Snowblower For Gravely Servicing??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-16-2012, 12:41 AM   post #1 of 7
jboyd12
MTF Junior Poster
MTF Member # 78690
Question Snowblower For Gravely Servicing???
I just picked up an MA210 snowblower for a Model L Super Convertible Gravely walk behind that has only been used to plow. I was told it was stored in a barn and has some grass and a little gravel in the impeller but I got most of it out. It spins by hand but it does take quite a bit of force. The auger has been adjusted as it was touching the housing and not moving now that too moves with some force with my foot.
I covered a lot of the moving parts with oil but I couldn't find any grease nipples. I want to service it properly. I was wondering how I could change the oil? As well as any other ways to service it to make sure its running properly for winter. Thanks!
jboyd12 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-16-2012, 08:15 AM   post #2 of 7
Gravely Model L Guy
Gravely Model L Guy
Gravely Model L Guy's Avatar
MTF Member # 65803
Default Re: Snowblower For Gravely Servicing???
There are no grease fittings on your model of MA210. You can change the oil in the gear box though. Remove the bottom plug and tip up the snow blower to drain the oil. Then refill through the top plug with 90W.
__________________
1951 Gravely Model L.
1964 L-8-currently under restoration.
1953 Model L with ring gear Ford type starter
1957 lI pull start
1957 li elec start
1961 L
1963 L-I
1970 Commercial 12
1963 L-I super convertible.
1987 Ford LGT14D
1960 bunton mower
1926 Ford Model T Tudoor sedan.
1985 Troy-Built Horse
1979 Troy-Built Horse
1950's Airens Trans a Matic
1972 MG MGB roadster
1997 ford f-450 5 spd 7.3 turbo
check out my youtube channel: http://www.youtube.com/user/64gravely?feature=mhee
Gravely Model L Guy is offline   Reply With Quote Quick reply to this message
Old 09-16-2012, 10:19 AM   post #3 of 7
DJ in WV
I Love All Color Tractors
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
Welcome to the forum and congratulations on grabbing a blower. It looks very good.
The only thing that I can add is lubing the splines on the drive shaft and in the coupler behind the auger gear box. Mine shows some wear after never being lubed.
__________________
MyTractorForum.com House Rules
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1981 Troy Bilt Horse, 7HP Kohler
1982 Gravely 8123
1983 Troy Bilt Junior
1988 JD 950, 75 Loader, 8A Backhoe
DJ in WV is online now   Reply With Quote Quick reply to this message
Old 09-16-2012, 11:58 AM   post #4 of 7
Richard-tx
5000 Strong & Climbing
Richard-tx's Avatar
MTF Member # 51208
Images: 7
I would use GL4 gear oil, not GL5.
__________________
Code:
                              Current Inventory
   24G (Onan 24hp)    24GLX - was 16G  (Onan 24hp)   8249 - was 8129 (Onan 24hp)
        818T (Onan 18hp B48)       8163T - was 8123 (Onan CCKA)
                              8183T (Onan B48)
   5665 w/brakes        5665        5660        Pro-8         Pro-16 w/brakes
For Gravely Manuals and more visit http://GTCOA.com
Richard-tx is offline   Reply With Quote Quick reply to this message
Old 09-17-2012, 01:39 PM   post #5 of 7
tinsley207
Senior MTF Member
MTF Member # 30562
One other thing to check is the large nut that is holding the slip clutch on the blower. That nut actually adjusts bearing play in the auger shaft. If you tighten that really hard you're just pressing those tapered roller bearings tighter together and eventually they stop moving... ask me how I know! It should be snug but not to the point where it stops moving.
You should remove that slip clutch anyway and service that as well. That will give you a chance to see the condition of the roller bearing underneath it. Ask us if non of this makes sense and we'll walk you through it.
Nate
tinsley207 is offline   Reply With Quote Quick reply to this message
Old 09-20-2012, 05:37 PM   post #6 of 7
jboyd12
MTF Junior Poster
MTF Member # 78690
Thank you everyone for the great tips and info! I do have one concern if i spin the clutch it turns the impeller and the auger, but i can hold the auger while someone else spins the clutch it wont mover.. also if i just spin the auger it will not turn the impeller.. is there a problem with the gear??
thanks for the Help guys!
Sponsored Links
Advertisement
Old 09-20-2012, 10:42 PM   post #7 of 7
DJ in WV
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
It could be a problem with the gearbox, but I would say that it's much more likely that the reel clutch is worn out or need tightened up.
If you don't have it already, the manuals for this and lots and lots of other Gravely goodies are available for free download over at http://www.oldgravelys.net. The clutch adjustment is outlined in the manual rather well. I'd start there.
__________________
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1982 Gravely 8123
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
