John Deere LT166 Gas Tank: Clean or Replace? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-26-2012, 01:36 PM   post #1 of 12
davbell22602
Senior MTF Member
davbell22602's Avatar
MTF Member # 50379
Default John Deere LT166 Gas Tank: Clean or Replace?
I acquired a JD LT166 for $25 few days ago. Guy told me the gas tank has black stuff in it from old gas. I dropped the tank. Found the steel line is rotting and has a hole in it near top. Also the inside of it is smelly and gummy lookin. The JD dealer wants $116 for a new tank and I found couple used on ebay for under $75 after shipping costs. Not sure what to at this point on cleaning the old tank or get another instead wasting time on the old one. I have no part washer to clean it.
Also need the lower hood assembly which is $337 from the JD also but found it cheaper new on ebay at $265.
Here's pics of the gas tank.
davbell22602 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-26-2012, 03:13 PM   post #2 of 12
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
Default Re: John Deere LT166 Gas Tank: Clean or Replace?
There is no way I woud use the one in the picture. Sorry some of the stuff is so expensive, just the way JD stuff is. I also have to buy the lower portion of my hood and it is in the $230 range, but what are you going to do.
Think of it this way, you only paid $25 for it, what a deal. It would be nice if the tank was plastic rather than steel.
Dick
__________________
GT275
GT235
JRJ is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 03:37 PM   post #3 of 12
davbell22602
Senior MTF Member
MTF Member # 50379
Dick
The tank is plastic the line going in the gas tank is steel. But when I talked to the JD parts guy both version of the line going in the tank subs to the same part number. Meaning the steel line version of the tank is not a option anymore its all plastic plastic line inside tank now. Probably gamble on a used one then later buy new if it fails.
Old 08-26-2012, 03:57 PM   post #4 of 12
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
A different story now, the picture of the tank just makes it look like steel to me and you stated it had a hole in it and I guess I just assumed it to be steel, so I would really try to salvage this one and then try to rig something up for the gas line, plastic or rubber line.
Dick
__________________
GT275
GT235
Old 08-26-2012, 04:04 PM   post #5 of 12
davbell22602
Senior MTF Member
MTF Member # 50379
So what do I use to clean the inside out with?
Old 08-26-2012, 04:13 PM   post #6 of 12
Engine_Tech
Proud Member of the 1K Club
MTF Member # 46741
I wonder if some SeaFoam would cut that stuff? I've seen them cleaned with a pressure washer before too. Heat would help.
Engine_Tech is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 04:22 PM   post #7 of 12
davbell22602
Senior MTF Member
MTF Member # 50379
I wonder if bleach would work? What about dumping cans of the b12 carb cleaner(the can you pour in with the gas not the spray) in there n shake it up and let it sit for awhile.
Old 08-26-2012, 04:29 PM   post #8 of 12
matt167
3K Poster!!!!
MTF Member # 64659
looks like that guy added a BOTTLE of Sta-bil to the tank and that's what setteled in the red gooey mess.. I would clean it with lacquer thinner and then rinse it with gas really good. Lacquer thinner is only a mix of xylene/ Toulene ( octane booster ) with a couple other solvents. I also would try brake cleaner.
matt167 is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 05:44 PM   post #9 of 12
davbell22602
Senior MTF Member
MTF Member # 50379
I cleaned tank out except one corner that missed. I noticed bunch of brown dots. When scrapped couple of them a layer of the plastic came off with it. The brown dots are rotting the tank out. So I still need another tank.
Old 08-26-2012, 05:53 PM   post #10 of 12
matt167
3K Poster!!!!
MTF Member # 64659
just fiberglass the effected areas after cleaning it out.. You'll spend $20 instead of $100 and it will likely last the life of the tractor.
Old 08-26-2012, 06:00 PM   post #11 of 12
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
Plastic does not 'rot'. It may deteriorate (as in become thinner or more brittle), but it will not rot. The process of 'rotting' refers to organic matter decomposition, and plastic is not organic. A coating of fiberglass is a good idea.
Harryc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-26-2012, 06:03 PM   post #12 of 12
davbell22602
Senior MTF Member
MTF Member # 50379
Quote:
Its actually coming through the plastic from the inside of the tank. Plus i doubt I can the fuel line that does in side anyways since they changed the design and location of where the pickup line is on the tank. I get another tank used of ebay for $65 after adding shipping to the cost.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
