#1 |
MTF Member
Snagged this out of the trash last wee and I love it. Starts on the first pull but spits gas up out of the carb at speed. Always had a thing for older equipment. Any ideas would be appreciated. Also I have no time frame on when its from if anyone knows.
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior MTF Member
MTF Member # 63518
all those did that when the air cleaner screw was out. thru the hole the air cleaner screw threads into.... look for model type and code numbers
the 1st 2 numbers of code is year engine was built (the "19"_ _ is left off so if code starts with "77" the eng was built in 1977) I would guess that mower's from mid to late 70s |
#3 |
Jack of All Trades
MTF Member # 27867
Do you always wee in the trash?
couldn't resist.
__________________
Owner, head mechanic, janitor, chief cook and bottle washer @ Nuevo Lawn and Garden Equipment Repair. KCBS Certified BBQ Judge (CBJ) Pitmaster @ All About the Q' ![]() Facebook.com/itsallabouttheq |
#4 |
2000 Posts and climbing!!!
![]() Join Date: Jul 2011
MTF Member # 62748
That's the biggest picture I have ever seen posted on this site. lol
#5 |
MTF Member
Sorry about the picture size, took it with my phone and thought it would be smaller. And if I am reading the code right its a 75. And no I don't wee in anyone's trash, but you did make my wife laugh. Already stripped down and cleaned the carb but I didn't know about the it spitting without the air cleaner. I've never see one with the carb mounted on the fuel tank like this. Still need to figure out why it dies above idle but I know more now than I did yesterday. Thank you for the info.
#6 |
3K Poster!!!!
![]() Join Date: Nov 2008
MTF Member # 19618
Its a Simplicity if you didn't know that already. The model and serial tag is under the white belt cover on the back I believe.
| Sponsored Links | |
Advertisement |
#7 |
Senior MTF Member
MTF Member # 63518
when running put the air cleaner stud back into its hole and it wont spit like that. there is an adjustment screw on the carb look below where the throttle cable goes there is a round hole for a screwdriver to fit into. may just need adjusted. I typically start with that set about 1-1/4 out and adjust from there as needed to make the engine happy. this was "Standard Briggs" for years and years. (gas tank mount carb) I think there are still a few, cheaper push mowers, power washers etc that use this setup but the newer ones aint like they used to be.(now non adjustable, don't like a sudden clump of heavy grass etc)
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
