Another victory for MMO! Revived a seized motor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 08-30-2012, 11:25 AM   post #1 of 7
benhogan
Ben's Lawn Mower Repair
benhogan's Avatar
MTF Member # 60718
Default Another victory for MMO! Revived a seized motor
So I get this email from my neighbor...
Hey Ben-
I have a new Toro, emphasis on new. Yes, I finally replaced my 14 year old craftsman mower. Unfortunately I was away when the new mower was purchased and my oldest didnít put enough oil in the engine so it burned out the first time it was used. Sadly the toro repair said there wasnít anything to do as a new engine would cost as much as a new mower. Costly lesson for my son to learn about having enough oil in an engine. Would you like the mower for your parts repair? If so, let me know when you will be around and I will drop it off. Thanks.
Tracy
he dropped off the mower yesterday and it was indeed seized up. I decided to overfill the crankcase and combustion chamber with MMO and then let it sit for an hour while i had supper. I drained the MMO (too expensive to dump) into the back into its jug. I put the normal 19.5 oz of HD30 oil in then I turned the mower on its side then slowly turned the blade back and forth. The dang motor was now "unseized"! It started right up. To really test it, I let it run for 30 minutes with no issues.
MMO is just awesome. I decided not to be a hog so I emailed the owner telling him it is fixed and he can pick it up.
__________________
Ben
1987 Mercedes 190d 2.5turbodiesel
2000 Toyota Sienna - mower hauler and carpool vehicle
1965 Arlene model. Stands about 5'3", a bit temper mental sometimes, sometimes expensive to maintain, but worth every bit of trouble.
benhogan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-30-2012, 12:13 PM   post #2 of 7
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Default Re: Another victory for MMO! Revived a seized motor
It wont live very long...but it might last a few cuttings.
When something seizes, by definition there is galling or metal to metal contact, when this happens the softer metal will smear or transfer to the harder metal. I nthe case of the bottom end, the aluminum rod transfers to the hard crank. In the top end..the aluminum cylinder transfers to the chrome plated piston and rings.
While it may still function, odds are good that major damage has been done, and it will have a much much shorter life span.
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Old 09-03-2012, 12:55 PM   post #3 of 7
Cohiba54
Busted Knuckle
MTF Member # 62565
what is MMO?
Cohiba54 is offline   Reply With Quote Quick reply to this message
Old 09-03-2012, 01:06 PM   post #4 of 7
DJ in WV
I Love All Color Tractors
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
Quote:
Originally Posted by Cohiba54 View Post
what is MMO?
MMO = Marvel Mystery Oil
__________________
MyTractorForum.com House Rules
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1981 Troy Bilt Horse, 7HP Kohler
1982 Gravely 8123
1983 Troy Bilt Junior
1988 JD 950, 75 Loader, 8A Backhoe
DJ in WV is online now   Reply With Quote Quick reply to this message
Old 09-03-2012, 09:29 PM   post #5 of 7
mikeinri
2000 Posts and climbing!!!
MTF Member # 62115
Images: 1
I did something similar (seized by over-speeding) with an old Tecumseh. Freed it by hand with MMO, then had a major breakdown (rod, I assume), the very next time I used it (this was on a tiller).
Mike
mikeinri is offline   Reply With Quote Quick reply to this message
Old 09-03-2012, 10:24 PM   post #6 of 7
Ralphst16
Senior MTF Member
Ralphst16's Avatar
MTF Member # 61010
MMO is a good product. My neighbor has a 1968 ford backhoe with a 3 cyl gas engine that was seized due to water getting in the head. My dad fixed it for him by soaking the cylinders with MMO and cranking it slowly by hand. I agree though, seizing from rust is one thing, but once an engine seizes from lack of oil it's pretty much done.
__________________
1973 Sears ST16 (48" mower deck, front plow, snowblower, litter whisk, broadcast spreader, manual 3 pt hitch, penn line dump trailer)
1964 Bolens Husky 900 (38" mower deck, front plow, home made dump trailer)
1969 International Scout 800a
Ralphst16 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-05-2012, 02:50 AM   post #7 of 7
38racing
Proud Member of the 1K Club
MTF Member # 25899
I have a still running 1979 briggs 11 hp that had the top bearing seize due to lack of oil. That was about 16 years ago. On the other hand I got another 28 series seized from no oil with some rod to crank transfer. When cleaning it up I noticed a tiny tiny crack in the rod. Replaced it and got a summer of heavy cutting from it. Haven't used it much this summer. I expect that had I left the original rod in it then it would have blown.
38racing is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
