Putting a tube in a front tire that got a nail in it - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-24-2012, 09:44 PM   #1
jbeall
Senior MTF Member
MTF Member # 39367
Default Putting a tube in a front tire that got a nail in it
Hi All,
I've got a John Deere 2210 SCUT, and it picked up a nail in the front tire.
The tire's got plenty of tread left. I'm thinking about putting a tube in it, which would be something like one-third the cost of putting a new tire on it. Any issues with this?
I could also try to patch it but I'm not sure if that would work in this case--would the FEL use putting extra weight on those little front tires make a patch job start to leak?
-Josh
jbeall is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-24-2012, 09:51 PM   #2
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: Putting a tube in a front tire that got a nail in it
I would go with the tube!
__________________
SonnyT is online now   Reply With Quote
Old 08-24-2012, 09:57 PM   #3
Hugh-SS/16
Junior-Senior Member
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
Where I work we put these in everything... 3000lb cars to 7000lb pickups
takes 3 mins
__________________
GT_80 Fan Club Member: #0001
'78 GT/19.9 Twin, '78 GT/18 Twin, '78 GT/18 Hydrodrive, '77 18/6 Twin, '73 SS/16 Twin, '65 Suburban 8
I'm 18 years old, and always looking to learn!
Hugh-SS/16 is online now   Reply With Quote
Old 08-25-2012, 08:26 AM   #4
kennyd
Senior MTF Member
kennyd's Avatar
MTF Member # 50540
Quote:
takes 3 mins
That has my vote as well. Certainly worth a try for the price and reduced labor. I have one in my front left R4 tire now that been holding for over a year now.
__________________
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
Also check out www.greentractortalk.com
kennyd is offline   Reply With Quote
Old 08-25-2012, 10:22 AM   #5
meburdick
Senior MTF Member
meburdick's Avatar
MTF Member # 60614
Let's see... Front axle max weight on your tractor is what... 1,000lbs? 1,500 lbs? 2,000 lbs?
Axles in my trailer are 5200 lbs. And I would use one of those patch kits on the trailer, providing the hole is in the face of the tread. So, in my reasoning, that patch is plenty strong enough to use on the fronts of your tractor. I might think twice for the rears if they're filled... Dunno... Still might try it there just to see.
If you have a hole poked through the sidewall, whole different story - get a new tire.
__________________
2011 Wife v2.0 - Now with more understanding of men needing their toys... Er, tools. (Props to TurtleBoy)
2011 2520 with 200cx / 53" bucket, 62D On Ramp MMM, 54" Front-Mount Two Stage Snowblower with remote chute angle control, Ballast Box, Artillian JDQA Pallet Forks / 42" Forks, Turfs, and Loaded Rear Tires
2011 Stihl MS 290 Chain Saw w/ 18" Bar/Chain
20?? Huskee 27-Ton Splitter
FOR SALE: Husqy 435 Saw http://www.mytractorforum.com/showthread.php?t=255716
meburdick is offline   Reply With Quote
Old 08-25-2012, 11:41 AM   #6
glc
Senior MTF Member
glc's Avatar
MTF Member # 33551
I also agree with the plug. Awesome invention. Probably last the life of the tire.
It's a tubeless tire,so if you decided to tube it,the tire still has to be patched. So if a tubeless tire is patched,why bother with the tube.
Greg
__________________
2009 2520
FEL/61" HD bucket/replaceable cutting edge
62D2 MMM
IMatch Quick Hitch
Homemade 3PT Receiver
Homemade Ballast Box
Woods GB65 Box Blade
A "REAL" snow blade
90% restored 1987 JD 316
MY BALLAST BOX:
http://www.mytractorforum.com/showthread.php?t=106002
MY SE SEAT MOD:
http://www.mytractorforum.com/showthread.php?t=110315
glc is offline   Reply With Quote
Old 08-25-2012, 01:30 PM   #7
JFordBronco
Senior MTF Member
MTF Member # 26902
I have numerous nails/thorns/glass/crap in my front and rear tires. I added 3 gallons of SLIME to my rear tires and a gallon each to the front tires, seals up good and dont have to worry about it Give that a whirl...
__________________
MF 1532 with FL100 5' FEL
5' Big Bee bush-hog
6' Rhino finishing mower
6' County Line/King Kutter box blade
12" Everything Attachments Single Bottom Plow
5' Howse disc(DLHT16822B)
5' Everything Attachments Garden Bedder
Everything Attachments Trailer Mover
Everything Attachments Potato Plow
Thanks Wifey for buying it for me
JFordBronco is offline   Reply With Quote
Old 08-27-2012, 11:47 AM   #8
jbeall
Senior MTF Member
MTF Member # 39367
Hi All,
Thanks for the suggestions. I went with a Slime tire plug kit. $3 at Walmart. And it turns out I had two leaks, not just one. I managed to push one of the plugs all the way into the tire (oops), but on the second attempt I got the plug 2/3 of the way, as the instructions said to do.
I cut the excess off and took it out for a mow for about an hour. So far so good! I also used soapy water on the plugged areas to check for leaks, and I couldn't see any visible bubbling with the tire at full pressure (22psi).
-Josh
Old 08-27-2012, 11:49 AM   #9
jbeall
Senior MTF Member
MTF Member # 39367
Quote:
Why do you have to patch a tubeless tire to put a tube in it? I've put tubes in my garden tractor's tires when they sprung a leak, and it seemed to work just fine...?
Old 08-27-2012, 11:52 AM   #10
Hugh-SS/16
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
As said, those plugs will withstand pressure, most passenger car tires run about 40-45 psi (truck tires are closer to 65) and the patches are one size fits all, goes in any tire, that type of deal. As long as your tires wear evenly, the plug will simply become flush with the tread and wear with the rest of the tire. Glad to see you got it fixed.
__________________
Old 08-28-2012, 08:21 PM   #11
kennyd
Senior MTF Member
kennyd's Avatar
MTF Member # 50540
Quote:
On a car/truck I would agree, but I would have no issue plugging a sidewall on a tractor tire.
__________________
John Deere 4110HST
Old 08-28-2012, 08:22 PM   #12
kennyd
Senior MTF Member
kennyd's Avatar
MTF Member # 50540
Quote:
Originally Posted by jbeall View Post
Hi All,
-Josh
Good news. You will find that very handy to have around for all your vehicles.
__________________
John Deere 4110HST
Old 08-28-2012, 08:49 PM   #13
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
The Slime will ruin your rim and no one will want to touch it when it come time to put on a new tire...
__________________
Kbeitz is offline   Reply With Quote
Old 08-28-2012, 09:27 PM   #14
JFordBronco
Senior MTF Member
MTF Member # 26902
fix a flat ruins your rim, never had any issue with slime in my tires - utility trailer, atv tires, huntin truck....
__________________
5' Big Bee bush-hog
Sponsored Links
Advertisement
Old 08-28-2012, 09:44 PM   #15
meburdick
Senior MTF Member
meburdick's Avatar
MTF Member # 60614
Quote:
I wouldn't consider plugging / patching any tire with a hole or cut in the sidewall. That's where the tire gets its strength, and any "injury" makes it weaker. The last thing I would want is to have that tire fail while I'm toting around 1,000 lbs of material in the loader or lifting something significant with the 3PH.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
