mower deck 445 pto stopped working - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-30-2012, 07:21 PM   post #1 of 9
fishingdave
MTF Junior Poster
MTF Member # 75081
Default mower deck 445 pto stopped working
while cutting the grass today after the mower was warmed up the mower deck stop cutting . i would reset the switch and it would turn back on most of the time. I think it might be the pto switch but not sure . Is it a common problem? the mower is a 95 with 380 hrs on it. Any help in trouble shooting would be great!
fishingdave is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-30-2012, 09:08 PM   post #2 of 9
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
Default Re: mower deck 445 pto stopped working
The PTO switches do have to be replaced...while not a real common problem, it is a known issue.
__________________
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline   Reply With Quote Quick reply to this message
Old 06-30-2012, 10:22 PM   post #3 of 9
WNYTractorTinkerer
5000 Strong & Climbing
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: mower deck 445 pto stopped working
pull the right side panel & look @ the Power module when the thing is running and you are in the seat. If there is a Red LED lit then all the safety switches are satisfied to start the PTO. The switch is the main culprit. (I just went through this on my 425)
If it isn't lit than ring out your seat switch (brake has to be OFF or it shuts it off!)
Next victim is the PTO switch.. Get a replacement & have fun getting the old one outta there!
WNYTractorTinkerer is offline   Reply With Quote Quick reply to this message
Old 06-30-2012, 10:53 PM   post #4 of 9
Diesel Powered
MTF mile high club member
Diesel Powered's Avatar
MTF Member # 69612
Another possibility..
They're designed to shut the PTO off if the engine temp gets too high. Check your coolant level, make sure your screens stay clean, and keep an eye on your temp guage.
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Diesel Powered is online now   Reply With Quote Quick reply to this message
Old 06-30-2012, 11:22 PM   post #5 of 9
fishingdave
MTF Junior Poster
MTF Member # 75081
If its over heating will I still be able to reset the pto right after it goes out? I was planing on changing the antifreeze what type can I use? Wny what was ur symptoms ?
Old 07-01-2012, 02:51 AM   post #6 of 9
WNYTractorTinkerer
MTF Member # 26264
Images: 13
Garage
Quote:
My PTO ready Red LED on the power module was off but when I turned the switch on I had 12V+ @ the actuator on the upper rear of the tranny.. I replaced the switch and the PTO ready light came right on then the PTO worked after that..
As far as coolant temperature- I looked @ the PTO trouble-shooting for the 445 and it isn't in the loop.. Nice thought though DP..
D/L & save this Service manual to your computer or even a zip drive for future reference Dave: http://www.mytractorforum.com/showthread.php?t=142324
Old 07-01-2012, 02:40 PM   post #7 of 9
Diesel Powered
MTF Member # 69612
Quote:
Wow, yet another reason why the 455 is superior.
I figured something like that would be universal across all 3 (425/445/455).
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Old 07-01-2012, 03:50 PM   post #8 of 9
Engine_Tech
Proud Member of the 1K Club
MTF Member # 46741
Yep, only 455's have the overtemp PTO shutoff.
But, the 425/445 are sort of superior in that they use the 455 radiator, which is way oversized for the gas models. Thus, the gassers rarely overheat and don't need the added cost of the overtemp switch.
Engine_Tech is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-01-2012, 04:15 PM   post #9 of 9
Diesel Powered
MTF Member # 69612
It's all good. You'd have to be a few fries short of a happy meal to overheat a 455.
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
