Ford 8630 powershift steering problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-11-2012, 08:41 PM   post #1 of 4
pjh
MTF Junior Poster
MTF Member # 79642
Default Ford 8630 powershift steering problem
Hi new member here.
I have a steering problem with the above tractor. Steering wheel turns but wheels don't.
Just want to check it's definitely the steering pump before buying a new one, could it be anything else ? and yes it has oil.
Thanks Paul
pjh is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-12-2012, 01:35 AM   post #2 of 4
Tractortech
MTF Member
MTF Member # 44940
Default Re: Ford 8630 powershift steering problem
Generally, on hydrostatic steering systems, the most common problem, the easiest item to check and fix is the steering cylinder(s). The cylinder packing wears or blows out causing oil to leak by as you turn the wheel.
So, do the wheels attempt to move? Can you jack the front wheels off of the ground and if so, do they turn then?
If they still don't turn, then the pump is the next item suspect.
Does the wheel turn as though it has power assist?
The pump driven gear might have come loose or sheared the key.
Tractortech is offline   Reply With Quote Quick reply to this message
Old 10-12-2012, 02:52 AM   post #3 of 4
pjh
MTF Junior Poster
MTF Member # 79642
Hi Tractortech and thanks for your reply.
I have jacked the front as you said and the wheels still don't turn. Does this mean it can only be the pump ?
Thanks
Sponsored Links
Advertisement
Old 10-14-2012, 07:52 PM   post #4 of 4
Tractortech
MTF Member
MTF Member # 44940
The wheels should have steered even if the pump was not working. My guess would be the steering cylinder has to be resealed providing the information here.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
