JD 425 54" mower deck problem. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-24-2012, 11:45 AM   post #1 of 14
Phat Phydeaux
MTF Member
MTF Member # 47436
Default JD 425 54" mower deck problem.
I have several things going on with my 54" mower deck.
1. Front right support wheel has hit something like a tree, post, etc... and is pushed in a inch or so. The blade doesn't hit the inside of the deck. (thank you grandkids). How is the best way to straighten up this wheel bracket and also the top welds are broken loose.
2. The belt has been jumping of even prior to the grandkids attack on my wheel bracket. I see on e-Bay that bearings are available for $38ish. I want to put quality parts on if I need to rebuild the deck to stop the belt from jumping off, but I don't want to pay an arm and leg. Is there an aftermarket vendor that I can get spendels, bushing, washers, bolts, bearings etc.. Also does the decks use a race in the spindle for the bearings or not?
Does anyone have a good drawing of the 54" mower deck and parts with parts list? The one on the JD website parts section is so small I can see it.
Thanks,
Garry
Phat Phydeaux is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-24-2012, 12:45 PM   post #2 of 14
Dan33Klein
2000 Posts and climbing!!!
Dan33Klein's Avatar
MTF Member # 55503
Default Re: JD 425 54" mower deck problem.
Ive heard good things about the ebay bearings, i would give it a shot. you can put a bottle jack and a 2x4 on the inside of the deck to push the dent out to straiten the wheel. not sure on the race, someone will answer soon
__________________
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/showthread.php?t=178233
http://www.mytractorforum.com/showthread.php?t=214280
Dan33Klein is offline   Reply With Quote Quick reply to this message
Old 08-24-2012, 01:16 PM   post #3 of 14
Diesel Powered
MTF mile high club member
Diesel Powered's Avatar
MTF Member # 69612
The spindle bearings aren't tapered bearings, so they don't have separate races. Take the belt off and check each spindle (as well as the idlers) by hand for up/down play and side play; also, make sure the pulleys aren't bent in any way.
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Diesel Powered is online now   Reply With Quote Quick reply to this message
Old 08-24-2012, 02:03 PM   post #4 of 14
mister moose
MTF Junior Poster
MTF Member # 3564
I just rebuilt my 54 deck on a 425. New bearings, belt, gearbox. At 900 hours the gearbox failed, and several of the bearings were rumbling, the belt (Looked good until I had it off) was cracking all over, and even had a 1/2" section missing on one side.
You can probably find the spindle bearings on line. Unfortunately, I didn't write down the bearing number, and the shop that pressed them out threw them out as I didn't want them.
Here's what I have for part numbers:
Belt M112269 $83.83
Spindle bearing M110008 $14.58 (need 6)
Spindle seal ET15755 $8.89 (need 6)
Spindle bushing M110008 0.71 (need 6)
Idler pulley AM106627 $18.76
Idler pulley AM37249 $17.05
Spindle bolts 03M7186 $0.51 (Need 12)
If any of the axles in the spindle are trashed:
Spindle axle M122465 $19.18
A few hints:
The bearings press outward from the center of the spindle. You cannot press the top bearing out through the bottom, or vice versa.
Take a photo of the belt path before you remove it.
Change the gearcase oil while it's apart. 90W gear oil.
You can also buy a complete spindle assembly for about $100.
Have fun. A good impact wrench is recommended.
mister moose is offline   Reply With Quote Quick reply to this message
Old 08-24-2012, 04:38 PM   post #5 of 14
mister moose
MTF Junior Poster
MTF Member # 3564
Also,
I have the same issue with the fwd right wheel bent backwards, on mine the unsupported opening of the mower chute allows any repeated drag on the wheel to eventually bend it back. I concur on the use of a small bottle jack and a 2x4 to press it back to original shape. I'm thinking of welding a large 'L' bracket on the outside of the chute to add rigidity there, as it is an ongoing issue. Wouldn't necessarily blame the grandkids on that one.
You will need a small arbor press to press in all the bearings and seals, or take all the parts to a shop that has one.
Old 08-24-2012, 08:09 PM   post #6 of 14
ShelbyGT550
ShelbyGT550's Avatar
MTF Member # 62377
Ouch on the price of the belt, Hate to see how much the one for my 48" is
__________________
1996 John Deere 425 Main Summer Machine - 20HP Liquid Cooled Kawasaki - Hydrostatic Twin Pedals - 48" Deck
197? John Deere 400 H3 Main Winter Machine Down - Fixing odds & ends - 19.9HP Kohler 532- Hydrostatic - 3PT Hitch - Back Blade - Snow Blower - Cab - Weights - Chains
1974 Massey 12G - Backup Machine - Tecumseh 12HP - 4 Speed Variator - 42" Mower Deck - Snow Blower - Tiller - Cab
1996 Sears GT6000 - Backup Machine - Kohler Command 22HP Twin - 6 Speed Hi/Low - 42" Mower Deck - 42" Dual Stage Blower - Brush Guard - ATV Tires - Chains & Weights
1974 John Deere 112
(Parts)
197? John Deere 112 Electric Lift - Storage - 12HP Kohler K301- 4 Speed Manual - Turf Tires
Past Machines & To-do's - 1974 Snapper LT16 - 1989 Murray GT18/46 - 1970 Massey Ferguson 10 - 2004 John Deere LA100- WIP
ShelbyGT550 is offline   Reply With Quote Quick reply to this message
Old 08-24-2012, 08:12 PM   post #7 of 14
SyNtAxx
Senior MTF Member
SyNtAxx's Avatar
MTF Member # 57051
i just fixed this on my 54" deck on my 455. I pushed it open with a bottle jack. Mine wanted to flex back but I made it work. In addition there is supposed to be a metal bracket that braces the opening. Mine didnt have it mounted when I purchased the tractor, but i have since installed it as it was in my spare parts box that came with the purchase.
