model 30 tiller, model 49 snow blower, 54 blade, Brinly - 2 3pt plows and 1 3pt disc, 79 Troybilt horse, 86 Troybilt pony, 68 - Wheel Horse commando 8
TNTFarms is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-08-2012, 05:41 PM   post #32 of 53
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
I posted this on another thread discussing the same ?upgrade.
Quote:
I have yet to see a GT with an engine big enough that a full bite of snow will not bog it down without reducing forward speed. The engine will only produce enough power to throw a given weight of snow a specific distance. A change in anything that is part of that equation will change the other values in the equation if the engine output remains the same.
More distance with the same engine means slower forward progress. Or, to put it another way, how far can you throw an engine? Now, throw it another 3' further without reducing its weight.
Commercial snowblowers are rated for tons of snow/hour that can be moved. If they need to move more than that, the engine has to be upgraded.
How well balanced is the impeller for your blower?
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 08:31 PM   post #33 of 53
BillNole
Senior MTF Member
BillNole's Avatar
MTF Member # 51394
Quote:
I saw your comment in the other thread as well Bob and it certainly bears consideration. I've yet to see a video or hear direct commentary from anyone regarding their results in deep/heavy/wet snow with the increased rpm's and would like to very much.
Another concern I have involves trepidation regarding the effects of the increased rpm's when finding a buried shoe or boot or wet rolled-up newspaper or even a curb with all that rotating mass spinning even faster than before. (It concerns me even at stock rpm's...) I fear the whole blower leaping into the air and smashing against the front of my hood, making a messy dent at the very best. I fear parts and pieces flying off the blower as it disintegrates at worst.
I tend toward the conservative side of things and may be concerned over nothing. An increase of 10 or 20% in rpm's probably wouldn't make any real difference in anything, but doubling it seems to me that it could get down right dangerous!
Thoughts anyone?
__________________
2011 Hitachi RB24EAP Leaf Blower
2010 Snapper LT2044 w/Blower and Snow/Dozer Blade w/Electric Lift
2010 Dolmar PS-460 Chainsaw w/18" and 20" Bars
2009 Snapper SPV211E Walk Behind Mower
2008 Airens 824E Walk Behind Dual-Stage Snow Blower
2002 Home Made 25 Ton H/V Log Splitter
'Don't cry because it's over. Smile because it happened.' - Theodore Geisel aka Dr. Seuss
ALWAYS FALL UP!
BillNole is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:00 PM   post #34 of 53
Leinie
Proud Member of the 1K Club
MTF Member # 68641
I don't think anyone was contemplating doubling the speed.
Leinie is online now   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:10 PM   post #35 of 53
BillNole
Senior MTF Member
BillNole's Avatar
MTF Member # 51394
Quote:
I saw reference to someone using a 22 tooth pulley. I didn't do the math but...
It was more rhetorical anyway. A 10% or even 20% increase isn't likely to result in any real changes either way. In order to realize any real gain in distance, something more will likely be required and that to me seems to be when things would start getting dicey.
The OEM's have to be concerned with product liability and thus err on the side of safety. There's something to be said for that...
__________________
ALWAYS FALL UP!
Old 12-09-2012, 10:09 PM   post #36 of 53
TNTFarms
Senior MTF Member
TNTFarms's Avatar
MTF Member # 39999
I only wanted to increase my speed a little bit. And with such little change I am sure it may will work my 322's 18 horsepower yanmar harder but that is okay. As you mentioned in deeper snow you would have to slow down, well I would have had to go slower anyway. Just as with tilling the harder the ground the slower I have to go. I have seen a lot of guys do the upgrade and I just wanted to try it. I still have my factory gear in the even that I don't care for the performance. Here are the numbers for different sprockets.
40T = 88rpm stock
36T = 98rpm +11%
34T = 104rpm +18%
32T = 110rpm +25%
30T = 117rpm +33%
I agree that going to a 22 tooth would be crazy and there is no where near enough horsepower. Also has been stated in other threads these blowers were made for tractors with as low as 12 horsepower. I have 18 and an inline three so I should be okay with my 34 tooth.
__________________
Old 12-10-2012, 10:35 AM   post #37 of 53
Allsystemz
Senior MTF Member
Allsystemz's Avatar
MTF Member # 49092
Images: 4
Quote:
Thoughts anyone?
Good point.
On mine with a 30 tooth, it ate a rolled up newspaper last winter and immediately the PTO belt broke.
I don't know for sure but I think the belt is going to be the weak link in the system, somethings gotta give and it may as well be the belt.
