How bad does a reed have to be to cause a non-start? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 07-21-2012, 04:03 PM   post #1 of 19
atomix
Senior MTF Member
atomix's Avatar
MTF Member # 74582
Default How bad does a reed have to be to cause a non-start?
Ok, so I know this sounds like a dumb question, but bear with me.
Picked up a Duraforce with the intention that it would be for parts. Sat outside for "a while" and was seized, but hadn't been straight gassed supposedly. There was an even rougher one next to it that I could have picked up today--but I think I have too many.
The short story is the photo. The lower reed is rusty, and has a hole on the bottom -- about half the bottom side is rusted through. Oddly enough the top reed still moves when you pull the cord though!
Unfroze the piston with a few squirts of oil & the breaker bar. Has spark, is getting fuel (wet plug..and I cleaned the carb and put in a new needle & seat). Primer is pushing in lots of gas...
Basically i went from wanting a parts mower to thinking I could get it running easily. Is reed damage of this magnitude enough to kill compression? With the added mess of oil you see in that photo pointing to a no-doubt weak lower crank seal as well.
Time to park this one for parts and work on more important things? I don't need another running Duraforce right now!
__________________
Several LawnBoys, 1D, 1E, 2F's
2 Toro/Suzuki 2 strokes
Snapper Wisconsin Robin, w/ possible bad coil
A few others...
atomix is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-21-2012, 05:01 PM   post #2 of 19
BDM53
Mowerholic
BDM53's Avatar
MTF Member # 70022
Default Re: How bad does a reed have to be to cause a non-start?
Never been in a duraforce. I may be completely wrong but I would think on the compression stroke the reed wont seal and it will push fuel right back out of it. My experience is with motorcycle reeds but I would think they work similar. Personally I would be afraid if it disintigrating into the motor and would never chance it.
Ill let someone with a little more experience chime in.
__________________
Branden
BDM53 is online now   Reply With Quote Quick reply to this message
Old 07-21-2012, 05:40 PM   post #3 of 19
coolted
OMG I got another LawnBoy
coolted's Avatar
MTF Member # 66300
I have an S21ZPM that had part of the reed broken off, it ran but barely. I would think that reed you have would still allow the engine to run, but I would be hesitant.
I have the same thought as BDM. I would be concerned of rust particles damaging the bearings and the piston. I would also be concerned of the reed breaking off and being digested.
I think you would be very lucky if this mower runs.
Let us know what you do, and as always...LOTS OF PICS!!!
***EDIT*** Look at the piston through the exhaust ports, I'm curious.
This reed came out of a mower that ran...barely.
__________________
-Thank you for helping us help you help us.
2-Lawn Boy Liberty
0-V series
1-S21ZPM
1-R7070 promo
1-10550
1-1973 Parmi sno-thro (I use it, works great)
1- 2003 Arctic Cat 4x4
1- Domestic short-hair cat (Slash).
coolted is offline   Reply With Quote Quick reply to this message
Old 07-21-2012, 08:34 PM   post #4 of 19
LawnBoy2ndToNone
Proud Member of the 1K Club
LawnBoy2ndToNone's Avatar
MTF Member # 69856
I would replace the reeds. They're pretty inexpensive and would be worth a shot at trying to fix this one. If it doesn't work, you can always save the good reeds for another mower that comes along, but that's just my opinion.
__________________
Andy
"Lawn-Boys never die.....They get restored by MTF members!" - Coolted
Lawnboy
3052
7260
8252
7265
8310
L20ZPRA
7351
10515
10525
5024 (restoration completed 12-12-12)
7023 (parts)
8232M (parts)
5275 (parts)
Echo
GT2000R(string trimmer)
PB500T (backpack blower)
280CS (chainsaw)
Stihl
FS51AVE(string trimmer)
FS36(string trimmer)
Husqvarna
340 (chainsaw)
HU700L (lawnmower)
LawnBoy2ndToNone is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 10:51 AM   post #5 of 19
atomix
Senior MTF Member
atomix's Avatar
MTF Member # 74582
Coolted's picture has me confused! It seems like my destroyed reed should work compared to that one! But I'll stop trying, I think some of the rust already has been sucked in to the engine from my cranking attempts, doing who knows what damage.
Alright, I think the plan of attack is to dig into the engine as my time allows. I really don't need another Duraforce running, so I may get the engine apart (pictures!), diagnose, and let it sit until I need a spare.
The biggest hold back for me isn't the reeds ($4 last I checked), it's the $45 ring set, and $20 worth of needle bearings I'd want to put in while it was apart.
Also, I can't see the piston until it's off the deck. I'll see where I get to over the next few. Thanks for help guys.
__________________
A few others...
Old 07-22-2012, 11:13 AM   post #6 of 19
qd-16
Senior MTF Member
qd-16's Avatar
MTF Member # 30251
My guess would be rings stuck to the piston causing loss of compression???
__________________
lawnboys
10550
10515
7200
5210
7253
7265
6262
qd-16 is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 12:53 PM   post #7 of 19
atomix
Senior MTF Member
atomix's Avatar
MTF Member # 74582
I only have a diesel compression gauge, so I haven't tried to get a reading (I don't think this guy will be making 400-600 psi!)
