table saw arbor bearings - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
Reply
Thread Tools Display Modes
Old 11-07-2012, 06:16 AM   post #1 of 4
yellowcat
Senior MTF Member
yellowcat's Avatar
MTF Member # 70302
Default table saw arbor bearings
I was trying my new bearings out and slipping them in the arbor housing and notice they slip in with not much effort. They are a good tight fit on the shaft though. Does anyone have experience with bearings and how tight they should fit? This size was the correct size for this job... 6202RS bearings. I thought maybe you had to press both in with a lot of pressure but I hear some can have a slip fit also..but how much is a slip fit? Pressing in and slipping in by hand is acceptable? I made a video to get a better idea.
http://www.youtube.com/watch?v=2-gJ6MdtBCo
yellowcat is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-07-2012, 06:41 AM   post #2 of 4
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Default Re: table saw arbor bearings
What you need is bearing retainer....
http://www.henkelna.com/markets-41/l...ound-15495.htm
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 11-08-2012, 02:53 AM   post #3 of 4
yellowcat
Senior MTF Member
yellowcat's Avatar
MTF Member # 70302
Thanks..I did not know they made Loctite for bearings. This should do the trick.
Sponsored Links
Advertisement
Old 01-01-2013, 11:31 PM   post #4 of 4
yellowcat
Senior MTF Member
yellowcat's Avatar
MTF Member # 70302
I put the new bearings in and used the Loctite bearing retainer. I am noticing though there is a very tiny amount of slop in the bearings when you pull the shaft to the sides...I am thinking maybe :001 to .002. These are Timken Federal Mogul bearings and cost about $20 each so they are not the cheap imports. Is it normal for new bearings to have a tiny amount of play like this? Also do the bearings make any sounds when you spin them even though there brand new? I am noticing a really low pitched sound inside one of the bearings when you spin it. No major squeal or chirp or anything like that though. Any input and comments would be greatly appreciated.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