Allsystemz is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 04:59 PM   post #38 of 53
jwakeman
MTF Junior Poster
jwakeman's Avatar
MTF Member # 75990
Quote:
Originally Posted by gcaldicott View Post
I replaced my 40T with a 34T from Surplus Center. The only issue that I had was that the hub diameter is significantly larger than on the 40T that has a hub on both sides. The larger diameter hub on the 34T resulted in rubbing on the inside of the cover. The cone shape bump out on the cover isn't wide enough for the larger diameter hub. I ground the corner of the new hub at a 45 degree angle so that it wouldn't hit the cover. I didn't have to take too much off to get the clearance necessary.
This weekend I replaced my sprocket to a 30T from Surplus Center, and am not able to put the side cover back on. To get the chain to line up, I had to install the sprocket hub-side facing inwards, which may make a difference. Tonight I may try again, but flipping the sprocket and see if I can line up the chain.
jwakeman is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 01:35 PM   post #39 of 53
yardwork
Senior MTF Member
yardwork's Avatar
MTF Member # 20413
Its interesting to note that i watched this video and then tried to find out if he posted a follow-up clip showing how the 22T sprocket worked. Well he did, but not in the way you'd think. One of his next videos shows his model 49 sans gearbox because it blew on him, he then proceeds to show the viewers the 54" plow he got. Rut-roh.
He says he stripped the teeth so when something had to give, the gears did. The teeth on sprocket had a shearing force lower than what the snow against the impeller produced. I also speculate doubling the speed was more than the gearbox lube could handle.
Quote:
Originally Posted by itsjojo View Post
Here is an interesting youtube video. I have watched this guy on youtube. He has a 332 where he puts a 22? tooth pully on. You may want to watch him. I think yours is a Diesel too isn't it? Perhaps the diesel torque can push a smaller pully without bogging....
check the end of this video, he talks a little about it and you can see it.
http://www.youtube.com/watch?v=Tla500YrrJQ
__________________
1985 JD 318 aka "Overkill"
yardwork is online now   Reply With Quote Quick reply to this message
Old 12-11-2012, 03:44 PM   post #40 of 53
esnb74
Desk by Day/Shop by Night
esnb74's Avatar
MTF Member # 43409
Images: 8
I found that a 1" smaller drive pulley was a lot easier way to speed up mine. Works great.
__________________
JD 318 H3
JD 140 H1 Mods coming slowly: http://www.mytractorforum.com/showthread.php?t=290386
CC 124 (Future Mini Farmall build)
CC 1250 (Future IHC 966 Tribute build)
Farmall H (One of the many Farmall's I grew up with)
Ford Mustang (64.5)
Past Equipment: JD 316, JD 318, JD 757 Ztrak, IHC 1100A Pickup, CC 3235
Remember: Freedom Isn't Free!
esnb74 is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 04:17 PM   post #41 of 53
whateverweasel
Senior MTF Member
MTF Member # 35595
Except I think you just slowed it down. You'd need to go bigger on the drive-side to speed it up.
/WW
whateverweasel is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 04:30 PM   post #42 of 53
318JD
MTF Member
MTF Member # 63166
Quote:
I have also seen on one youtube video where the guy had changed the sprocket and the side shield didn't fit back. What he did was cut a hole in the guard same size as the dished out part where the socket sits. It looked really good and did the trick.
318JD is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 04:59 PM   post #43 of 53
esnb74
esnb74's Avatar
MTF Member # 43409
Images: 8
Quote:
/WW
Nope. Smaller = faster. Just like everyone goes to a smaller sprocket to speed it up, whether it is the drive pulley or sprocket - it makes no difference. The only downside to doing the smaller pulley is that the gearbox also turns faster and could produce more wear. I wasn't concerned with that as it isn't that much faster and I don't run WOT that often anyway. My pulley was bend anyway, and had to be changed regardless. With my modern style spout mod, the snow flies great at 3/4 throttle.
__________________
JD 318 H3
Ford Mustang (64.5)
Old 12-11-2012, 05:45 PM   post #44 of 53
whateverweasel
Senior MTF Member
MTF Member # 35595
Not to belabor this, but to avoid future confusion it doesn't really work that way. Putting a smaller drive sprocket on doesn't speed up the 'gearbox' -- only the throttle can do that. (or some upstream gearing change) Make sense?
To increase final shaft speed: bigger drive gear/pulley or smaller driven gear/pulley, or both.
(all at the expense of torque)
/WW
Sponsored Links
Advertisement
Old 12-11-2012, 08:04 PM   post #45 of 53
theroosterb
MTF Member
MTF Member # 63313
He did not change the drive sprocket.
He changed the pulley on the gear box to a smaller one.
At least that is the way I understand it.
So he did speed up the gear box and auger speed.
__________________
318- for mowing and 54 blade for plowing
71 140 H3- with cozy cab and 49 blower
66 model 60- fully restored - just for shows
theroosterb is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
