| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#1 |
5000 Strong & Climbing
![]() Join Date: Feb 2008
MTF Member # 9436
The fuel in my portable gas generator (Husqvarna 5510 GN) is getting old, so the next time I have an empty gas can I plan on draining the gas out of the generator. Do you think I should refill it with gas to be ready for use or leave the tank empty? Full would mean it is ready but then the gas can go stale again. Empty would mean that I would have a maximum of 10 gallons (two 5 gal cans)of gas handy in emergency to run the generator, snowblowers, etc. What are your thoughts?
EDIT: I always treat every can of gas with Stabil and a dash of Seafoam.
__________________
ggsteve 08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab 68 JD 112H 47 deck 43 blade 69 JD 110H 37A blower 80 cart 71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab 72 JD 110 parts 78 JD 316 49 blower 81 JD 317 Onan Johnny Bucket Sr. 46" deck 80 Cart 84 JD 214 39 deck 43 blade Toro 212-5 36" blower 74 Concord (MTD) 990 12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
| Sponsored Links | |||
Advertisement | |||
#2 |
Administrator
Opinions will vary widely, but I store mine full after treating the fuel with Stabil. Mine holds eight gallons. That will run anywhere between eight and twelve hours, depending on load, so I like to have a tank full and a couple of full cans in reserve, just in case.
That strategy really paid off after the Derecho of June 29, BTW. My power was off for 13 days and fuel was scattered, to say the least.
__________________
![]() ![]() MyTractorForum.com House Rules Looking for a Technical Exchange Article? Here's an Index! My Equipment: 1963 Gravely Model L 1972 Gravely 816 1973 Gravely Model C8 Six other Gravely C's, L's, and LI's 1981 Troy Bilt Horse, 7HP Kohler 1982 Gravely 8123 1983 Troy Bilt Junior 1988 JD 950, 75 Loader, 8A Backhoe 2002 Craftsman GT3000 23hp 48" Cut Hydro |
#4 |
3K Poster!!!!
![]() Join Date: Apr 2009
MTF Member # 25367
Tank full is OK as long as the carburetor is empty and drained.
#5 |
Likes Vintage JDs
![]() Join Date: Feb 2010
MTF Member # 38663
Steve, I agree with these guys. Maximizing your fuel reserves is key for a long outage.
I don't know how much a hassle it is to drain, but if you could improvise a quick-drain system it should be easy to rotate the fuel out and into a tractor, every 2-3 months or so.
__________________
![]() 1966 JD 110 Round Fender 1972 JD 140 H3 Thanks for all the help with tractor info. |
#6 |
Senior MTF Member
MTF Member # 30999
I keep mine full with treated gas. Every 6 months I drain the gas, put it in my truck and refill with new treated fuel and run it for 15 minutes or so under load.
I put a 'T' in the fuel line so it's easy to drain, before that I had to keep removing the fuel line from the tank, no big deal but I was afaid I'd eventually bust the fitting. I'm opposite of most people as far as draining the carb, I keep it full with the tank valve closed. I have the theory, maybe unfounded, that the constant drying/wetting of the gaskets etc will eventually cause a leak, it's worked for me so far....Mike
__________________
1984 1966 Bolens 19H Kohler 198? 1666 Bolens 17H Kohler 2007 204 Jinma 20 HP 4WD Tractor Koyker 140 Loader BH6600 Backhoe Howse 5ft. Backblade |
#7 |
The Magnificent
I keep mine full of treated gas, and run it quarterly (with a load on the generator). Seems to be working for me. Also keep 10-20 gallons of gas in reserve.
__________________
#8 |
Senior MTF Member
MTF Member # 71265
Shelf life of gas up here is 3 months . I would use stabilzers and run it once in a while ,date the fuel and change it out every 3 months . I also think the same way about keep fuel in the carb as long as it was run with treated gas first .
__________________
![]() The only bad question is the one not asked . http://golfcoursemechanics.blogspot.ca/ |
#9 | |
MTF Member # 9436
Quote:
Interesting comments so far. I knew there would be varying opinions. I like the idea of a "tee" off the fuel line. Seems like that would be a good standard feature on a product of this nature.
__________________
#10 |
Martian Wx Moderator
I keep mine full all the time and run it about once a month. I've had worse luck in the past draining carbs and tanks then I have by keeping fresh gas flowing into them every month or two.
#11 |
10,000 +posts!
I there any place in your area you can get non-ethanol gas?
I have been useing it in my lawn stuff for the last couple mnths, and have noticed a difference..............however--have not used over long shut-down period yet... glenn
__________________
glenn27 Sometimes you just have to laugh.. To keep from going insane!!Jimmy Buffett |
#12 |
2000 Posts and climbing!!!
I keep a minimum of treated gas in the tank, but always have 4 or 5 gallons on hand. It doesn't get much use so I start it up every couple of months and let it run under load for about 20 minutes. Then I add about a half gallon of fresh treated gas so most of the gas in the tank is refreshed. I also use the shutoff valve to stop the engine, rather than the switch. It starts on the first pull every time.
__________________
Al Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab TroyBilt LTX 15.5, snow thrower, cab (sold) TroyBilt LTX 13, (given away) Craftsman DYT 4000 Special Edition, 21 HP Briggs Twin (sold) DR Lawn Vacuum. Review here 1978 Craftsman 7 1/2 HP snow blower (backup machine) "You will find out what that extra part is for as soon as you throw it away"
#13 | |
Senior MTF Member
MTF Member # 30999
Quote:
I have heard that higher octane fuel doen't have ethenol added, true or not I don't know. If it is the case when it does arrive here it'll be high test always for everything....Mike
__________________
#14 |
Junior-Senior Member
I keep mine full (~4 gals) with the fuel shut off in the OFF position. That way its ready to go, plus if I run out of jerry can gas, theres a good chance I can get some out of the genny
__________________
GT_80 Fan Club Member: #0001 Where is everybody? ![]() '78 GT/19.9 Twin, '78 GT/18 Twin, '77 18/6 Twin, '73 SS/16 Twin, '65 Suburban 8 I'm 18 years old, and always looking to learn!
| Sponsored Links | |
Advertisement |
#15 |
MTF mile high club member
![]() Join Date: Feb 2012
MTF Member # 69612
Empty and it's never been filled since it was new.
![]() Seriously, I was losing power quite often in the winter due to old lines/poles breaking down the road; for a long time I just put up with it as they seemed to have pretty fast repair service. Finally, after how many years, I broke down and bought a decent generator along with everything to hook up the switch; the following spring the power company came through (unannounced to the power customers) and put in all new lines and poles for several miles clear back to the sub station. What are the odds of that? I haven't been without power since then that I can remember and that was 3 years ago.
__________________
2011 JD X748 2007 JD X748 |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
