| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| Introductions For New Members. Tell us about yourself |
Thread Tools | Display Modes |
#1 |
MTF Junior Poster
MTF Member # 76473
So for a few months now my 2008 Cub Cadet LT 1045 has been backfiring when hot after shutdown. No big deal right? Well it evolved to hard starting or not starting when hot? A little starting fluid usually would get it running but not so good to use all the time.
Then, the tractor out and out stopped during a cut and would not restart at all. After several hours sweating in 100% humidity in the garage, it turns out that this model tractor with a Kohler Engine had a Anti Backfire Fuel Solenoid Shutoff valve that screws into the bottom of the carburetor bowl. The solenoid valve over time gets crudded up and stops working properly! A new one from Cub Cadet / MTD is ordered and on the way at get this $75! Temporary, I cut down a 3/8 bolt and screwed the carburetor bowl back on, it runs perfect! Not sure that I will put the solenoid back on! |
| Sponsored Links | |||
Advertisement | |||
#2 |
Busy in Howey
Welcome Aboard!Try posting in the cub forum as this is the intro forum and may get missed, try here: http://www.mytractorforum.com/forumdisplay.php?f=242
__________________
--------------------------------------- You can't have everything, where would you put it? ![]() 2008 JD Z810A ZTRACK 48" (GRASS MUNCHING MONSTER) 2002 JD 4400 MFWD (CURRENTLY OVER WORKED) JD 430 LOADER, JD LX5 ROTARY CUTTER, A&B 5' BOX BLADE, GAMBLER DEBRIS RAKE 2001 JD 4x2 GATOR 1982 TROY BUILT HORSE II 6HP TILLER WITH DOZER BLADE AND BUMPER 1972 MASSEY FERGUSON 12G WITH 610 MOWER DECK AND 720 SNOWBLOWER 1969 MASSEY FERGUSON 7 WITH 710 MOWER DECK 1947 FORD 8N (PRE-RESTORED) 1935 MCCORMICK DEERING O-12 (CURRENTLY UNDER RESTORATION) 1995 Dodge Ram 2500 4x4 5.9 diesel (Official Tractor Hauler) with 400,000+ miles 1967 International Scout 800 (OLD RUSTY) 1947 Ford Business Coupe Like us on Facebook!
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
