Craftsman LT4000 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-01-2012, 06:20 PM   post #1 of 16
Michigan Mower
Senior MTF Member
Michigan Mower's Avatar
MTF Member # 66574
Help Craftsman LT4000
I just got this Craftsman LT4000. The 15.5 OHV Kohler currently doesn't run. The 42 inch deck is in great shape and is newer to the tractor. The previous owner told me the engine had a bad coil and wasn't getting spark. I haven't checked the spark yet because the battery was dead. The frame is also cracked by the front axle. I have a few questions. What year is it? Model number- 917.257660. Serial Number- 052594D. What is it worth running with the deck? Thanks! On to the pictures!
__________________
No Lincense plate? No problem, I have a fluorescent orange triangle!
Lambert 666
Michigan Mower is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-01-2012, 06:22 PM   post #2 of 16
craftsmanmowerfreak
Briggs powered Sears.
craftsmanmowerfreak's Avatar
MTF Member # 64880
Images: 6
Default Re: Craftsman LT4000
serial number 05/25/1994
__________________
1992 GMC Sonoma Extended cab
4.3l v6 700r4 trans
my mowers
1970 lawn flite (mtd)
1971 ss14 (repower) 14hp cast iron briggs from a gilson
1972 ss15 (redone suburban 15) 78 cast iron 16hp
1973 st10 (8hp briggs repower)
1973 st10 blue and white with a 79 8hp briggs
1978 39inch sears 3pt tiller 8hp briggs
1991 mtd gt1846 rough beater for mowing grass lol
craftsmanmowerfreak is online now   Reply With Quote Quick reply to this message
Old 09-01-2012, 06:25 PM   post #3 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
Quote:
Thanks you! So that's you tell eh! Cool! Thanks again!
__________________
Lambert 666
Old 09-01-2012, 06:25 PM   post #4 of 16
craftsmanmowerfreak
MTF Member # 64880
Images: 6
also take the blower housing off and take the kill wire off the mag. to make sure thats it is the mag thats out and not a short in the harness
__________________
4.3l v6 700r4 trans
my mowers
Old 09-01-2012, 06:31 PM   post #5 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
Ok! Thanks!
__________________
Lambert 666
Old 09-01-2012, 06:43 PM   post #6 of 16
craftsmanmowerfreak
MTF Member # 64880
Images: 6
what i do if its a short in the tractor thats grounding out the mag is i put a toggle switch on the dash and run new wire to the mag and then ground other sideof toggle switch to the frame. thats just what i do to be a quick fix
__________________
4.3l v6 700r4 trans
my mowers
Old 09-01-2012, 10:11 PM   post #7 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
__________________
Lambert 666
Old 09-02-2012, 12:43 AM   post #8 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
Another one!
__________________
Lambert 666
Old 09-02-2012, 01:22 AM   post #9 of 16
craftsmanmowerfreak
MTF Member # 64880
Images: 6
nice lt1000
__________________
4.3l v6 700r4 trans
my mowers
Old 09-02-2012, 01:57 AM   post #10 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
nice lt1000
It smokes a lot, I am guessing it needs new rings. lol
__________________
Lambert 666
Old 09-02-2012, 03:02 AM   post #11 of 16
craftsmanmowerfreak
MTF Member # 64880
Images: 6
is it a ohv? could have a blown head gasket. if it is i set the vavles to 5 thousandths on both intake and exhaust.
__________________
4.3l v6 700r4 trans
my mowers
Old 09-03-2012, 07:54 PM   post #12 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
Yeah it's OHV. I set the valves to 5 today and it still smokes. Probably the head gasket. What kind of rear end are in the LT1000 Spicer? Or Peerless?
__________________
Lambert 666
Old 09-03-2012, 10:13 PM   post #13 of 16
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
Why set them to the minimum on one valve and the maximum on the other, when you can set them both in the middle of their range with the SAME effort?
Do you only own a .005" feeler gauge?
__________________
Illegally Blind
Bill Kapaun is online now   Reply With Quote Quick reply to this message
Old 09-03-2012, 10:41 PM   post #14 of 16
greenbud21
Senior MTF Member
greenbud21's Avatar
MTF Member # 77940
Quote:
Im pretty sure it is peerless. They are a fun little tractor to mod cause parts are cheap and easy to find.
greenbud21 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-03-2012, 11:08 PM   post #15 of 16
Michigan Mower
Senior MTF Member
MTF Member # 66574
Quote:
Thank you!
__________________
Lambert 666
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
