Tuff Torq Fluid Change - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-23-2012, 11:24 PM   post #1 of 15
John151
Senior MTF Member
John151's Avatar
MTF Member # 71778
Default Tuff Torq Fluid Change (K71B)
As a tractor newb, and a preventative maintenance advocate, I have been reading dozens of posts on fluid changes on the tuff torqs. However, all I have accomplished so far is to get myself totally confused.
Is this a simple and safe task? Some posts led me to believe I have to pull the entire unit, and some posts have lead to to believe that the unit could be damaged if air is left in the system.
How often does the fluid need to be changed? I don't know the entire history of my machine (other than it appears to have been well taken care of), but if the tractor runs great, do I need to even worry about this?
What fluid should be used? I have read posts about 10W30 motor oil, 5W50 synthetic motor oil, Amsoil hydrolo fluid, JD high and low viscosity fluids. That is quite a variety of fluids.
__________________
1998 GT 275, 17 HP Kawasaki (air cooled), 48" mulching deck, Tuff Torq K71B
2001 JS 63 self propelled push mower
2012 Echo SRM-225 string trimmer
1979 Snapper 5/23 Snow Blower
2012 National Walking Sprinkler - A5-2 with optional mud wheels
1999 K9 fertilizer spreader (border collie, black lab mix)
John151 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-23-2012, 11:33 PM   post #2 of 15
wizzo
MTF Tractor Nut
wizzo's Avatar
MTF Member # 32657
Default Re: Tuff Torq Fluid Change
Most of the sealed Tuff Torq models it is best to remove the trans and turn it upside down to drain the fluid. TT usually suggests 5W50 synthetic oil about every 200 hours.
__________________
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 11:39 PM   post #3 of 15
Hardscrabble
Senior MTF Member
Hardscrabble's Avatar
MTF Member # 4174
I have a JD X485. I changed mine every 50 hours. Probably overkill but I am very big on fresh fluids in equipment. I used the factory recommended JD Low Viscosity transmission fluid.
__________________
If you like your Freedom - Thank a Vet.
Hardscrabble is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 11:43 PM   post #4 of 15
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Your suppose to use Low Viscosity Hy-Gard here’s what the outside of the container Looks Like http://www.deere.com/wps/dcom/en_US/...ils/oils.page? at the Bottom of the Page They do have it In 1 quart Containers You Need 3.4 quarts
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is online now   Reply With Quote Quick reply to this message
Old 04-24-2012, 12:18 AM   post #5 of 15
Jim_WV
Jim_WV's Avatar
MTF Member # 241
Images: 13
Garage
Here's the scoop from Tuff Torq on recommended replacement lubricants for various TT transmissions. I used the Castrol Syntec 5w50 when I rebuilt my K46.
http://www.mytractorforum.com/showthread.php?t=113369
But yes as Sarge said you should use the HyGard, which coincides with the chart for the K71B
Jim_WV is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 12:51 AM   post #6 of 15
Sergeant
Sergeant's Avatar
MTF Member # 24
Thanks Jim I always forget about that chart for the substitutes
__________________
White Model: GT2055
Old 04-24-2012, 10:20 AM   post #7 of 15
John151
Senior MTF Member
John151's Avatar
MTF Member # 71778
Thanks guys!
I am still not clear on the high vs. low vis JD oil. J20C - high vis, J20D = low vis? Is the difference between these just outside temps? If I am only cutting grass in the summer (no snow attachment just yet), wouldn't I want high vis?
Also, how easy and safe is the fluid to change? Is this on par with changing the engine oil? Or is there more to this.
__________________
Old 04-24-2012, 11:31 AM   post #8 of 15
KCFLY
Senior MTF Member
KCFLY's Avatar
MTF Member # 48034
When I changed the fluid in my gt235 it was a fairly painless process. I contacted TuffTorq directly for any guidance/suggestions on my fluid change. They are very helpful. There was no need to pull the transmission. Just take your time and you'll be fine.
