49 snow thrower mods? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-23-2012, 10:56 PM   post #1 of 5
bubsy
MTF Member
MTF Member # 49281
Default 49 snow thrower mods?
Just wondering if there are some mods that I should do to the thrower I got for my 317??
bubsy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-23-2012, 11:06 PM   post #2 of 5
Leinie
Proud Member of the 1K Club
MTF Member # 68641
Default Re: 49 snow thrower mods?
http://www.mytractorforum.com/showthread.php?t=255101
Leinie is online now   Reply With Quote Quick reply to this message
Old 09-24-2012, 06:42 AM   post #3 of 5
UrbanTractor
Likes Vintage JDs
UrbanTractor's Avatar
MTF Member # 38663
Garage
As I understand it, these are the 3 primary things that many folks do to improve the Model 49 snowthrower:
1) Add the rubber flaps as described by Mxzrxp in This Thread;
2) Change the size of the auger drive sprocket to increase auger rotation speed; and
3) Swap the short chute for the tall one (if you don't already have it).
Another common mod, if your tractor has a spare pair of hydro outlets, is to convert the manual chute rotation to hydraulic, by bolting a hydro motor right to the wire drum. Also, I've seen where folks have increased chute rotation by adding wraps of wire to the chute base.
__________________
1966 JD 110 Round Fender Integral Sleeve Hitch, Model 42 Blade, 1964 (?) Model 80 Cart, 1965 Model 80 Cart
1972 JD 140 H3, 1972 Cozy Cab Model 14 JDX (2nd Ed.), Front-, Mid-, and Rear-PTOs, Model 54/48" 4-Way Blade, Model 48 MMM, 542 Front PTO, 3-Point-Hitch, Heavy-Hitch, 1968 Model 80 Cart, 2 x 1987 Model 80 Cart, Johnson Model 12 FEL (in progress), MTF Dec. 2013 Machine of the Month
UrbanTractor is online now   Reply With Quote Quick reply to this message
Old 09-24-2012, 09:01 AM   post #4 of 5
grnspot110
3K Poster!!!!
grnspot110's Avatar
MTF Member # 4515
Images: 21
Garage
I use an electric actuator for spout control, car window motor for rotation control (third pic is the bracket for the motor). Drift cutters on both sides, make it easier to see where the ends of the blower are! And, don't forget the cab! ~~ grnspot
Name:	HPIM2234 (640x478).jpg
ID:	230446   Click image for larger version
Name:	HPIM2250 (Small).JPG
ID:	230447   Click image for larger version
Name:	HPIM2249 (Small).JPG
ID:	230448   Click image for larger version
Name:	HPIM2244 (640x478) (Small) (Small) (Copy).jpg
__________________
Home of the JD L/60 "Custom" & the 70 I!
grnspot110 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-11-2013, 07:30 PM   post #5 of 5
french69ssrs
MTF Member
MTF Member # 25535
Images: 1
Hi All
Just wanted to share my Pic of our 1986 318 taking on Nemo in Trumbull, CT. 34" of snow fell from Friday 2/8 to Saturday 2/9, Drifts of 5' and grater. I did the 2 Mods for our Model 49 Snowthrower/ Snow Thrower from MTF and played with the Engine RPM, adjusted the Govenor to just above 3'600 rpm. I changed my Driven Sprocket to a 34 Tooth sprocket
http://www.surpluscenter.com/sort.as...N=20&PageNo=11
and added the Rubber Wipers to the 2 Paddles on the Auger.
Awesome.
Timmy from Trumbull, CT
Name:	2012 Nemo 1986 318 49 Blower 013.jpg
ID:	247437   Click image for larger version
Name:	2012 Nemo 1986 318 49 Blower 012.jpg
french69ssrs is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
