Plow hookup for Cub Cadet 147 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-18-2012, 11:02 AM   post #1 of 17
troye
MTF Junior Poster
MTF Member # 40516
Default Plow hookup for Cub Cadet 147
Recently I acquired a 147 without a plow, I was able to buy this plow which I believe from seeing other photos that it is from a Cub Cadet.
First question is how can I find out if mine is a narrow frame, and are there any instructions or measurements or diagrams available to make some changes or to fabricate parts to make the one I have fit the 147.
Second question, the photo shows what I think is the mower deck frame and it should be removed to allow for the plow frame.
troye is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-18-2012, 12:39 PM   post #2 of 17
BillB
Pie R Round
BillB's Avatar
MTF Member # 36410
Default Re: Plow hookup for Cub Cadet 147
The 147 is a narrow frame, but I don't know what you might need to modify your plow. Looks like you need the lift rod, and yes, the mower deck carriage needs to be removed. Have you tried fitting it to the tractor? It should mount much the same as the deck carriage.
Bill
__________________
2012 JD 2320 w/FEL, 54D MMM, 54" Snowblower
2000 Craftsman GT 24HP, 50" Deck, 46" Snowblower
2001 Craftsman GT3000, 48" Deck w/mulch kit, 46" Snowblower, 42" Sweeper, 16 Cu Ft Dump Cart
1973 Cub Cadet 108, 42" Deck, Snow/Dirt blade and Dump Cart
BillB is offline   Reply With Quote Quick reply to this message
Old 10-18-2012, 02:08 PM   post #3 of 17
tpournaras
Senior MTF Member
tpournaras's Avatar
MTF Member # 37349
Images: 6
That plow is a wide frame plow. The undercarriage is the only difference between the plows. If you could find a narrow frame plow undercarriage you could just swap them. I have one of each and could take measurements if that would help.
tpournaras is offline   Reply With Quote Quick reply to this message
Old 10-18-2012, 06:34 PM   post #4 of 17
Pa-Pa
Senior MTF Member
MTF Member # 76670
On the wide/narrow frames: I was surprised to discover that the "wideness" of the frame is only at the front of the tractor, that is, at the engine bay and Quick-Attach links --they're both same dimension through the center and at the rear of the tractor.
So the plow frame isn't going to fit at the front.
Of course, that doesn't take overall length into consideration . . ..
Pa-Pa is offline   Reply With Quote Quick reply to this message
Old 10-19-2012, 07:21 AM   post #5 of 17
troye
MTF Junior Poster
MTF Member # 40516
Quote:
I would appreciate any measurements you have to post,
thanks,
Old 10-19-2012, 07:24 AM   post #6 of 17
troye
MTF Junior Poster
MTF Member # 40516
Being "that the "wideness" of the frame is only at the front of the tractor" in your opinion do you feel that it should then be possible to fabricate something to make it fit.
Old 10-19-2012, 08:58 AM   post #7 of 17
Pa-Pa
Senior MTF Member
MTF Member # 76670
troye: I think you might be able to adapt a narrow frame blade to a wide frame tractor, but honestly, I don't see how you're going to be able to adapt your wide frame blade to fit a narrow frame; unless you just make up a whole new piece that goes from hitch to blade. If it were me, I would be looking for a wide frame tractor for your wide frame blade, it might prove cheaper and easier in the long run. --Just a thought.
Old 10-20-2012, 12:07 AM   post #8 of 17
tpournaras
Senior MTF Member
tpournaras's Avatar
MTF Member # 37349
Images: 6
Like I said before the part of the plow in front of the undercarriage is the same. Both my wide frame and narrow frame plow are about 9 1/8" wide at the pins. The narrow frame undercarriage does not go into the quick attach it bolts to the frame above it. I don't have electricity in the barn anymore so I can't take good measurments tonight but I'll get them tomorrow. The narrow frame plow subframe is not bent like the wide frame one so it could be made easily with some flat bar and a piece of plate.
I stuck the narrow frame sub carriage on top of the wide frame one so you can see. I was holding a maglight in one hand and the camera in the other so sorry about the quality.
Old 10-20-2012, 12:15 AM   post #9 of 17
tpournaras
Senior MTF Member
tpournaras's Avatar
MTF Member # 37349
Images: 6
This is the part you need. It gives a better picture but this one is way overpriced.
This one is slightly different than my plow since it had the quick attach pins whereas mine does not.
http://www.ebay.com/itm/NOS-Cub-Cade...item35be40b450
Old 10-21-2012, 10:57 AM   post #10 of 17
troye
MTF Junior Poster
MTF Member # 40516
This is a great help, I will be watching for the measurments, thanks,
Troye
Old 10-21-2012, 11:48 AM   post #11 of 17
U.S.A Tractor Joe
Farm Show
U.S.A Tractor Joe's Avatar
MTF Member # 56295
Amen for saying so, that NF sub frame for 149.00 is WAY over priced. I seen those go for 10.00 - 30.00 . Maybe someone would trade you're WF for a NF subframe.
__________________
International Harvester Company-the people who bring you the machines that work!
U.S.A Tractor Joe is offline   Reply With Quote Quick reply to this message
Old 10-21-2012, 12:53 PM   post #12 of 17
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Careful the are actually 3 Sub Frames Before the wide Frame quick attach
The Narrow Frame Sub Frame for My 106 uses the quick attach and does Not Bolt to the Frame which is what the 147 would Use as well
Narrow frame Non quick attach series 2 & series 3 Models 70, 71, 100, 102,122 & 123
Narrow Frame quick attach Models 72, 73, 104, 105, 106, 107, 124, 125, 126, 127, 147
For Sub Frames You can check with any of the Cub Cadet Bone Yards Here http://www.mytractorforum.com/showthread.php?t=172824
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 10-21-2012, 10:37 PM   post #13 of 17
tpournaras
Senior MTF Member
tpournaras's Avatar
MTF Member # 37349
Images: 6
Are the two versions of the narrow frame subframe the same overall dimensions other than the quick attach part? I probably have the wrong sub frame as well. I have a 147 also. I just got the 147 this summer and never had the plow on it yet. I thought the non quick attach plow would bolt right up since the frame has the same hole that the earlier cubs had. I really could care less if I have to bolt up the plow rather than just push it into the quick attach.
I didn't get around to making the measurments yet but I will sometime this week. I just hate to see you use the dimensions if they are pretty much the wrong ones.
Old 10-22-2012, 10:36 AM   post #14 of 17
Sergeant
Sergeant's Avatar
MTF Member # 24
Since I Have the deck off My 106 I will Just see today If the Narrow Frame Bolt On from My 70 will work On my 106.(Never Have tried it) I think the engine will Interfere. See I Have a QA36A for My 106 Broke One of the quick attach Pins Off so I Bolt the Thrower to the 106 Now
__________________
White Model: GT2055
Sponsored Links
Advertisement
Old 10-27-2012, 06:28 PM   post #15 of 17
tpournaras
Senior MTF Member
tpournaras's Avatar
MTF Member # 37349
Images: 6
Sorry it took so long. I got called out of town on an emergency buisness trip all last week. The only think I'll mention is that my subframe is slightly bent open at the part where it mounts to the plow so the width im measuring at the two upright bars with the hole are larger than they should be. I suggest you measure the tractor frame and make that width match the frame.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
