#1 |
Senior MTF Member
Hi everybody;
I have a 12.5 I/C B&S that was given to me, the only problem is when they removed it they cut the wires. There are three wires that come out of the starter side of the engine. A black wire that goes to the coil, I think is a kill switch wire. There are two wires that come out from under the flywheel one is white and one is black, what do these connect to? Thanks |
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior MTF Member
MTF Member # 25899
One of the pair should have a diode in it . It's 12v dc and goes to battery positive , possibly at keyswitch tab in common with lead from battery. Does you carb have an anti-backfire solenoid? If not the second wire of the pair is lkely AC for lights if it comes from under the flywheel with the other wire. I think the anti backfire wire , if it existed, is paired in a connector with the coil kill wire.
#4 |
3K Poster!!!!
MTF Member # 24003
Using the motor info on the fan shroud, the B&S website might have an instruction booklet for that engine which would list the wire colors. I had to install a 12.5hp into a machine that had a 10hp, and the B&S website saved me time. The 'diode' was not on the 12.5, nor on the remaining wiring for the 10, inmy case.
#5 |
Senior MTF Member
MTF Member # 23545
I found this while searching for something yesterday. It's PDF of briggs engine wiring.
Cannon http://www.stripmine.org/sears//engi...ggswiring1.pdf |
| Sponsored Links | |
Advertisement |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