__________________
-Brad
2000 JD GT235 w/48C, PowerFlo, & front dethatcher
42" blade, and 42" snowthrower
2 105 lb. cast wheel weights
KCFLY is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 05:36 PM   post #9 of 15
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Default Re: Tuff Torq Fluid Change (K71B)
It all depends on what transaxle the tractor has. If the unit is sealed (like the K46), JD doesn't recommend any maintenance on it. In order to change the oil on it, you have to drop the transaxle. Tuff Torq recommends using 5W-50 synthetic on the K46 if you do change the oil. IIRC, they recommend changing the oil at 50 hrs then every 200 hrs.
For models that have a serviceable transmission, the operator's manual usually has instructions for changing the transmission oil as well as the recommended oil. I think JD recommends changing the oil at 50 hrs, then every 250 hrs.
It would probably be a good idea to pick up the operator's manual for your tractor to see what JD recommends. They offer free access to many manuals online, but I don't think they offer it for yours.
Preventative maintenance is always better than repair. You don't want to wait until the transmission starts giving you problems before you decide to change the oil.
__________________
Need info on a JD tractor? Go here:Link
Need a free online owner's manual? Go here: Link
Buying JD parts? Go here for the latest coupons: Link
Current
2002 John Deere LT150 Hydro
Kohler Command CV15S 15 HP single
38" deck, material collection system, G6 Gator blades
Previous
1987 John Deere 130
Kawasaki FC290V 9HP Single
30" deck, Tri-Cycler Mulching Kit
sjlee is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 06:09 PM   post #10 of 15
CenTex Guy
MTF Member
MTF Member # 66716
When I bought my x485 it need fluids. I called the service manager at my JD house, about the low viscosity fluid (I had been reading on this marvelous forum about it). He stated that the low vis fluid was more for the norther states i.e. colder climate weather and that here in cen tex should have any trouble running regular hydraulic fluid.
CenTex Guy is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 08:24 PM   post #11 of 15
mikgran
Proud Member of the 1K Club
mikgran's Avatar
MTF Member # 61817
Thank you for highlighting the really irritating part for owners of sealed transaxles.. Tuff Torq tells you the service intervals for keeping the transaxle in the best possible operating condition. JD has the transaxles built to not be serviced, gambling that the owner will not have problems before the warranty expires. The transaxle is slightly cheaper to buy when it`s spec`d out with no drain and fill capabilities, and very profitable when they replace it due to failure caused by worn out , burned fluid. By waiting until the warranty expires, you have exposed to the inner parts to a lot of wear from worn out, dirty oil.
So do you follow Tuff Torq`s guidelines and risk voiding the warranty, or do you follow JD`s guidlines and pretty much guarantee that the transaxle will have a much shorter lifespan than it could have.
mikgran is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 08:45 PM   post #12 of 15
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
If it were me, I would not touch the transaxle until after the warranty ran out. If you overwork the K46 (hilly terrain, plowing snow, etc.), you could still have a problem even if you change the oil.
The warranty on a 100 series tractor is 2 yrs/120 hrs. If you're using it for what it was designed for (i.e. light-duty work), I would think that the original oil should be able to last at least that long.
__________________
Current
Previous
1987 John Deere 130
Old 04-24-2012, 09:54 PM   post #13 of 15
Jim_WV
Jim_WV's Avatar
MTF Member # 241
Images: 13
Garage
If I'm reading the OP first post correctly, this is a K71B tranny in a used machine, so the K46 info, warranty and sealed transmissions information would not apply .
Old 04-24-2012, 10:04 PM   post #14 of 15
mikestoy
2000 Posts and climbing!!!
mikestoy's Avatar
MTF Member # 38920
It would probably be a good idea to pick up the operator's manual for your tractor to see what JD recommends. .
Good advice.
Also don't forget check the type of filters along with choosing the oil.
__________________
Mike
My 2011 X720 Tractor: "The spirit of a race horse....but the body and pulling power of Clydesdale."
2011 X720 54c" mower deck/ 47" snow thrower / 2 bag vacuum System....SWEET
Other Toys:
2003 Candy Red Honda Goldwing Touring Cycle ......SWEET
2009 18' Lund w/200 hp Boat
2012 Black Lexus RX 350
Married for 47 years.
1 adopted son, married and lives in Charlotte N.C.
mikestoy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-24-2012, 11:22 PM   post #15 of 15
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Right. The only reason I mentioned those things is because the OP seemed to think that some of the things he's read about the K46 apply to his transmission.
__________________
Current
Previous
1987 John Deere 130
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