Spent another hour on this since the wife was watching the baby and it was too wet to work outside...Engine is off the deck, and just needs a good wash before I crack it open.
Only odd finding was the soup pouring out of the exhaust. I put a good dose of oil in through the spark plug hole...and later some MMO to hopefully unstick any rings. But I did a lot of that ill fated cranking/pulling which I would have thought would have blown all this out. Very little in the transfer tube, odd.
Smells like gas & oil, but has little chips of rust in it (hooray). Could this be water living below the piston?
Can't wait to crack the case now...
ID:	222296   Click image for larger version
ID:	222297   Click image for larger version
ID:	222298   Click image for larger version
__________________
A few others...
Old 07-22-2012, 03:22 PM   post #8 of 19
LawnboyKS
Lifetime Lawn Guy
LawnboyKS's Avatar
MTF Member # 47527
That sucker doesn't look like it had just been rained on, it looks like it had been submerged in water! I'd guess that water filled the engine and just sat there for quite some time and the condensation from that caused the reed to rust out like that. I don't see how else an engine could get that wet sludge inside...
I wonder how common this is in areas that have had floods? Anything with an engine on it, if put under flood water, would have the same sort of damage unless the water was cleaned out in short order and the internals relubricated.
__________________
Jason Rose
-You know you have a Lawn Boy addiction when the space provided here isn't big enough to post all the models you own...-
LawnboyKS is online now   Reply With Quote Quick reply to this message
Old 07-22-2012, 05:38 PM   post #9 of 19
BDM53
Mowerholic
BDM53's Avatar
MTF Member # 70022
Going to be interesting to see whats inside. Definitely looks like it was sitting in a lake
__________________
Branden
Old 07-22-2012, 10:03 PM   post #10 of 19
LawnBoy2ndToNone
MTF Member # 69856
Take one of the old bearings to a bearing shop to have them measure and order new ones. It will save you money. $45 seems steep for new ring set also, I'd do a little more digging. I think you could get that one running for a bit less than you stated.
__________________
Andy
Lawnboy
3052
7260
8252
7265
8310
L20ZPRA
7351
10515
10525
7023 (parts)
8232M (parts)
5275 (parts)
Echo
280CS (chainsaw)
Stihl
Husqvarna
340 (chainsaw)
HU700L (lawnmower)
Old 07-23-2012, 11:04 PM   post #11 of 19
atomix
Senior MTF Member
atomix's Avatar
MTF Member # 74582
Well, whoever guessed this mower was used in a swimming pool or a swamp would probably be the winner. Holy heck, what a mess! The reed is/was the least of my concerns!
I don't know what the previous owner did to this thing! Maybe, somehow, our 2 foot snow storm 2 years ago seeped in??
There was rust pretty much everywhere, particularly on the lower 1/2 of the crankshaft. The lower main (?) bearing on the crank was darn near frozen. The crank was covered in rust....The crankcase was too.
Doesn't seem like the engine was actually run that hard, the cylinder wall and piston didn't look bad beneath this rusty murk.
Bulk trash pickup is tomorrow--should I toss everything you see in the trash??
ID:	222531   Click image for larger version
ID:	222533   Click image for larger version
ID:	222534   Click image for larger version
ID:	222536   Click image for larger version
ID:	222537   Click image for larger version
ID:	222538   Click image for larger version
__________________
A few others...
Old 07-23-2012, 11:09 PM   post #12 of 19
LawnboyKS
Lifetime Lawn Guy
LawnboyKS's Avatar
MTF Member # 47527
That was me! What do I win? One rusted up DF engine? haha! I'd say that's without a doubt a case of an engine that's been swamped, and then just left for dead...
Do you plan to rebuild it? If so, is it really worth it? Aside from the metal rusting I'd imagine the aluminium parts inside the block would have corrosion started on them too. I'm surprised the cylinder walls weren't rusted up too. If they were, you have a boat anchor... Bearings are replaceable at least, and everything else...
__________________
Jason Rose
Old 07-24-2012, 12:00 AM   post #13 of 19
coolted
coolted's Avatar
MTF Member # 66300
Holy Mother that is TERRIBLE!
__________________
2-Lawn Boy Liberty
0-V series
1-S21ZPM
1-R7070 promo
1-10550
Old 07-24-2012, 12:23 AM   post #14 of 19
atomix
Senior MTF Member
atomix's Avatar
MTF Member # 74582
Boat anchor indeed, or target practice!
This may scare me out of buying / picking up any more non-running mowers! It really looked fine on the outside save a little oil and tree debris. Has a nicer deck than my "good" duraforce!
__________________
A few others...
Sponsored Links
Advertisement
Old 07-24-2012, 02:19 AM   post #15 of 19
bosco659
Senior MTF Member
MTF Member # 75084
What a shame! I would salvage any of the decent external parts and toss the engine itself. Trying to rebuild it would cost you a ton of money and with the severe rusting who knows if it actually can be successfully rebuilt?
__________________
10518 - daily driver
22261 - fully restored - invested more than a new one!
5000 - waiting to be brought back to life
8237 - It's alive and for sale
5150 - new addition to the shrinking collection
Stihl 026
Stihl MS200T
Honda HS55
Craftsman LT2000
bosco659 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
