B7100 Clutch Replacement - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-28-2012, 05:10 PM   post #16 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
Default Re: B7100 Clutch Replacement
Looks like there a drift pin in the yoke by the U joint, maybe I have to drive that out?
How about the other drive shaft to the rearend too. I see some sort of pin in that too up thru the observation hole. Man that"s hard to get to.
BillCT is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-28-2012, 05:16 PM   post #17 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
This is looking up thru the observation hole at the rear. The shaft to the front diff is at the top.
Old 07-28-2012, 05:43 PM   post #18 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
Maybe I should be unbolting that housing to the left shown in post #15 and the snap ring is in there??
Old 07-28-2012, 07:02 PM   post #19 of 32
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
You have to remove that pin (in the red circle) to separate the yoke from the drive shaft, after you will be able to pull out the drive shaft from the front diff I think.
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Old 07-28-2012, 07:09 PM   post #20 of 32
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
It's look like you have a u joint there too, here's the diagram I was talking about.
Part# 80 to 89
__________________
Forum Rules
Old 07-28-2012, 07:47 PM   post #21 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
Yes, you're right, I figured it out, the front U joint is inside that cover. Removed the cover and there it is, I was misinterpreting the drawings you sent. No snap ring in this tractor though, there a roll pin thru the Yoke and thru the shaft. I drove out the pin and out came the U joint and yoke.
Mr Newbie here!!
Thanks for replying to my emails, I'm ready to split the tractor in the morning.
Old 07-28-2012, 10:39 PM   post #22 of 32
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Mr Newbie here!!
Cool! keep us inform of your progress.
__________________
Forum Rules
Old 07-29-2012, 08:18 PM   post #23 of 32
ribchord
MTF Member
ribchord's Avatar
MTF Member # 3686
Images: 3
thanks i just dowloaded these, i just bought this b7100 4dw hst fel last year, had no books.
__________________
ribchord is offline   Reply With Quote Quick reply to this message
Old 08-04-2012, 11:02 AM   post #24 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
Tractor is finally separated, PP fingers look pretty worn but the disk isn't too bad really. Current delema, how is the throwout bearing removed? The manual is pretty vague, just says remove it. I don't see any "C" clips or anything, looks like a backer plate behind it. Tried to grab it with large water pump plyers but it doesn't seem to budge. Picture below.
I suppose the next question will be on removing the pilot bushing, or even if I should change it.
Old 08-04-2012, 02:32 PM   post #25 of 32
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Can you take a closer pictures of the bearing?
__________________
Forum Rules
Old 08-04-2012, 03:18 PM   post #26 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
It must be pressed on the clutch shaft or something, there's nothing holding it. I pressed the clutch so it sticks out more.
I got the pilot bushing out.....man.......not easy!
Old 08-04-2012, 05:10 PM   post #27 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
I figured it out. You have to reach up in the observation hole behind the bellhousing, remove the spring. Then remove the zerk fitting, remove the clutch shaft, then turn the collar the bearing is pressed onto so the clutch fork falls in your face and the assembly slides out. Man what a design.
Old 08-04-2012, 08:43 PM   post #28 of 32
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Yeah I hear you, how are the bearing, still running smooth or rough?
__________________
Forum Rules
Old 08-04-2012, 09:18 PM   post #29 of 32
BillCT
MTF Junior Poster
MTF Member # 12060
Bearing feels OK, still stiff with grease but I'm gonna change it anyway. The fingers on the PP are really worn so this thing has seen some abuse.
Do you happen to know how to line up the flywheel properly? All the holes are the same distance apart so it'll go on in any position, no dowl pin or anything for alignment. Timing marks are on the outside edge so it has to go on right. I screwed up not marking it somehow.
Sponsored Links
Advertisement
Old 08-04-2012, 11:11 PM   post #30 of 32
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Many engine have timing mark on the harmonic balancer also call damper crank pulley situated in front of the engine where the belt are, if you align the crank pulley on his mark you'll have the mark you need to align the flywheel correctly.
Let me know if it work, if not one other possibility is available.
__________________
Forum Rules
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