See here: http://www.mytractorforum.com/showthread.php?t=250262
second page of posts has the bracket that is supposed to be in the chute opening.
nick
__________________
1993 JD 455 w 54" Deck @ 2200+ Hours
CTC 4150 Loader w 6 suitcase weights
54" Quick Attach Blade
54" Front Mount Dethatcher
48" Agri-Fab Core Aerator
48" Craftsman Lawn Sweeper
15 Gallon Towable Boom Sprayer
130# towable Broadcast Spreader
JD 80 Dump Cart
SyNtAxx is offline   Reply With Quote Quick reply to this message
Old 08-24-2012, 11:52 PM   post #8 of 14
69project
Proud Member of the 1K Club
69project's Avatar
MTF Member # 40646
I would check your belt out before redoing your spindles. Sometimes as a belt wears it starts jumping off, at least I have had that happen to me. I would also shop around for belt prices although most everything on a 425 tends to be pricey.
69project is offline   Reply With Quote Quick reply to this message
Old 08-25-2012, 12:40 AM   post #9 of 14
Robert Webb
Robert Webb's Avatar
MTF Member # 53133
Images: 4
Garage
STICK WITH JD BELTS.........you can skimp elsewhere but insist on JD BELTS
__________________
John Deere 430
John Deere 425 with 54" Deck and Power Flow and MC 519 Cart
John Deere 400 with 60" Deck and Power Flow
John Deere 112 H with 38" deck
John Deere 30 Hydraulic Tiller w/ 12" extension and 3 Pt setup
John Deere 21 Cart
John Deere 80 Cart (refurbished to be used)
John Deere 22 Cart (Greens mower trailer)
54" 4 way plow
Brinly 10" Sleeve hitch plow
Brinly 12" 3pt Plow X2
Brinly 4 gang Disc
Brinly Cultivator
5 JD 400 parts machines (2 are destined to be rebuilt)
Craftsman Lawn Cart (orphaned)
Its amazing how fast the collection grows when you aren't even trying....
Robert Webb is offline   Reply With Quote Quick reply to this message
Old 08-25-2012, 08:14 AM   post #10 of 14
69project
69project's Avatar
MTF Member # 40646
I agree on the JD belts comment. I would shop various JD dealers though because when I first went looking for a belt for my 400, the local JD dealer wanted $90+ for it and then I found it on "Keeping it Green" for $46(same belt)...you may find a similar experience with the belt for the 425. I think some dealers feel they charge a little more for parts for discontinued tractors.
Old 08-25-2012, 09:40 AM   post #11 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I'll third the JD Belts, I've used other brand belts on some of my other decks and they never hold up like the JD belts!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 08-27-2012, 01:21 PM   post #12 of 14
Phat Phydeaux
MTF Member
MTF Member # 47436
Thanks for all the info on repairing the guide wheel and deck, I will pull the deck off this evening and check it out.
I haven't bought a belt in two years but have found JD to the way to go. My local dealer has always been lower on cost than the internet guys. I believe in buying at home to help you neighbors when you can and I know the belts hold up better than the ones I have bought at Agri Supply.
I replaced my u-joint on the PTO drive shaft at the first of the summer and again my dealer beat the internet prices, even with out figuring in S&H. Before repairs to the drive shaft / U-Joint my shaft kept uncoupling and sometimes cause the belt to jump off. If there is any damage to a belt idler or pully this might very well be the cause. All one big WAG till I pull the deck and check it out but while having the U-joint shaft issue we didn't see any damage when making those repairs.
Stay tuned a report to follow. Thanks to all that replied, you guys are the best.
Old 10-02-2014, 09:43 PM   post #13 of 14
mister moose
MTF Junior Poster
MTF Member # 3564
Update on my deck:
Last month one of the brackets that hold the front bail mount snapped off. (970 hours)I found the 2 rollers, but no luck on the bracket and shaft. So I found a decent used deck on Craigslist and jumped on it not knowing how well the repair on the busted mower shell would go, plus I needed something for a pattern. So $600 for the deck, $200 for welding repairs it needed, 3 new blades, belt, and rebuild the tensioner shaft. Drain and fill the gearbox. This time I bought a Stens belt, $50 on Ebay. We'll see how it holds up.
So a few comments for 54 deck owners:
Watch for cracks in the bogey wheel mounts, and the front mount brackets. The tensioner bushing is plastic, and will induce wobble when it wears. If you have belt tracking issues check this first.
While welding the cracks I had the guy make a bracket that spans the bottom of the chute out of 3/16 plate steel. Both my used decks came without it, and the local Deere dealer said the original was pretty thin and bent/broke readily. Should solve the bending issue of the right front of the deck.
I also had him weld reinforcing gussets on both front brackets. One had started to crack on this deck as well. Hopefully it's bulletproof.
Now to see if the welder can repair the first deck!
Sponsored Links
Advertisement
Old 10-02-2014, 10:52 PM   post #14 of 14
ricky racer
Senior MTF Member
ricky racer's Avatar
MTF Member # 83427
Images: 3
I was having the same problem with mine. You can read about it here:
http://www.mytractorforum.com/showth...905&highlight=
I purchased the JD Anti-Blowout kit, can't tell you the part number right now but I paid around 70 -80 bucks for it. It helped somewhat but didn't do as good of job as I had hoped. Actually, I'm pretty disappointed in John Deere for not addressing this better.
ricky racer is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
