Kohler 14 HP Not Getting Spark - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 10-16-2012, 09:54 PM   post #1 of 15
98Murray
Outlaw Tractor Collector
98Murray's Avatar
MTF Member # 52473
Images: 26
Default Kohler 14 HP Not Getting Spark
I bought this old golf cart for $60 the other day. It came woth a spare engine block, new magneto, and a John Deere 318. The golf cart has a Kohler 14 HP horizontal shaft engine. I tried to start it but it has no spark. I put on the new coil and still no spark. I replace the thing that goes in the little black box on the bottom of the block side and still no spark. Why do I have no spark? How is this supposed to be wired up? There is 2 wires coming off the negative side and 1 wire coming off the positive side. Thanks in advance
__________________
1956 Fairbanks Morse Model 26 Riding Mower MFG by Root Thread Here
2000 Simplicity Regent Thread Here
1969 Massey Ferguson MF7
1979 Bolens H11XL
1988 Craftsman II GT18
1990 Craftsman II GT18
1997 Yard Machines GT by MTD
1998 Craftsman II GT6000
2007 Yard Machines by MTD
98Murray is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-16-2012, 10:31 PM   post #2 of 15
FORDLT75
Proud Member of the 1K Club
MTF Member # 78469
Default Re: Kohler 14 HP Not Getting Spark
Is there a black wire running down the the throttle assembly on the motor? If so you will have to open the throttle to get spark. Other then that sounds like kill wire is bad or shorted out on the motor maybe?
__________________
1975ish Ford LT75 - Needs carb worth a hoot
1960's Minneapolis Moline - runs
1971 Sears SS14 - Needs nothing runs great.
1980's GTV16 - runs great but deck needs work
1975 Sears SS16
1970's Allis Chalmers 314H and 314V
1960's Simplicity 3314H
FORDLT75 is online now   Reply With Quote Quick reply to this message
Old 10-16-2012, 11:17 PM   post #3 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
heres some photos
ID:	233506   Click image for larger version
ID:	233507   Click image for larger version
ID:	233508   Click image for larger version
ID:	233510   Click image for larger version
ID:	233511   Click image for larger version
ID:	233512   Click image for larger version
__________________
1979 Bolens H11XL
Old 10-16-2012, 11:18 PM   post #4 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
Quote:
I dont remember seeing a wire around the throttle assembly. I was thinking that maybe the wired got chewed by rats
__________________
1979 Bolens H11XL
Old 10-16-2012, 11:36 PM   post #5 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
I have the plug wire. It wasent on there when I took the photos
__________________
1979 Bolens H11XL
Old 10-17-2012, 12:49 AM   post #6 of 15
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
that thing down under the black cover...is your points, their gap has to be set properly using feeler gauges, best to download a manual and look up "breaker points adjustment"...
Your model number is K321
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Old 10-17-2012, 12:21 PM   post #7 of 15
WNYTractorTinkerer
5000 Strong & Climbing
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: Kohler 14 HP Not Getting Spark
There is only one wire to the points. It must be isolated from the battery/block ground when they are open and then they connect that wire to ground when they are closed. (Test for a short circuit or to see if they are faulty) While the points are closed, it energizes the primary coil winding. Spark happens when the points open and the condenser which is mounted adjacent to your coil and wired to the coil's neg (-) terminal cause the primary coil winding to transfer energy to the secondary winding which makes your spark plug spark.
The point setting is .020" BTW--> the points need to be CLEAN for them to work. Remove and inspect the faces to verify. Here's the Service manual if you don't already have it: http://www.mytractorforum.com/showthread.php?t=61904
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is offline   Reply With Quote Quick reply to this message
Old 10-17-2012, 03:11 PM   post #8 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
For a short while I was getting spark whenever I turned the key on but that was it. I dont think my "new" coil is actually new. How much is a new coil, points, and condensor?
__________________
1979 Bolens H11XL
Old 10-17-2012, 04:09 PM   post #9 of 15
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Sounds like dirty points, the points sound like they arent opening or are stuck open...and they arent letting the coil release.
Seriously...clean the points, set the gap.
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 10-22-2012, 01:52 PM   post #10 of 15
North Dakota Picker
MTF Junior Poster
North Dakota Picker's Avatar
MTF Member # 79584
Images: 8
I'd say the points to, after sitting for awhile the points stick or need to be cleaned with a file, ( a double sided finger nail file will work.
North Dakota Picker is offline   Reply With Quote Quick reply to this message
Old 10-22-2012, 04:46 PM   post #11 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
I havent had much time to work on it but when I get some free time I will clean the points and hopefully get this thing running. Does anybody know who might have made this utility golf cart?
__________________
1979 Bolens H11XL
Old 10-22-2012, 06:02 PM   post #12 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
I had a little time today to work on it so I cleaned the points but still got nothing. So I took off the cover to that little box where the points are and spun the engine over and noticed that little push rod is not moving. How can I fix this?
__________________
1979 Bolens H11XL
Old 10-22-2012, 09:32 PM   post #13 of 15
rhenning
3K Poster!!!!
MTF Member # 4880
If the push rod is not moving it could be a couple of things. The easiest would be that the push rod has worn down so it is no longer the correct length. If that is the case buy a new one and set the point gap at .020 with the points at their widest. If a new one doesn't make it work or move then you have a broken camshaft and probably some internal engine problems. Pray it is a worn push rod. Roger
rhenning is offline   Reply With Quote Quick reply to this message
Old 10-22-2012, 09:44 PM   post #14 of 15
98Murray
98Murray's Avatar
MTF Member # 52473
Images: 26
I have another Kohler 14 HP laying around that has the same problem. Both push rods are the same length.
__________________
1979 Bolens H11XL
Sponsored Links
Advertisement
Old 10-23-2012, 01:19 AM   post #15 of 15
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
It doesnt move it much, only about 1/2 the thickness of a spark plug gap...so its barely visible. With the points removed, if you put the push rod in and hold it with your finger, and role the engine 2 turns, you should feel a "bump"...
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
