Piston Corrosion On HH100 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 05-28-2012, 05:38 PM   post #1 of 12
ShelbyGT550
2000 Posts and climbing!!!
ShelbyGT550's Avatar
MTF Member # 62377
Default Piston Corrosion On HH100
I seem to recall a thread that was posted about this same issue but not sure what engine it was one, This is on a HH100. Issues I was having is it was forcing oil out the breather. Only did it after going WOT then it did it the whole time the engine was running. Could this corrosion be the cause?
Also noticed this
__________________
1996 John Deere 425 Main Summer Machine - 20HP Liquid Cooled Kawasaki - Hydrostatic Twin Pedals - 48" Deck
197? John Deere 400 H3 Main Winter Machine Down - Fixing odds & ends - 19.9HP Kohler 532- Hydrostatic - 3PT Hitch - Back Blade - Snow Blower - Cab - Weights - Chains
1974 Massey 12G - Backup Machine - Tecumseh 12HP - 4 Speed Variator - 42" Mower Deck - Snow Blower - Tiller - Cab
1996 Sears GT6000 - Backup Machine - Kohler Command 22HP Twin - 6 Speed Hi/Low - 42" Mower Deck - 42" Dual Stage Blower - Brush Guard - ATV Tires - Chains & Weights
1974 John Deere 112
(Parts)
197? John Deere 112 Electric Lift - Storage - 12HP Kohler K301- 4 Speed Manual - Turf Tires
Past Machines & To-do's - 1974 Snapper LT16 - 1989 Murray GT18/46 - 1970 Massey Ferguson 10 - 2004 John Deere LA100- WIP
ShelbyGT550 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-28-2012, 05:58 PM   post #2 of 12
brokeitagain
MTF Member
brokeitagain's Avatar
MTF Member # 71775
Garage
Default Re: Piston Corrosion On HH100
that piston looks heavily worn, have you measured it and the bore to see what is no longer round?
Take rings off place them squarely in the bore and check ring end gaps
It looks like its time for an overhaul
Has the air filter been inspected to see if it has holes in it or improperly installed, looks to be dirt ingestion causing piston scuffing and ring wear
__________________
1991 MTD Silver Edition 18HP B&S Twin II, 46'' deck
1986 Cub Cadet 1105 20HP B&S Twin II 36'' deck
brokeitagain is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 06:49 PM   post #3 of 12
ShelbyGT550
MTF Member # 62377
It had only a foam precleaner when I got it, No idea how long it was ran like that, I assume this is not just a stuck ring cuasing the oil blowing?
__________________
1974 John Deere 112
(Parts)
Old 05-28-2012, 06:54 PM   post #4 of 12
rscurtis
5000 Strong & Climbing
MTF Member # 25367
That piston looks OK for re-use, but the rings are worn out. If it does not have an offset wrist pin (indicated by an arrow on the crown indicating a direction of installation), you can turn it around on the rod the wear the other side.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 05-28-2012, 10:58 PM   post #5 of 12
markusedma
Senior MTF Member
MTF Member # 30825
Personally I would not re-use that piston. The crown has alot of erosion. Usually caused by a build up of carbon at the top of the cylinder. Is there a ridge at the top of the cylinder that will grab your finger nail?
__________________
3x Honda 4514, 2x Honda HT3813
2X JD L130, LX178
Roper YT16 Hydro,
Kubota G4200hst
Kubota B7100D
2X Kubota G5200HST
Cub Cadet 2518
Sears craftsman DGT6000
markusedma is offline   Reply With Quote Quick reply to this message
Old 05-29-2012, 02:48 AM   post #6 of 12
dodge trucker
Senior MTF Member
MTF Member # 63518
the top ring land is pretty chewed up, I would not reuse it.
dodge trucker is offline   Reply With Quote Quick reply to this message
Old 05-29-2012, 10:55 AM   post #7 of 12
tomw0
MTF Member # 34922
Check the piston ring end gap by placing them in the bore, one at a time, and using the piston backwards to push a little on the ring, square the ring. Measure the gap between the ends of the ring using a feeler gauge. Check against the manufacturer specified range. If within tolerance, pbt. The rings are allowing blowby from the combustion chamber to pressurize the crankcase, causing the oil to get blown out. At higher rpms, the pistons seem to seal better in most cases as there is not enough time for the gas to escape past the rings into the crankcase. You'd see a lot more at idle speeds in most cases.
