Tire Dry-Rot Repair - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 07-14-2012, 06:05 PM   post #1 of 20
Cam-Shaft
Proud Member of the 1K Club
Cam-Shaft's Avatar
MTF Member # 54891
Default Tire Dry-Rot Repair
I picked up some tires which hold air, but have some heavy cracking. Would it be OK to use black urethane to fill the cracks, then spray tuck bed liner over it?
__________________
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
Bolens HT-23S power steering, Cruise control, Transmission cooler.
Bolens HT-20 w/ARK 500 FEL and 3pt hitch (apart for repairs)
Bolens 1050 pulling tractor (Wisconsin TJD)
Bolens 800, rebuilt engine.
Cam-Shaft is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-14-2012, 07:46 PM   post #2 of 20
orange j d
My Orange Jane Deere
orange j d's Avatar
MTF Member # 37225
Images: 1
Default Re: Tire Dry-Rot Repair
Go for it, it will ether work and look good or it will fall off. What you got to lose. Take some before and after pictures and keep us post on the out come.
__________________
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline   Reply With Quote Quick reply to this message
Old 07-14-2012, 08:03 PM   post #3 of 20
flash5153
3K Poster!!!!
flash5153's Avatar
MTF Member # 62748
If you figure this one out,, patten your method and you will be a millionaire.
Well,,Ok,,maybe not a millionaire but at least I would know how fix them.lol
Only thing I know that will work is a tube or sometimes if not too bad,,,,green slime will cure it,,or fix a flat.
Seems like just maybe black gasket maker might work but you would have to let it dry before putting air pressure to it. It won't hold much PSI,,so if it is real bad it won't work. But I have seen leaks like this where the air is barely coming out,,there's not PSI there.
I have never tried it ,,just a thought.
Make sure no one is around when you do it!!!!
But if it works????? hmmm???
flash5153 is online now   Reply With Quote Quick reply to this message
Old 07-14-2012, 08:05 PM   post #4 of 20
Evo26pm
Senior MTF Member
Evo26pm's Avatar
MTF Member # 75837
Garage
Talking Re: Tire Dry-Rot Repair
If you have tires that are dry rotten then the best solution is to put tubes in them then you be fine. Tubes are cheaper to buy the buying brand new tire.
__________________
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Exmark Turf Tracer 48"
Evo26pm is offline   Reply With Quote Quick reply to this message
Old 07-14-2012, 08:06 PM   post #5 of 20
Evo26pm
Senior MTF Member
Evo26pm's Avatar
MTF Member # 75837
Garage
Aw and just for note the urethane and bed liner won't work on it. I knew a guy that actually tired that. Lol
__________________
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Old 07-14-2012, 08:11 PM   post #6 of 20
orange j d
orange j d's Avatar
MTF Member # 37225
Images: 1
Go back a reread. He never said anything about fixing a flat. He said they DO NOT LEAK they hold air. He just wants to make them look nice. *** some peoples kids.
__________________
Old 07-14-2012, 08:16 PM   post #7 of 20
Evo26pm
Senior MTF Member
Evo26pm's Avatar
MTF Member # 75837
Garage
Yes I under stood what he was meaning but just saying for future reference and if you are wanting them to look good then ppl would actually pay the money and get new tires!
__________________
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Old 07-14-2012, 08:20 PM   post #8 of 20
flash5153
3K Poster!!!!
flash5153's Avatar
MTF Member # 62748
Quote:
DOH!!! Got me,,,,,I missed that part.
Heck ya it will work!!! Can paint a mural on them if all you want is beauty!!! lol
Old 07-14-2012, 08:39 PM   post #9 of 20
grnspot110
3K Poster!!!!
grnspot110's Avatar
MTF Member # 4515
Images: 21
Garage
Try Miller Tire's "Tire Paint", it won't fill cracks, but will make old tires look better!
http://www.millertire.com/products/t...ck-tire-paint/
__________________
Home of the JD L/60 "Custom" & the 70 I!
grnspot110 is online now   Reply With Quote Quick reply to this message
Old 07-14-2012, 08:40 PM   post #10 of 20
Cam-Shaft
Cam-Shaft's Avatar
MTF Member # 54891
All I was hoping to do was keep water out of the cracks...
__________________
Old 07-15-2012, 10:50 AM   post #11 of 20
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
Tubes can be pinched in dry rot cracks if they are large enough cracks,and the tube may be eventually punctured....I have made a "boot" from an old tube to put in a tire before tubing it ,to prevent this from happening...
I have used "shoe-goo" or "Goop" sealant/adhesive on some badly cracked sidewalls on tires I had,that still had excellent tread and only leaked slowly,over a few days time they would go nearly flat...so far thats the only stuff I tried that seemed to adhere well to rubber and didn't peel right off ..
I used a drill with a wire brush to ruff up the rubber around the cracks and folded the tire to open the cracks up more then forced the goop in with a putty knife,and I put a thin layer on the entire sidewall....inside & out!...
I learned to wait several days before inflating the tires,otherwise the goop will blow a big bubble, and come off ,or pop!...I ended up using tubes in the tires after assumung they wouldn't hold up well with goop alone...I used acetone to clean the rubber well before applying it too....never tried Goodyear "Pliobond" on this application,or rubber cement,maybe that would work too.....nothing beats new tires though..
__________________
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Old 07-15-2012, 12:29 PM   post #12 of 20
Canawler
Canawler's Avatar
MTF Member # 32205
I would think that truck bed liner would be just a bit too stiff and would flake or fall off as the tire flexes.
Maybe a rubberized undercoating???
__________________
---Jim
It's only money, you make more every day.
'74 Agway/MTD 990
'93 Troy-bilt GTX18
'74 Allis Chalmers Homesteader 8 (X2)
?? Simplicity Broadmoor 717
?? Pennsylvania Meteor 1010
Canawler is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 01:34 PM   post #13 of 20
Cam-Shaft
Cam-Shaft's Avatar
MTF Member # 54891
thanks for the ideas.. I'm going to look around and see what I find.
__________________
Old 07-15-2012, 02:33 PM   post #14 of 20
orange j d
orange j d's Avatar
MTF Member # 37225
Images: 1
Well if you find something good that works let me know, the ol lady is getting a lot of dry rot spots I will use it on her.
__________________
Sponsored Links
Advertisement
Old 07-17-2012, 09:53 PM   post #15 of 20
Engine_Tech
MTF Member # 46741
I have some badly cracked ATV tires and I just put Slime in them to seal up any holes that have developed or may develop. I know your's hold air now, but who knows in the future. Plus, you would probably destroy the tires trying to get tubes in them now.
For strictly looks, in the movie The Last Indian (about breaking the land speed record on an Indian motorcycle) the character gets red flagged by the safety guy as his tires have cracks in them. He solves the problem by rubbing shoe polish into the cracks.
Engine_Tech is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