The top of the piston sure looks clean compared to a lot of the pics you see posted here. From the condition, it is hard to believe this engine is blowing oil. Most times the piston would be covered with 'stuff'. The rod bearing is not perfect, but I have yet to see one that has run for any length of time that IS perfect. What does the crank journal look like?
The scoring of the topmost land is a little more than expected. Was it run low on oil or with the cooling fins clogged with trimmings? If the piston fits into the bore without binding, and doesn't flop around, as in you cannot 'rock' it, then you can put back together and see what happens. If you are doing this for a living, the more profitable and likely success will be found with new parts. If you are on your own time, you can afford to try the old parts. Check to see how sloppy the rings are in the grooves by sticking the ring into the groove 'backwards' and using a feeler gauge to measure clearance between the top or bottom of the ring and the land. There is a spec for that too. If the clearance is too large, the ring will have too much room to flop around, and will not seal properly. I think it will 'flutter' in the groove rather than follow the piston smoothly, leading to poor sealing.
tom
tomw0 is offline   Reply With Quote Quick reply to this message
Old 05-30-2012, 11:21 AM   post #8 of 12
ShelbyGT550
MTF Member # 62377
Ring end gap is above 35 thou, as thats as high as my feeler gauge goes, and its lose in the gap
__________________
1974 John Deere 112
(Parts)
Old 05-30-2012, 02:24 PM   post #9 of 12
dodge trucker
Senior MTF Member
MTF Member # 63518
be nice if you had a new set of rings for it to check end gap with again; see if the end gap is tighter in that bore, with a new set....sadly I just scrapped both an HH and a VH 100 like a month ago; the HH was almost certainly rebuildable; the VH I'm guessing would have needed bored out. (ran outta oil seized and freed up by PO.)
this was truly the 1st and only VH series engine that I have ever had; it came on an old (late 70s) Bunton commercial walk behind
I had a fresh, overbored and rebuilt Briggs 12.5 L head I/C sittin here so that's what I put on that mower instead.
Old 05-30-2012, 03:01 PM   post #10 of 12
WNYTractorTinkerer
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Yikes Re: Piston Corrosion On HH100
Yup- Whipped rings.. Another cause could be a faulty CC breather but not likely due to the looks of the bore.. The cylinder could be ovaled perpendicular to the wrist pin. (axial forces cause the piston to slap and wear in that direction.) The ring in the middle of the cylinder bore concerns me.. I'd try cleaning it up and measuring it as it may be time for a bore job and oversize piston.. Or if you are flipping it re-ring at least.. The piston should be replaced due to the wear too..
WNYTractorTinkerer is online now   Reply With Quote Quick reply to this message
Old 05-30-2012, 09:31 PM   post #11 of 12
ShelbyGT550
MTF Member # 62377
Thanks WNY,
Will be putting her on the shelf for now, got no funds to do that much work sadly
__________________
1974 John Deere 112
(Parts)
Sponsored Links
Advertisement
Old 08-17-2012, 05:09 PM   post #12 of 12
ah64bennett
MTF Junior Poster
MTF Member # 77498
Greetings gentlemen, I just joined up on the forum, but have been reading for a few months while I am restoring a Sears XL 10 that I got for free. The engine on it has the HH100 sheet metal but turns out itís actually an HH120, I figured that out when I ordered a new standard piston for the HH100, not the same size as mine! Anyways, I ordered the correct piston kit but still have the new HH100 standard piston kit with new rings, piston, wrist pin and clips. If anyone wants it, I would prefer to just give it to someone than to bother sending it back to the company I bought it from and paying a restocking fee. The Kit is a ROT6736 ROTARY AFTERMARKET piston kit from Patís Small Engine.
ah64bennett is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
